04-01-2013, 11:54 AM | #1 |
Rep 1,209
FOOTWELL lights
Has anyone replaced their footwell lights? Even with lighting settings set to brightest, i wish mine were a bit brighter. Not sure if it''ll throw code, or how easy it is, so checking here first. Can't imagine it's too hard, but code stuff not sure about.
2015 Tanzanite Blue M3 /19 silver/exec/SS full leather/hk/cams/6speed_Wife 2017 x5 xdrive 35i
04-01-2013, 12:16 PM | #2 |
Rep 4,553
I don't think the footwell lamp is monitored or will throw a code. Pull it out and disconnect it. See what happens.
I believe its an LED lamp so may be a project to increase illumination.
04-01-2013, 01:47 PM | #3 |
Rep 1,209
if i do get a code, then plug it back to stock, will the code clear itself or do i need it to get 'professionally' cleared by dealer?
04-01-2013, 05:58 PM | #4 |
Rep 4,553
For something like a lamp, it should clear after a couple starts of the car where it observes no further failure. Will stay in history unless dealer clears history.
04-02-2013, 08:41 AM | #5 |
1ST CLASS AWMSPORT
74
Rep 789
Drives: 13' 328 MSPORT
Foot wells
Ok....so I kinda didn't want to post this for the Simple fact that it was a mission to get done and hard to do a DIY. So I had the same thinking that the footwells weren't bright enuf. I took out n removed the housing and the 3led mother board. Spliced into the wire for the welcome lights and sport setting , and then wired in L.E.D bulbs to them, drilled 2holes to the back of the housing, put the bulbs thru the holes and ........ Wollalla....I do not have footwell lighting on the classic (orange) setting, cus I don't like orange...but when the LEDs are on IMO, LOOKS HOTTT!!
Did this with all the lights only one I'm having trouble with are the dome lights...I cant get the housings off....and it's very frustrating!!
'13 328i MSport, AW, Black Dakota leather, Premium Pkg, xenons, ///M Perf, side skirts,Front Lip, Fully coded, CF roundels, Matt Black Grillz, Painted reflectors (front & rear) Smoked tail lights, Plazma l.E.D White PY27W front turn signal,trunk spoiler, Matt Black roof, 8K D1S HID,Custom Exhaust,!
Soon: JB4,DP,H&R sports,rear diff,! |
04-02-2013, 09:32 AM | #6 | |
Rep 1,209
04-02-2013, 09:58 AM | #7 |
1ST CLASS AWMSPORT
74
Rep 789
Unfortunately it is not plug n play...but it sounds harder that it really is
What we did was from my 07e90' took all my LED bulbs , either broke glass hosing or pulled the led out with the connectors in tact, and just wired thm into te correct wire.
04-02-2013, 09:58 AM | #8 | ||
1ST CLASS AWMSPORT
74
Rep 789
04-02-2013, 10:14 AM | #9 |
Rep 1,209
Im near DC in northern VA.
hmm, well kudos to you for doing it...where are the OEM footwells mounted, or what are they mounted to? Is it just a strip of explosed lights, with wires, or are they on some sort of enclosed casing? If i just got another strip of LEDS can I just splice in?
01-02-2014, 04:45 PM | #10 |
1ST CLASS AWMSPORT
74
Rep 789
I used the original housing.
11-20-2021, 11:18 AM | #13 | |
Rep 1,808
https://www.benzinfabrik.com/de/led-...htung-fuer-bmw |
