04-26-2015, 07:39 PM | #1 |
Rep 383
Drives: F13 M6 | E92 M3 | '15 Mustang
GSR Technik 320i ECU Flash Tune Now Available 75whp/100wtq
Greetings F30 Community!
Some of you may have seen the 2Addicts thread covering the development of our 228i into a Pirelli World Challenge TCA Class racecar. We have a great group of development partners and are excited to start offering new products based on all the development work we have done over the last year or so. Check out the 228i thread: http://www.2addicts.com/forums/showthread.php?t=1117222 We’d like to official announce the launch of a proper ECU flash tune for the 320i achieving approximately 75whp and 100wtq over stock. The dyno graph below is tune only on 91 octane – no other vehicle modifications. This is an ECU flash tune (not piggyback) so it does require access to the ECU. Removal of the ECU is fairly simple – we should have a "how to" video up shortly. For those of you in Southern California – removal, flash and reinstallation of the ECU can be done at our shop in about 1-2 hours. Retail price: Stage 1: $999 Stage 2: $1,499 Last edited by GSR Technik; 05-06-2015 at 05:00 PM.. |
04-26-2015, 09:55 PM | #3 |
Rep 383
04-30-2015, 06:23 PM | #4 |
Rep 74
I'm surprised more people aren't commenting on this. Seems like a pretty big deal seeing as how this is the first flash tune for the n20. Does this tune also work on the n26? Is the ecu actually opened (ie physicallytampered with)or is the the tune somehow plugged into the ecu?
04-30-2015, 07:55 PM | #5 |
Rep 280
You must have missed the last half year or so...
This is certainly not the first ECU tune for the N20, check out - BR Performance (and their partners in the US) - PP Performance - SKN Tuning - Manhart Racing - Jailbreak Tuning - mcchip-dkr etc. And until now the ECU has to be opened or drilled into. |
04-30-2015, 11:34 PM | #6 | |
Rep 383
05-01-2015, 10:34 AM | #7 |
Rep 74
Hmm, if there was major warranty work done, would bmw be able to tell that the ecu was physically opened before? Even assuming the car was re-flashed back to stock specifications, would there still be an indication that something had been done to the ecu?
05-01-2015, 06:38 PM | #8 |
Rep 383
Our process involves opening the ECU and then resealing it so there is literally no visible indication that it was ever opened. No drilling like some tuners do.
05-01-2015, 07:17 PM | #9 |
Assassin
144
Rep 156
Drives: 2013 F30 335i Xdrive M-SPORT
So what exactly is the entire process? I have a 2014 328i xdrive with the N26 engine. How would I get this done ? How does the car remain undetectable to the dealer, is there a switch or something that changes the vehicle back to stock mode when going in for a service?
What kind of results are you seeing with the N26 engine, 328i models? |
05-02-2015, 01:01 AM | #10 | |
Rep 383
http://www.2addicts.com/forums/forumdisplay.php?f=531 So it's not being done through the OBDII port which a lot times has counters on how many times the interface has been used to load something new. It's done by plugging directly into the ECU using tools that are derived from the tools that are used to develop the systems, such companies as Siemens or Bosch. The code in raw state is a bunch of binary so these tools allow you look at the code and make changes to the binary that is interpreted by the embedded systems (hardware/software). There is a checksum that gets calculated from the binary to check to see if any of the binary code has been changed. These checksums need to be recalculated if you make any changes to the binary code - these types of tools allow you to do that. So when dealers are plugging into the cars for general diagnostics they aren't designed to look at the binary directly and say this fuel map has been changed from what is expected. That's at least the basic idea. There are empirical things anyone could do to test like check to see if the car will go faster than the speed limiter or monitoring boost on a dyno to see if boost is exceeding factory specifications but typically dealers are not doing those types of things. The process... You take the ECU you out, here's a video how (below) and send it to us. We flash tune, seal it back up and send it back to you. You reinstall and you are good to go. If you truly want to return your car back to stock you need to resend the ECU to us and we will flash it back to stock. |
05-04-2015, 01:19 PM | #11 |
Rep 1,554
If you tuned the ECU, then why do you have a JB4? Did you move your battery? Mine is on the passenger side rear corner??
05-04-2015, 08:41 PM | #12 |
Rep 368
Where is the link to purchase the product/flash on your website? Couldn't find it. Is there any warranty that comes with the flash? And, this may sound weird, but how would I know if the tune was flashed successfully outside of relying on butt-dyno?
I have JB4 on N20 now and AM SUPER interested since I've been debating Dinan switch. |
05-05-2015, 12:58 AM | #13 | |
Rep 383
The best thing to do to verify results is dyno your car before you send us the ECU and then take the car back to that same dyno and dyno it again with same settings after you get the ECU back. Ideally the weather would be similar on those two days so results will be apples to apples as much as possible. |
05-05-2015, 01:08 AM | #14 | |
Rep 383
No that is the stock location for the battery on our car. |
05-05-2015, 07:13 AM | #15 | |
Rep 1,436
F30 328i - 8 auto.. JB4-EWG harness, OCC, Injen Intake, AFE Scoop, AFE dp, AA axle-back - H&R springs, H&R Rear SB, Front Strut, F&R BMS spacers..
05-05-2015, 07:50 AM | #16 | |
Rep 265
Drives: 2014 328i AW
This is what I'm looking for! Do you have any reliability concerns for the N20, longterm?
MODS: afe intake, afe scoop, afe scorcher module, 19" AG M580's, H&R Sports, AWE Tuning exhaust, LED conversion,wrapped interior, msport steering wheel, msport aero kit
05-05-2015, 07:59 PM | #17 | |
Rep 383
Anyone who says they can predict long-term reliability is full of sh#&. I think our tune is operating within a reasonable performance envelope along with all the factor safeguards that the ECU provides. I feel more confident about our tune compared to what I'm seeing people do with piggyback systems and meth injection. Of course if you drive like knucklehead every moment you are behind the wheel long-term reliability is going to suffer no matter what. |
05-05-2015, 08:47 PM | #18 |
Rep 383
05-06-2015, 02:28 PM | #19 |
IG @bmwF9xG80
3813
Rep 7,593
rustyminded best of both worlds man GSR and Jailbreak are both wonderful very responsive and helpful teams, i have not yet met such tuners caring for us N20/N55 everyone else is concentrated mostly on the M's lol.
60-130mph 6.5s X4M #HCP
05-06-2015, 06:28 PM | #20 |
Rep 265
One more question, will all of my feature coding (dvd in motion, sport +mode etc) be erased/overwritten?
My ECU has been removed and is enroute to GSR for tuning!
05-07-2015, 12:24 AM | #21 |
Rep 23
Interested. couple of questions
1) For the 320i what is the stage 1 and Stage 2 difference? 2) Also the dyno chart shows 228i and I don't see the 75whp and 100wtq increase. Maybe it is not the right graph? I do like that this is done with 91 oct about 95RON which is my local pump gas oct. |
05-07-2015, 12:45 AM | #22 | |
Rep 383
The +75whp and +100wtq is for the 320i since it's basically a detuned 228i/328i so there is way more headroom we can take advantage of. |
