01-27-2018, 01:05 PM | #155 | |
Rep 740
507 is for rear pdc only and 508 is for front and rear. You can't have both 507 and 508 vo.
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
01-31-2018, 01:43 AM | #156 |
Rep 4
01-31-2018, 07:55 AM | #157 | ||
Rep 740
01-31-2018, 12:02 PM | #158 |
Rep 4
01-31-2018, 02:11 PM | #159 |
Rep 740
Did you VO code the REM, ICM, and HU_NBT/HU_CIC? Sounds like you didn't code the ICM maybe?
02-22-2018, 02:19 PM | #160 | |
Rep 35
03-08-2018, 12:51 AM | #163 |
Rep 1
PDC not work
Hello
I have wired and coded everything, but i get the error: 0x803232 PDC Sensor programming faulty All sensors in the front have the self error, someone had that already? Thank you for help. |
03-16-2018, 08:02 AM | #164 |
Rep 6
Hi chaps,
I have rear PDC only on my 2017 f31, and want to disable PDC when reversing with trailer. Someone mentioned in this thread, no coding required, for the PDC button. What is the part number for the PDC wire, to ICM? Any pics of you routing the wire? And the plug goes into the ICM? and you put the 2 wires in the correct pins on the existing loom plug, for the console PDC switch side? Last edited by 2ippy; 03-16-2018 at 08:19 AM.. |
03-16-2018, 04:36 PM | #169 |
Rep 2,302
OK, I just searched the internet and found out that if you install the retrofit kit from Westfalia, it will not shut off the PDC.
And then you can not code that either. So like your first idea you need the PDC button. The problem is that this cable does not exist singly, but only together with the entire retrofit harness. Maybe someone can find out the individual part numbers for the plug and socket contacts. I will also try to find out the part numbers The plug then will be plugged into the PDC button and the 2 wires into the ICM. wire green/yellow Pin 28 wire yellow/blue Pin 6 |
03-16-2018, 04:54 PM | #171 |
Rep 2,302
Ah yes, i just saw that it is only one plug.
So you only need the pins and wires. You also then need a new/used operating unit centre console 61319252912. Here a picture https://www.ecstuning.com/b-genuine-...t/61319252912/ Only for example. You can buy it used on Ebay. |
04-05-2018, 03:29 AM | #174 |
Rep 72
I am making my own Front PDC retrofit wiring harness. Can someone confirm the color coding for "Cable Set Front bumper 61129260019" and cable in "Install.kit, Park Distance Control,front 66202338070" are the same?
04-24-2018, 04:26 PM | #175 |
Rep 941
If anyone is looking for parts for a front and rear retrofit hit me up.
I have all the original brand new BMW parts never installed as well as 8 PDC sensors (Silverstone II) and front and rear harness. Also have the REM module with correct pinout. Never got around to installing it. Thanks
2019 M4CS Lime Rock Grey, MP HAS, GC camber plates, MPE
05-22-2018, 12:52 AM | #176 |
Rep 4
Hey!
I'm having some issues with the coding. i get the error: Transaktions-Report: Aktion: Codieren Abort! Failed to code the CAF "CAFD_000007A1_005_044_005" of "REM--72", because it is not present in the STV actual. [C250] Any suggestions? Don't know if it matters, but i'm currently running E-sys 3.27.1 and PSdZData_v.4.11.20_Lite |
