BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > F80 M3 controls arms install questions
proTUNING Freaks
      10-26-2018, 10:23 AM   #45
Relax19
Drives: car
Originally Posted by MacklinUSOB View Post
Thanks.
My camber could have been a little more aggressive, but I also had my suspension raised up a good bit while they did this install. I've read that you should expect between -.8 to -1 increase with the arms. I lost about -.2 off my pre-LCA alignment to the height increase.
To get into -2 territory you'll need either camber plates or a combination of F80 LCA and the F30 -.5 correction hub.
Bollocks. Thanks! I'll take what I can get. It's so frustrating that the F30 drives like a Camry, it needs camber from the factory. It's just understeer central without it
I don't want to do plates on my DD, I already have them on my track prep'd m3 and the NVH would drive me up the wall.
      10-26-2018, 10:50 AM   #46
MacklinUSOB
Drives: f30 328i 6MT Sport
Thanks.
No problem. I agree with you there, my car was so quick to understeer while stock. Between the over-stiff run flats, lack of steering feel, and non-existent camber it was not confidence inspiring on tight and twisty roads, and just awful at AutoX. It really comes alive with proper tires and camber.
I definitely wouldn't want them on mine either. Having ridden in cars with them before I knew they were not for me.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines |
Past: E36 328is & E38 740i
Polo088161614.50
      10-30-2018, 08:28 PM   #47
Bryan_KiesMotorsports
391
Drives: 2013 BMW 335i xdrive
Originally Posted by BMW DIY Guy View Post
Hey yall:
I am definitely considering this, well correction, considering this depending on cost as my budget as always is super constrainted.
F80
What do you guys think of this? Anyone done the same?
Outstanding questions I have at this point.
1. arm part numbers
right - 31122284530 - $208
left - 31122284529 $208
2. headlight control rod part number -
Whole kit including arms and control rod - $386
https://www.ecstuning.com/b-genuine-...31122284529kt/
3. proper torque - ???
Worth it?
Thanks for sharing the video, much appreciated
If anyone wants the control arms, I haven't sold them yet. They only have about a quarter mile of driving on them lol.
Not that it was challenged, but before I did it I talked to Turner and also FCP euro and neither thought there would be any problem with the xdrive, but I hope my little mishap saves others from having the same issue. For those who have done it on RWD, I've heard great things!
Bryan
Polo088161614.50
      10-30-2018, 08:30 PM   #48
391
I appreciate the info.. interesting those are needed too? Wonder if there is real benefit from doing this?
yeowtch!
I'm a fan of bkkeys so seeing this sucks. Gotta be honest though, I did chuckle at the vid a little bit, in a sympathetic, nervous laugh kinda way. He seems in fairly good spirits and definitely toftt!
https://www.youtube.com/watch?v=iL_Xgl-Hb-s
Lol. Gotta pay to play as they say! Thanks for checking us out, we appreciate it
      10-31-2018, 12:22 AM   #49
BMW DIY Guy
BMW DIY Guy's Avatar
Drives: 2019 M2 Competition
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
Hey yall:
F80
1. arm part numbers
Worth it?
Bryan
SORELY tempted to take these off your hands.. dang it.. one project at a time..
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy **
'Nimona' G87 M2 Build Thread
'Lillith' F87 M2 Competition Build Thread
      10-31-2018, 03:35 AM   #50
N420i
Drives: 2016 420i lightly modded
Bryan
Would you consider shipping internationally? Nowhere particularly exotic, just Spain, regular USPS would do.
If so shoot me a PM with pricing please, I'm interested in acquiring a pair of these.
      10-31-2018, 12:03 PM   #51
teapain
Drives: 2016 340i XDrive
I just did this bc I needed new control arms but I wouldn't have otherwise. My car with 19X8 front wheels + 10mm spacers + Dinan Springs now rubs during hard cornering.
2016 340i XDrive: Bootmod3. And stuff.
      10-31-2018, 08:51 PM   #52
kern417
Cheapskate
4457
Drives: 2018 440i |2016 340i | 2010 X5
so just to confirm, there's no way to fix the increased caster and get the wheels back center?
Youtube/Instagram/TikTok: @kern417
      10-31-2018, 09:29 PM   #53
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Other than the actual LCA's -
Are there are any other required or recommended parts or hardware that should be installed when fitting to an F30 ?
Can someone confirm R and L part numbers?
      11-04-2018, 09:49 PM   #54
Nugget
Nugget's Avatar
650
Drives: G81 M3 Touring, GR Supra GTS
2011 BMW 135i  [10.00]
I need to do this on my F30, does anyone know if the spacers are necessary for the F30? Or was that just needed on the F22? I'm planning on doing both Control Arms and Thrust Arms as the the F30 out of the box handles like trash and seriously needs camber up front.
You can either
-use spacers
-press a F30 bush into the F80 control arm
-wait for the control arm kit super pro is going to release early 2019 that is supposed to be plug and play.
      11-04-2018, 09:59 PM   #55
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
You can either
-use spacers
where is this kit coming from?
      11-05-2018, 01:59 AM   #56
Nugget
Nugget's Avatar
650
https://superpro.com.au/
      11-06-2018, 12:00 PM   #57
Sweeney921
Sweeney921's Avatar
98
Drives: 2000 BMW E39 M5
Is there a page discussing their LCA development or did you find out about it via email, calls, etc.? Also any word on if their kit will be compatible with xDrive?
2017 BMW 330i Sport Wagon - M-sport, EBII, THP, DHP
Supersprint cat-back exhaust (resonated, dual outlet) - H&R rear sway bar - ER charge pipe
Waiting for: Bootmod3 - xHP Flashtool - xDelete
      11-06-2018, 07:07 PM   #58
Nugget
Nugget's Avatar
650
It was in an Australian M-lite facebook group.
Not sure about x drive as we don't get them in Australia.
      06-09-2019, 08:29 PM   #59
nyc_dude
nyc_dude's Avatar
Drives: 09 //M3 e90 Interlagos Blue
F80 M3 Lower Control Arm Kits
There are several kits for this mod. Need a shop with an alignment rack.
<<<NOT COMPATIBLE WITH XDRIVE>>>
FCP Euro has all the P/Ns and hardware
https://www.fcpeuro.com/products/bmw...QaAuHQEALw_wcB
ECS Tuning: 2 LCA + Headlight Level Bracket
ECS Tuning: TRW Full Kit
https://www.ecstuning.com/b-trw-part...7142283867ekt/
ECS Tuning: BMW OEM Full Kit
https://www.ecstuning.com/b-genuine-...7142283867gkt/
GetBMWParts probably has the best prices
Cheers
sspade2468.50
      06-09-2019, 08:39 PM   #60
Polo08816
Drives: 2014 335i M Sport
Cheers
You can take the toe measurements with toe plates before modifying the car. And then after you install one side with M3 LCAs, get your toe back into spec. then install M3 LCAs on the other side and do the same.
We did this and were within 0 degrees and 4 minutes off from the factory spec. It allowed us to drive 30 minutes to the alignment shot.
      06-10-2019, 09:20 AM   #61
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
Absolutely NOT compatible with Xdrive, and seen what happens when you try.. its bad.
      06-10-2019, 11:40 AM   #62
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
Cheers
Thanks man.. fantastic references for sure. I am still trying to figure out if this is worth doing, granted the prices are pretty reasonable all things considered and also watched the DIYs on how to do it. My only concern would be reinstalling properly to then get it to an alignment shop to finish the work.
*ponder* Maybe adding this to my bucket list of To Dos. Side note, using the parts list it looks like $408 from GetBMWParts
      06-15-2019, 10:08 PM   #63
SilkySmoooth
Drives: '13 335i MSPORT Estoril Blue
Please try it! Do it for all of us who are wondering!!
      06-21-2019, 08:57 PM   #64
JMK007
Drives: 335 M Sport, RWD
Having just switched back to anF30 after several years in other car makes, I was really excited to learn about this alternative to camber plates. So I jumped in (apparently too quickly) and got a “kit” from a highly reputable vendor that sells both the F80 LCAs and tension struts as a plug and play for the F30. Well, the installer and I just learned tonight the F80 tension struts definitely don’t fit the F30. I wish I read this post earlier, notwithstanding the vendors assurances to me everything fits. Does anyone know where I can get spacers that will allow the tension struts to fit? I also saw some reference to trying to to push the larger F30 bushing into the tension strut of the F80. Based on bushing housing for the F80 v. F30, I don’t see how this would work right. Has anyone successfully done this?
SCCA & Midwestern Council W2W, '91 Spec Miata, '07
NASA TTD Champion, Midwest, '99 M3, '09
Midwstrn Council TT Champion, BS, '10 GTI, '10 &'11
Midwestern Council TT Champion, BS, ‘17 BRZ, ‘19
      06-24-2019, 05:09 AM   #65
Polo08816
Read this thread:
https://f30.bimmerpost.com/forums/sh...1090804&page=7
I used the spacers linked by MacklinUSOB .
      06-25-2019, 08:27 PM   #66
JMK007
Thanks!
