BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding the steering
proTUNING Freaks
      08-08-2013, 10:25 AM   #23
dinonz
Drives: 2016 M3 MWM ZCP
Originally Posted by dirksterzel View Post
Sadly the entries are not always complete words but often some codes that probably only the BMW engineer who invented them understands
I figured as much. If I had a very large indoor garage I would just try a few and see what it does
      08-30-2013, 02:41 PM   #24
t335xi
Drives: 2013 335xi Sedan Sprt Line ppk
SO it sounds like you figured out how to code steering?
      09-25-2013, 01:06 PM   #25
coolnesh
Drives: 2019 X3 m40
Has anyone figured out if this is possible?
Can the steering be coded to be stiffer (like how it feels in sport or sport+) but in comfort on a non DHP?
      09-25-2013, 01:21 PM   #26
f30coyote
Drives: 2013 335iX
Yes it is. I coded the sport mode configuration pop up as JesseSrq said in a previous post. I do not have DHP and now I can separate chassis and drivetrain in sport mode. All I do now is put in on sport during hwy driving and I get the stiffer steering without the shift points. Best "mod" you can make!
335iX M-Sport | Estoril Blue II | Black Dakota | Aluminum Hex | Premium | Cold Weather | Technology | 403M Wheels | 8SPAT w/paddles | Blacked Out Kidney Grills | Rear Spoiler
      09-25-2013, 09:06 PM   #27
shag
pullin a boat
shag's Avatar
Drives: 2021 X3 M40i
Whoa. Nice going!!!
2021 X3 M40i, Phytonic/Cognac
Past:
2017 330i xDrive Touring M Sport, EBII, Dinan
2014 328d xDrive Touring M Sport, BSM/CR.
      09-26-2013, 02:24 PM   #28
coolnesh
Drives: 2019 X3 m40
Good to know and thanks for the info.
But I am assuming the "mod" would only be possible in the Sport mode - invariably you would be loosing the the Sport Throttling and keeping just the chassis/steering firmness. And that this would not be a configurable mod in the comfort mode?
      09-26-2013, 06:54 PM   #29
f30coyote
Drives: 2013 335iX
Correct - only in sport mode. But, all you have to do then to get the shift points too is either select sport + or move your shift lever to the left while in sport. Seems the same to me.
      09-26-2013, 09:41 PM   #30
JamesMA
JamesMA's Avatar
81
Drives: 2018 F80 ZCP
Cool and I see you are local. I have DHP and really find the only thing I would change on the car is the steering. I know they will not got back to hydrolic, but it would be nice if they would release an optional patch - like the ASS save last setting - for those who want it, which would give me the sport steering feel in comfort and something more in Sport/ Sport+.
I mean the fat that the steering changes at all says it can be done. I am going to pester my dealer some more.
2023 G80 ///M3x Comp. BSM on Black M Brakes
Gone: 2018 F80 ///M3 ZCP 6 MT, 2013 F30 335i 6MT M-Sport
      11-11-2013, 04:17 PM   #31
shag
pullin a boat
shag's Avatar
Can you change the shift points using iDrive? e.g. I want the stiffer steering wheel but sometimes I still want the tighter shift points.
My understanding is that Sport mode does alter the shift points but it doesn't shift as fast as when it's in S. It really felt like the transmission was acting like an SSG transmission when in S-mode - shifting was pretty quick/hard. I did not experience that in D in Sport mode, but I did notice the higher shifting points.
Past:
      11-11-2013, 07:20 PM   #32
f30coyote
Drives: 2013 335iX
Honestly not sure. I like the setup I have now with the sport mode only changing the chassis and using shifter in S when I want spirited driving.
      12-25-2013, 12:09 PM   #33
endless402
endless402's Avatar
Drives: F31 EBII
How was that done?
      01-18-2014, 03:11 PM   #34
drexplode
drexplode's Avatar
1782
Drives: G26 i4x
Originally Posted by endless402 View Post
How was that done?
also interested in step-by-step instructions
      02-16-2014, 07:41 PM   #35
c40oz
Drives: 2013 335i Xdrive M-Sport
How were you able to re-code that? Any instruction or link would be much appreciated! I've been relying on turning off all nannys to get stiffer chassis and steering feel while leaving the comfort throttle mapping for a less volatile throttle input. This also activates the eLSD. But I like your option for the sport mode for daily driving.
      02-16-2014, 09:17 PM   #36
f30coyote
Drives: 2013 335iX
This is how you code to configure sport mode.
Originally Posted by JesseSRQ View Post
I think I answered my own question last night. After coding Macro_fds to the value popup_and_config, I have the option to configure the Sport mode to include chassis and/or powertrain settings. When I select chassis only, the steering is set to the stiffer Sport mode but the throttle response and transmission behavior remain in the Comfort settings. This is great for highway driving where I want to be in 8th gear and have less float to the steering.
      02-17-2014, 12:53 AM   #37
c40oz
Nevermind! Was looking for a from start to finish tutorial on how and what you need to do it.
      02-17-2014, 12:55 PM   #38
carzaddict
Drives: 2015 Cadillac Escalade ESV
There is a way to activate the "Sports" setting via coding on iDrive.
once you enable it, through iDrive you can control what you want to change when you put the car in Sport mode. You can either select Drivetrain only (gas pedal).....Chassis only (steering).....or both.
ive done this to my car and confirmed it works...ill take a screenshot later
2015i Cadillac Escalade ESV
      02-17-2014, 03:18 PM   #39
ScarecrowBoat
Zooombie attaaack!!
ScarecrowBoat's Avatar
Drives: 328
Same...
      03-09-2014, 10:17 PM   #40
shag
pullin a boat
shag's Avatar
Hmm. I tried coding this today, the menu shows up, but any attempt to select Drivetrain only or Chassis only fails - the checkmark stays on Drivetrain & Chassis. But I've got NBT navigation, you seem to have HU_CIC... that might be it. Too bad...
So it works for HU_CIC cars but not HU_NBT cars... unless I can find another coding option to fix this.
Past:
      09-17-2018, 10:36 AM   #41
TufftyUK
Drives: 2018 335dxM Shaddow
Did we ever get a conclusive answer to this? I want the opposite result, light steering in Sport+
By using the iDrive menu I can change from light to heavy in Sport but Sport+ is always heavy.
A lot of what is described earlier in this post is not coding it's just iDrive set-up!
