Bimmerpost for iPhone and Android have just been updated with a host of bug fixes. If you've ever had trouble logging into it in the past, give it a try now!
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Car pulling to the left, burning smell from left
VIBE Motorsports
      11-01-2016, 01:56 PM   #1
dbramley
320d M-Sport
England
51
Drives: BMW 320si
Drove to work fine this morning fine. Driving home I notice a strong pull to the left, no clunks over speed bumps or anything like that.
Park up but too dark to see anything, I do however notice a burning smell coming from the front left wheel, right one smells fine.
Any ideas to what this could be please?
Previous: BMW 320si E90 Le Mans Blue. | BMW 320d E92 LCI Alpine White | F10 520d Alpine White
Now: F30 320d X-Drive Alpine White
      11-01-2016, 02:03 PM   #2
Gixerste
Gixerste's Avatar
Drives: F30 340i m sport MPPSK
Is your wheel hot, sounds like it could be a seized caliper
      11-01-2016, 02:55 PM   #3
dbramley
320d M-Sport
England
51
Drives: BMW 320si
Thanks, will pop it into my local back street garage near work tomorrow to check.
I've got the M-Sport brake upgrade I take it they are covered by the warranty if the calliper is screwed?
      11-01-2016, 03:30 PM   #4
dbramley
320d M-Sport
England
51
Drives: BMW 320si
Actually thinking about it now I've had the front brakes creaking for a while now, low speeds just easing off the brakes, wonder if it's related?
Creaks not squeaks...
      11-01-2016, 03:43 PM   #5
Watsey
In the meantime you could take the car out for a spirited run and do several hard stops on the brakes from decent speeds i.e. 60-80mph. Obviously pick a quiet road and be ready to manage any increased pull to the left.
If you normally have a gentle braking style calipers can get sticky. Some hard stops may help to loosen things off.
Current : F31 330sD, DMS remap, Ohlins Road & Track, Vorshlag adjustable top mounts, SuperPro front caster adjustable bushes, Bird's ARBs, MPSS, Quaife LSD, StopTech BBK.
Previous : E91 330D M Sport; E91 330D SE; E46 320D M Sport Touring; E46 330D M Sport Saloon
      11-02-2016, 03:11 PM   #6
Ashway
Ashway's Avatar
84
Drives: F15 x5///M50d/AM Vanquish
Could also be a seized wheel bearing
      11-03-2016, 08:25 AM   #7
BrennanF30
BMWLad
BrennanF30's Avatar
Ireland
772
Drives: F30 M Sport
BMW F30 M Sport  [0.00]
Definitely sounds like a seized caliper, had the very same issue on one of my Audis
EBII F30 with M Performance Kit, Ispiri ISR8 wheels
Originally Posted by 6times7 View Post
I don't know - BrennanF30 is Irish isn't he? I reckon he's got some super hi def, Ultra HD4K F30 photo taking potato
      11-03-2016, 12:41 PM   #8
fat dog
fat dog's Avatar
England
Drives: 435d Gran Coupe
I'm also guessing sticky caliper. If you take the car for a gentle drive (avoiding using the brakes as much as possible) park up and if the disc is hot then it would point to the caliper sticking on.
I would avoid any hard driving or braking, not just on safety grounds but you don't want to overheat the disc which could cause it to warp.
If the car is still under warranty, whatever this turns out to be should be covered.
