01-02-2019, 08:10 PM | #1 |
Rep 30
Smog-safe mods in California
I've searched through the regional forum a bit, but I'm still not clear which modifications (exhaust, intake, etc.) that are generally smog safe here in California. I recently picked up a 2016 340i, so I've got a little bit of time before I have to deal with it, but I don't want to do anything that will potentially cause issues that will trigger a fail.
Can someone lend a hand with breaking down which parts are generally non-issues when it comes to smog? For instance, a full catback exhaust, such as AWE, is noted as "track only" on their website, but I know manufactures need to cover themselves with disclaimers. It looks like most all downpipes are a problem, but it's all a little mystifying to me. Thanks for any tips! |
01-02-2019, 10:14 PM | #2 |
Rep 3,748
Here we go again. Its california... all parts need to have carb OE # to be exempted. Axle back exhaust is ok but if you have a mid pipe replace the secondary catalytic converter (if your car has one) then means illegal.
So what a lot of people do if they keep the car pass 5 years old.. is to mod it...then put back the original stock when smog comes. OR pay someone off |
01-02-2019, 11:46 PM | #3 |
Rep 2,499
Anything with an Executive Order (EO) has been validated to be legal to use in California. This can include tunes, full exhaust, turbos. If it's an emissions related component without an EO, it's illegal. You pretty much can't touch the catalytic converter. It's definitely possible to pass the smog test with a downpipe, though it's still illegal. You can upgrade to a Pure Stage 1 or 2 turbo as those look stock and would be virtually impossible to catch on a smog test.
Things like intercoolers, charge pipes, and intakes are fine to upgrade. The intake is really not worth changing though, unless you want a visual mod. |
RubberBandMan10.50 |
01-03-2019, 01:45 AM | #4 | |
Rep 5,776
01-03-2019, 09:29 AM | #5 |
Rep 3,748
01-03-2019, 11:34 AM | #6 |
Rep 1,827
To my knowledge, CARB certification and smog checks are two different things. I don't think smog shops are doing CARB inspections. That said, you can be "illegal" (non-CARB approved parts) and still pass a smog test.
I've heard stories about people getting snagged for a CARB inspection, but I've never seen it firsthand. IMO, if your car looks fairly stock, isn't shaking windows when you drive by, or isn't blowing black smoke, you should be fine. That's said, catback is fine, won't throw codes. Same goes for FMIC. There have been a few users reporting codes from certain intakes, but really, the stock system is more than capable. CAIs don't really add much besides sound and engine bay decoration. And I assume an aftermarket catted dp MAY still pass smog as long as it doesn't throw any monitor codes.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
01-03-2019, 01:07 PM | #8 |
#gotboost
517
Rep 861
A lot of muffler shops will charge $200 - $300 to pass your smog test....just saying.
2018 F87 M2 (09/2020 - )
Dinan Cold Air Intake |Dinan Axle Back | VRSF 6.5" Intercooler | VRSF Catless Downpipe | VRSF Charge Pipes | BM3 | MST Inlet v2 | Turbosmart VR11 2013 F30 328i (12/2015 - 09/2020) SOLD! |
01-07-2019, 07:11 PM | #9 | ||
Masterchief
364
Rep 1,015
California AB1274!
AWE Non-Res Touring | TE37 SL PW | Ohlins RT |
01-07-2019, 08:02 PM | #10 |
Rep 3,748
01-07-2019, 09:50 PM | #11 | |||
Rep 1,827
01-08-2019, 10:31 AM | #12 | |
Masterchief
364
Rep 1,015
based on the new law i think we are good until 2021!
MONSTAR517.00 |
01-08-2019, 11:45 AM | #13 | |
#gotboost
517
Rep 861
Probably wont even have the car anymore in 2021 lol
yoon_209363.50 |
01-08-2019, 11:47 AM | #14 | |
Masterchief
364
Rep 1,015
01-09-2019, 10:43 AM | #15 |
Rep 5,776
Yeah, I saw that. Great news--as I thought I had to do the DP swap this year.
Last car: 2011 335i Msport. JB4. Vrsf CP |
01-14-2019, 10:22 PM | #18 | |
Rep 30
