11-14-2013, 09:05 PM | #45 |
Rep 284
Drives: F30 335i EBII MPPK/BBK
Garage List 1999 Honda CR-V [0.00]
2013 BMW 335i [0.00] 1986 BMW 325e [0.00] 2014 Porsche 991 Ca ... [0.00] 2018 Audi SQ5 [0.00] 1971 Volkswagen Sup ... [0.00] |
Frogman, next weekend along with some minor coding, can you verify for me the Plant Integration level of my car? It is accessed by 'performing a Key Read and selecting Vehicle Key Data, then Software Integration' (quote from PPK press release). My car is a July '13 South Africa build and I need this data to determine which Performance Power Kit to order. Thanks in advance, David
11-15-2013, 03:19 PM | #46 |
Rep 13
I won't be needing coding anymore. I bought the cable and software and did the coding myself already. I will bring my cable and laptop to help other coding.
11-15-2013, 03:23 PM | #47 |
Rep 1,170
Dude, thanks so much Jimmy!! I'm sure Tom will appreciate it very much that we'll have a second coder.
Updated list so far. Add yourself if you're coming! Date: November 24nd, 2013 Time: 9:00 AM Location: LA Zoo (4701 Zoo Dr Los Angeles, CA 90027 (NE parking lot)) Coding 1. Frogman 2. jimmyktf Getting coded 1. Arktctr- Maybe 2. Forgiven- Coming 3. Presario- Coming 4. lukster- Coming 5. daberlin- Coming 6. estoril335- Coming 7. Jchan112- Maybe 8. LAwolverine- Coming 9. Cavm335i- Coming 10. Bowser330 - Maybe 11. biguk997 - Coming 12. 13. 14. Hang out crew 1. izzyM3- Coming 2. Hansolo1019- Coming 3. Sedan_Clan- Coming 4. JNLBC- Maybe 5. 6. 7. 8.
F36 435i * MINERAL GREY * ///M Performance | G01 X3 * PHYTONIC BLUE * ///M40i
11-15-2013, 03:24 PM | #48 | |
Rep 13
Remove initial seat belt warning. (3 gong when engine start) Display digital current speed in instrument cluster. Enable sport mode configuration. (chassis & drivetrain, chassis, drivetrain) Display S1-S8 in DS mode. |
11-15-2013, 03:28 PM | #49 | |
Law Enforcer
25117
Rep 22,290
Drives: '22 Chalk Gray Porsche C2S
That's the one that I want you or Tom to activate on mine. How exactly does it work and how is it reflected in iDrive? |
11-15-2013, 03:43 PM | #50 | |
Rep 13
It will also show up when you change to sport mode. (Very similar to ECO-Pro setting) Drivetrain: aggressive shifting points Chassis: tighter steering Originally when you change to sport mode, it will tighter steering and change shifting point, now you can choose only tighter steering by selecting Chassis. |
11-15-2013, 03:57 PM | #51 | |
Law Enforcer
25117
Rep 22,290
11-15-2013, 04:13 PM | #52 | |
Rep 13
I like to drive in "Chassis-Only sport mode" and whenever I want to sport throttle, I just change my gear to DS. I don't have any photo right now, so I attach some image I found on google. They looks exactly the same. |
11-15-2013, 04:18 PM | #53 | |
Law Enforcer
25117
Rep 22,290
Thanks for those photos. That is exactly what I needed to know. So since Sport can be configured, I assume that Sport+ retains the OEM chassis/drivetrain/limited DSC configuration specs right (..or does the configuration affect Sport+ as well)!??! I'm looking forward to having this coded on the 24th. This alludes to lots of adjustment possibilities where the F8X M3 is concerned. |
11-15-2013, 04:21 PM | #54 | |
Rep 13
11-15-2013, 05:53 PM | #56 | |
Rep 808
11-15-2013, 09:36 PM | #58 |
Rep 401
11-15-2013, 11:21 PM | #59 | |
Rep 1,892
I'm the procedure from the PPK press release may be referencing using ISTA/P and that would be a different procedure, but may be the same value. Do you have an example of what an Plant Integration Level value looks like? |
11-15-2013, 11:24 PM | #60 | |
Rep 1,892
If there is anyone else out there in SoCal that can attend and help with coding, it would be greatly appreciated!! |
11-15-2013, 11:28 PM | #61 | |
Rep 1,892
It's meant to be able to control the adjustable damping on cars with DHP. My car does not have that, but enabling the mode does let you control what you indicated (throttle sensitivity/shift points), and Chassis (steering, and damping if you have DHP). |
11-15-2013, 11:37 PM | #62 | |
Rep 1,892
S1-S8 normally only shows up when you are manually shifting the 8AT. There's nothing to code to enable that. Are you saying that you are enabling the S1-S8 without being in MS mode? If so, can you send me the the ECU / section / variable to enable this and I'll add this to my list! Thanks! |
11-17-2013, 12:17 AM | #64 | |
Rep 13
After doing the coding it actually show S1-S8 in DS mode so you know which gear you are current on. I believe this default if you have shift paddles option. EGS 3000 Applikation Sportschalter_alt change to aktiv EGS 3000 Applikation Sportschalter change to aktiv |
11-17-2013, 12:24 AM | #65 | |
Rep 808
11-17-2013, 12:42 AM | #66 |
Rep 13
