02-21-2013, 10:46 AM | #1 |
Rep 2,937
Drives: 2013 Estoril 328i M Sport
Will the 335i M Performance Diffuser & Exhaust fit the 328i M Sport?
Searched and didn't find anything specifically about this.
My only gripe with the M Sport 328i I have on order is the dual, single-sided exhaust tips. The 335i Performance diffuser and exhaust look fantastic, so I'm wondering: 1. Will the 335i Performance Diffuser fit the M Sport 328i? 2. Will the 335i Performance Exhaust fit the M Sport 328i? 3. If the 335i Performance Diffuser does fit the M Sport 328i, would the stock 328i M Sport Diffuser fit non-M Sport cars so I can sell it? |
02-21-2013, 10:48 AM | #2 |
[Versatile]
378
Rep 1,683
You live in LA, you have access directly to LTMW/LTBMW. They can make anything happen. Its safe to say if you want dual exhausts w/ the diffuser on your 328i, you're going to get it.
'02 TS E46 330xi - SOLD
'06 SGM E90 325i - SOLD '13 AW F30 335i ///M-Sport 6MT. OEM(+) - SOLD '20 AW F87 X3MC - Sold Current: `23 Chalk G80 M3CX | Ordered: '24 M3CS - Week37 build. |
02-21-2013, 10:50 AM | #3 |
Rep 2,937
I'll clarify: can it happen without modifying anything, i.e. a direct swap of the exhaust and diffuser? Or is the exhaust compartment shaped differently between the two models?
02-21-2013, 11:42 AM | #4 |
Rep 2,937
The 328i and 335i both share the same trunk floor ("2", part #41007284335):
And they share the same heat shield ("10", part #51487321619): So with this in mind, I'm guessing the exhausts are interchangeable? |
02-21-2013, 12:27 PM | #5 |
Rep 2,937
I think the issue comes down to part "1" in both the 335i and 328i, and how the pipe connects to the mufflers:
328i: 335i: |
02-21-2013, 12:30 PM | #6 |
Rep 411
Even if you swapped out everything, it looks like Part #2 won't match.
johnsedlak.com - web developer, designer
02-21-2013, 12:42 PM | #7 |
Rep 2,937
335i M Performance (clamp part "2" is 80mm):
328i M Performance (clamp part "3" is 75mm): |
02-21-2013, 01:20 PM | #8 |
Rep 2,937
02-21-2013, 01:31 PM | #9 |
Rep 411
The post above mine shows it wouldn't fit. The angle on the long tubing (#2) isn't the same. I'm guessing the downpipes aren't in the exact same spot with the exact same angle and that changes the exhaust just enough that they aren't interchangeable.
It wouldn't be "too hard" to get something that works, but I'm betting it won't be a perfect drop in replacement.
02-21-2013, 01:36 PM | #10 | |
Rep 2,937
I noticed the angling too, on the 335 it's almost straight, whereas the 328 is more curved. What might work is getting a 335 "2" pipe, cutting it off and welding it to a 328 pipe and connecting that to a 335 Exhaust. |
02-21-2013, 01:45 PM | #11 |
Rep 2,937
Another issue would be sound; I'm wondering if the internals of the 335 exhaust are strictly designed around the sound characteristics of the N55 and wouldn't cooperate well with the 328.
02-21-2013, 06:59 PM | #12 | |
Too much is never enough
655
Rep 3,079
It's not a big deal to make it fit. Any shop can get it done with very little effort. It's just tubing. |
