BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > [TUTORIAL]Retrofit rear lights BMW F30/F31/F80 LCI
      11-07-2019, 02:05 AM   #133
david51
david51's Avatar
France
538
Drives: bmw M3 F80
use the original connectors bmw or other model to connect the red wire and the green wire
to dismount the plug it is necessary to spread the small lamella at the same time and to leave the connector
      11-07-2019, 09:59 AM   #134
623baller
Drives: 2015 F80
got it! didnt know both side had to be spread to release it haha i was only spreading 1 side
will give this a go this weekend and report back, thanks again David!
      11-07-2019, 11:53 AM   #135
david51
david51's Avatar
France
538
Drives: bmw M3 F80
      11-09-2019, 04:13 PM   #136
623baller
Drives: 2015 F80
i tapped the right side , inner light came up now! will finish up on left side. i did not actually take the retro wire (red) out of pin 22 on 14b. i cut the wire taped it up and then scotchlok tap to 14b pin 12 blk/gray wire
i actually closed my trunk with battery disconnected by mistake, had to jump the car to reopen the trunk lol.... leaving this out here for other people try to do this to not close your trunk when your battery is disconnected. that was a good scare.
      11-18-2019, 09:53 PM   #137
david51
david51's Avatar
France
538
Drives: bmw M3 F80
      01-17-2020, 04:58 AM   #138
brtttt
Ü
brtttt's Avatar
Drives: F31
First thanks David for taking the time to help others and also everyone whos contributed.
Can I ask when it comes to the Retro wiring cable , Ive seen 2 types and wondering if the bottom type would be easier to install and tap into the oem wiring loom according to this link
https://f80.bimmerpost.com/forums/sh....php?t=1180839
Just can't seem to find the orange & blue cables shown at the bottom in the uk for a F31
Top looks like you need to wire it back to the REM ,
Bottom looks like you just run it from the inners back to the outter wiring loom and connect up.
      01-18-2020, 04:37 AM   #139
david51
david51's Avatar
France
538
Drives: bmw M3 F80
hello thank you
on ebay you can ask this seller
https://www.ebay.fr/itm/273867988666
brtttt75.50
      01-20-2020, 02:02 AM   #140
brtttt
Ü
brtttt's Avatar
Drives: F31
thanks for the link David.
Does anyone know what thickness/guage wire is needed. Going off previous F31 installs it looks like I may need to extend the over lengths.
Hoping to just code these in with just bimmercode, unsure if others have done the same if its possible to just disable the bulb warm up checks.
Thanks
      01-30-2020, 09:45 PM   #141
dexterdpc
dexterdpc's Avatar
Drives: '14 328d F30 Luxury Line
Installed LCI and Coded with Bimmercode - no wire tap needed
Hey guys - I have a 2014 US 328d with old CIC. Just finished the LCI blackline upgrade and if you follow BMW's instructions on their wiring harness part 61122410220 (I recommend their part), and code with Bimmercode, no wire tap is needed to get the inner blinkers working if you code it per the below.
Attached are my pics installed. (Rear fog lights work too. Too much light for the picture - see other places on bimmerpost to get those operating).
Here is the coding that works so you can plug the new trunk lid harness wires into the car wiring:
REM > 3061 LceOutputChannels > BFD_L_CCM = ccm_blinker_l
REM > 3061 LceOutputChannels > BFD_L_IS_LED = aktiv
REM > 3061 LceOutputChannels > BFD_L_UE_SPG_SCHUTZ = dimmed
REM > 3061 LceOutputChannels > BFD_R_CCM = ccm_blinker_r
REM > 3061 LceOutputChannels > BFD_R_IS_LED = aktiv
REM > 3061 LceOutputChannels > BFD_R_UE_SPG_SCHUTZ = dimmed
REM > 3061 LceOutputChannels > BL_L_IS_LED = aktiv
REM > 3061 LceOutputChannels > BL_L_KALTUEBERWACHUNG = nicht_aktiv
REM > 3061 LceOutputChannels > BL_L_UE_SPG_SCHUTZ = nicht_aktiv
REM > 3061 LceOutputChannels > BL_R_IS_LED = aktiv
REM > 3061 LceOutputChannels > BL_R_KALTUEBERWACHUNG = nicht_aktiv
REM > 3061 LceOutputChannels > BL_R_UE_SPG_SCHUTZ = nicht_aktiv
REM > 3061 LceOutputChannels > FRA_H_L_IS_LED = aktiv
REM > 3061 LceOutputChannels > FRA_H_L_KALTUEBERWACHUNG = nicht_aktiv
REM > 3061 LceOutputChannels > FRA_H_L_WARMUEBERWACHUNG = aktiv
REM > 3061 LceOutputChannels > FRA_H_R_IS_LED = aktiv
REM > 3061 LceOutputChannels > FRA_H_R_KALTUEBERWACHUNG = nicht_aktiv
REM > 3061 LceOutputChannels > FRA_H_R_WARMUEBERWACHUNG = aktiv
REM > 3061 LceOutputChannels > NSL_L_IS_LED = aktiv
REM > 3061 LceOutputChannels > NSL_L_KALTUEBERWACHUNG = nicht_aktiv
REM > 3061 LceOutputChannels > NSL_L_UE_SPG_SCHUTZ = aktiv
REM > 3061 LceOutputChannels > NSL_L_WARMUEBERWACHUNG = nicht_aktiv
REM > 3061 LceOutputChannels > NSL_R_CCM = NEW_ccm_nsl_r
REM > 3061 LceOutputChannels > NSL_R_IS_LED = aktiv
REM > 3061 LceOutputChannels > NSL_R_KALTUEBERWACHUNG = nicht_aktiv
REM > 3061 LceOutputChannels > NSL_R_UE_SPG_SCHUTZ = aktiv
REM > 3061 LceOutputChannels > NSL_R_WARMUEBERWACHUNG = nicht_aktiv
REM > 3061 LceOutputChannels > RFS_L_CCM = NEW_ccm_rfs_l
REM > 3061 LceOutputChannels > SL_2_L_CCM = Fxx_ccm_sl_2_l
REM > 3061 LceOutputChannels > SL_2_L_IS_LED = aktiv
REM > 3061 LceOutputChannels > SL_2_R_CCM = Fxx_ccm_sl_2_r
REM > 3061 LceOutputChannels > SL_2_R_IS_LED = aktiv
REM > 3061 LceOutputChannels > SL_L_IS_LED = aktiv
REM > 3061 LceOutputChannels > SL_R_IS_LED = aktiv
REM > 3062 LceLampMapping1 > MAPPING_BLINKER_H_L_FIXED_PWM = fixed
REM > 3062 LceLampMapping1 > MAPPING_BLINKER_H_L_PWM_LEVEL_1 = 13.7V
REM > 3062 LceLampMapping1 > MAPPING_BLINKER_H_R_FIXED_PWM = fixed
REM > 3062 LceLampMapping1 > MAPPING_BLINKER_H_R_PWM_LEVEL_1 = 13.7V
REM > 3062 LceLampMapping1 > MAPPING_BRAKEFORCED_L_FIXED_PWM = fixed
REM > 3062 LceLampMapping1 > MAPPING_BRAKEFORCED_L_PWM_LEVEL_1 = 100%
REM > 3062 LceLampMapping1 > MAPPING_BRAKEFORCED_R_FIXED_PWM = fixed
REM > 3062 LceLampMapping1 > MAPPING_BRAKEFORCED_R_PWM_LEVEL_1 = 100%
REM > 3062 LceLampMapping1 > MAPPING_BREMSL_L_FIXED_PWM = fixed
REM > 3062 LceLampMapping1 > MAPPING_BREMSL_L_PWM_LEVEL_1 = 13.5V
REM > 3062 LceLampMapping1 > MAPPING_BREMSL_R_FIXED_PWM = fixed
REM > 3062 LceLampMapping1 > MAPPING_BREMSL_R_PWM_LEVEL_1 = 13.5V
REM > 3063 LceLampMapping2 > MAPPING_NEBELSCHLUSSL_L_FIXED_PWM = fixed
REM > 3063 LceLampMapping2 > MAPPING_NEBELSCHLUSSL_L_PWM_LEVEL_1 = 13.5V
REM > 3063 LceLampMapping2 > MAPPING_NEBELSCHLUSSL_R_FIXED_PWM = fixed
REM > 3063 LceLampMapping2 > MAPPING_NEBELSCHLUSSL_R_PWM_LEVEL_1 = 13.5V
REM > 3063 LceLampMapping2 > MAPPING_RUECKFAHRL_L_PWM_LEVEL_1 = 13.7V
REM > 3063 LceLampMapping2 > MAPPING_RUECKFAHRL_R_PWM_LEVEL_1 = 13.7V
REM > 3063 LceLampMapping2 > MAPPING_UNIVERSAL_6_OUTPUT = sl_2_l
REM > 3063 LceLampMapping2 > MAPPING_UNIVERSAL_7_OUTPUT = sl_2_r
REM > 3063 LceLampMapping2 > MAPPING_UNIVERSAL_8_OUTPUT = bfd_l
REM > 3063 LceLampMapping2 > MAPPING_UNIVERSAL_9_OUTPUT = bfd_r
      01-30-2020, 10:19 PM   #142
dexterdpc
dexterdpc's Avatar
61122410220 harness instructions
BMW 61122410220 Instructions in English. Tells you how to rewire so you don't need to tap other wires (you still need to code in Bimmercode - see my post above!).
      01-31-2020, 02:59 PM   #143
david51
david51's Avatar
France
538
Drives: bmw M3 F80
it's not new I already gave the codes on page 3 but it doesn't work on all models
      02-08-2020, 11:46 AM   #144
fabianx
Drives: BMW 3 GT F34 318d
Hy. I want to retrofit rear tail lights to my BMW 3 GT F34. Should i use the same steps as F30 ?
And i have one more question, is it possible to retrofit my headlights (from halogen, to full led), and use for coding Binmercode? Thank you in advance
      02-10-2020, 05:54 PM   #145
david51
david51's Avatar
France
538
Drives: bmw M3 F80
I think this is different from the F30
yes you can use bimmercode to suppress the rear light monitoring module REM
      03-25-2020, 04:41 AM   #146
Coopers
Drives: BMW F31
When retrofit is completed, does inner tail lights should turn on when the brake pedal is pushed? Please see picture. There seems to be LED lights inside or are they for different purpose?
      04-18-2020, 02:17 PM   #147
DeividF80M3
DeividF80M3's Avatar
44
Drives: BMW F80 M3
2015 BMW F80 M3  [0.00]
Thanks for sharing mate, i can do with that coding, i can´t by OP.
F80 My15
Cheers
      08-28-2020, 03:17 PM   #148
asheenlevrai
Drives: BMW F31 318d (2012)
Originally Posted by Wunsch View Post
This tutorial is great, and I really appreciate it. Unfortunately, I'm finding that the inside of the hatch on the F31 is quite different from the liner inside the trunk lid on the F30. Does anybody have some tips on how to get at the inner lights on an F31?
I have the same question
      08-28-2020, 03:20 PM   #149
asheenlevrai
Originally Posted by weytie View Post
As the install of the lights on a F31 is a bit more complicated then the F30, here some pics of the wiring for the inner lights.
Here is how I did the wiring.
The only parts you have to remove are the 2 sliding covers (where the lights are), the upper trim of the tailgate.
Also undo the trim where the concertina goes inside the tailgate.(there’s 1 torx screw under the rubber piece, the rest just clicks off). See picture.
Then i took out the inner taillight on the right side.
You can run the wiring of the left taillight tot he right side with a bith routing.
Then I inserted a flexible iron wire from the top of the tailgate tot he bottom of the tailgate where the inner light is.
This is very easy. Now you take the 2 wires and tape them tot he metal wire and pull the wire up and guide the wires easily to the top.
Once this is done, you take out the sealings of the rubber concertina on both sides.
I then sprayed some silicone spray in the concertina and on the wires to guide them easy through the concertina.
Actually this went really easy.
It’s just a matter of opening and closing the uper part of the tailgate and complete tailgate for easy acces of putting in the wires.
Then you release the 2 screw on the D pillar and pull off the rubber seal ( you have to pull strong to take off.
Now you take off the cover fort he battery to access the REM box.
I connected them directly to the connectors with a scotchlock tot he correct wires.
Put everything back together and done 
Thanks
      10-11-2020, 04:44 PM   #150
328iking
Drives: 328i
Anyone struggle to fit the inners. Whereby the hole and lug don't quite align?
Has anyone cut it off? Pic attached
      10-17-2020, 11:06 AM   #151
OcTag3n
Drives: 2015 435d X-Drive F36
Originally Posted by cossie1 View Post
Turns out it was a faulty adaptor harness.
How did you find out the harness was bad? By buying a new one?
      10-17-2020, 04:16 PM   #152
cossie1
Drives: 2015 F82 M4
1 of the pins on the adaptor loom I bought from ebay was snapped so when inserted into the rem connector it didn't make a contact.
I bought the OEM loom in the end.
      10-17-2020, 05:21 PM   #153
OcTag3n
I think this is the route I might take. How much did you pay for the OEM loom?
      10-17-2020, 05:28 PM   #154
cossie1
Drives: 2015 F82 M4
Was about £90 iirc.
