09-23-2014, 11:52 AM | #1 |
Rep 435
First dyno run ever, what gear?
I am going to have my awd 435 (at 8 speed) dynoed on Friday. I have never been to a dyno. my intent is to verify the vr tune I have is operating at safe A/F ratio and also of course find out the power.
what gear should I pull? also anything else I should know going into it blind? I thought you are supposed to do a pull in whatever gear is the closest to 1:1 not sure if that is right though because from what I am reading that is 6th gear which is higher then I would normally expect.. |
09-23-2014, 11:59 AM | #2 | |
Rep 648
/Krelle
Ist der Motor kalt, Gib ihn sechs ein halb.....
09-23-2014, 02:08 PM | #4 |
Rep 1,252
6th pulls till 160( 266kmph) which is too long and will make intake overheat...
i guess 5th or 4th are best. even tho they aren't 1:1
Docrace 6266
09-23-2014, 03:45 PM | #7 |
3441
Rep 79,212
I would stay on the side of conservative and just do a 5th gear pull. You may find a bit more torque in a higher gear but it's really trivial stuff.
09-24-2014, 06:49 AM | #8 |
Rep 435
what about a/f readings? I was shopping for downpipes yesterday and I see some offer extra bungs for wideband and egt gauges. without this extra bung can they read my a/f properly.
they phrased it like this: "We do have an awd dyno jet. We also have a air fuel wideband monitor..." not sure if it is possible that they hook to the obd2 port or just go in the tailpipe. otherwise I am thinking I would need an extra bung in an aftermarket downpipe. |
