BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > N20 328i JB4 **STAGE2** Dyno Testing -- New World Record. :)
proTUNING Freaks
      08-29-2013, 11:38 AM   #221
JSillaway
Drives: 2013 328 N26
Originally Posted by ScarecrowBoat View Post
You can only select map 1 or map 0 with the wheel as of now. To change to other maps you have to hook up your computer with the usb cable to the JB4 (extra cost).
Hold Volume (-) for 5 seconds, then press either (+) for map 1 or (-) for map 0.
The full control from the steering wheel should be added soon.
DL the JB4 comp interface from here http://www.n54tech.com/forums/showthread.php?t=15536
One more question now that I have hooked up my laptop and I am in map 2 can I change back to map 1 from the steering wheel or do I have to hook it back up to the laptop?
      08-29-2013, 01:05 PM   #222
rustyminded
rustyminded's Avatar
248
Drives: BMW 328i
The volume keys are for map 0 and 1 only, yes you can change it back to map 1 from steering.. but If you want map 2 again you will have to hook up the laptop again
      08-29-2013, 01:52 PM   #223
ScarecrowBoat
Zooombie attaaack!!
ScarecrowBoat's Avatar
Drives: 328
The steering wheel controls take you to map 1 or 0 no matter if you're in map 0 or 1 or 2 or 7.
      08-29-2013, 04:13 PM   #224
JSillaway
Thanks
      08-29-2013, 05:12 PM   #225
gtman
Iron man
gtman's Avatar
24
Drives: 2013 328i M-Sport/2013 C63AMG
is stage 2 still beta?
2013 328i M-sport Totaled|2013 c63AMG|2014 G63AMG|2015 S65AMG|2015 S63AMG COUPE|2009 GL450|2015 fiat 500 abarth|2011 porsche boxster|2012 Lamborghini Gallardo gone but not forgotten|
      08-30-2013, 08:26 AM   #226
1GrayBulldog
Drives: 2013 135i
Yep, sure is. I'll be (pleasantly) surprised If the beta tag is removed before the new year. There's still a bit of work to be done on refining the tune IMO, especially for the majority of us who have the electronic solenoid control.
      08-31-2013, 12:45 AM   #227
ilya_treg
Drives: f30 320i
hello guys let me remind you, i got 320i which reflashed in 328i
two days ago I connected my bms stage 2, we made a couple of races vs 328 stock (map 1), if previously we dispersed equally, but now I am going away from him, but not much
yesterday installed the downpipe, map 2, and result of the race with the 328i exactly the same as without downpipe and map1
why is this happening, whether it is necessary to ride for a couple hundred miles or not
      08-31-2013, 12:59 AM   #228
ilya_treg
Drives: f30 320i
      08-31-2013, 10:26 AM   #229
Seraphblade@sg
Drives: F30 328i
Originally Posted by ilya_treg View Post
Is this 320 or 328??
I thought the 320 can only run map 5 regardless of fuel, dp?
      08-31-2013, 11:06 AM   #230
Ictus
Russian Federation
54
Drives: BMW G30
This is 320i with 328i ECU programm.
G30 540i xDrive 2019 Rhodonie Silver M Sport
F16 30d 2019 Long Beach Blue M Sport
G30 530i xDrive 2018 Sophisto Grey M Sport - sold
F30 320d xDrive 2013 Alpine White Sport Line - sold
E90 325xi 2006 Sparkling Graphite - sold
      08-31-2013, 11:12 AM   #231
JSillaway
I am going to have to question how a 320 is going to keep up with a 328 with both having tunes? I have a 328 with stage 2 and cannot see this happening. I sell BMWs and there is a huge difference in power stock for stock.
      08-31-2013, 11:47 AM   #232
Ictus
Russian Federation
54
Drives: BMW G30
This guy can open the hood on a speed of 75 miles per hour, so do not worry about the engine) Everything is under control of our great experimenter!
Илюх, прости, не мог не похвастаться о твоих успехах!
      08-31-2013, 12:28 PM   #233
JSillaway
Hahaha that's good stuff right there!!
      08-31-2013, 01:00 PM   #234
ilya_treg
Drives: f30 320i
Ictus, I think they already know about me i just couldn't insert a photo )) http://www.f30post.com/forums/showthread.php?t=873542
      08-31-2013, 05:57 PM   #235
ilya_treg
Drives: f30 320i
we did some races with 328i again, and once again we got small difference
but on 6 gear from 80km/h-160kmh on 0 map - the same performance me and 328stock, and on 2nd map - i was much faster !
it means a big difference in 2000-4000 rpm, and small at 4-7rpm ( why?
      09-01-2013, 01:35 AM   #236
gtman
Iron man
gtman's Avatar
24
So it’s not worth buying yet?
      09-01-2013, 07:36 AM   #237
ilya_treg
Drives: f30 320i
racelogic data : 0-100kmh - 5.1s, 1|4mile - 13.4s )
      09-01-2013, 11:42 AM   #238
rustyminded
248
Drives: BMW 328i
you can't open map 2 unless you have 98 Octane, If you have less than 98 your performance will be demilished.. I would recommend 93 with E40 40% ethanol then you can open map 2 or even 7 if you want
      09-01-2013, 11:58 AM   #239
ilya_treg
Drives: f30 320i
i always use 98 octane, and we don't have any type of ethanol here
what if use 102 octane and 7 map?
      09-01-2013, 12:08 PM   #240
rustyminded
248
Drives: BMW 328i
yes you can open map 7.. but only with 102 Octane tell me if you feel the difference
      09-01-2013, 12:38 PM   #241
rustyminded
248
Drives: BMW 328i
Have you tried map 5 which is specifically for 320i, 520i ect. it will give the same boost as a stock 328i.. put in mind you have a different compression ratio so I don't know about using other maps you should ask John@bms.
      09-01-2013, 01:05 PM   #242
ilya_treg
Drives: f30 320i
i already have stock 328i program without bms !
