08-29-2014, 09:15 AM | #7173 |
Rep 40,752
PM sent.
08-29-2014, 09:26 AM | #7174 | |
Rep 40,752
Make sure you add OEOE as HO-Wort and not as SALAPA-Element.
08-29-2014, 03:57 PM | #7178 |
Rep 24
The only option i have in my iDrive menu is Door Locks and within that are two further options: Unlock All Doors or Driver Door Only.
Any ideas please? |
08-29-2014, 05:02 PM | #7179 | |
Rep 1,799
http://f30.bimmerpost.com/forums/sho....php?t=1020138
U06 230e Active Tourer |
Previous : 2019 F31 340i : 2017 F31 335D M-Sport |
08-29-2014, 05:52 PM | #7180 |
Rep 34
hi
How can I activate wifi connection phone. and how can I activate nbt m start logo? Which code should I use? Last edited by E///RAH; 08-29-2014 at 05:58 PM.. |
08-29-2014, 07:21 PM | #7181 |
Rep 24
I think i made a mistake, hopefully not..
Shawn i unchecked the VCM and MSM in Settings under the option tab just like you said but after editing the FA file that i loaded on the VCM tab under Expert Mode and added the Ho-Wort (OEOE) and Calculated FP and saved it, i then clicked on the MASTER tab at the bottom and clicked WRITE FA FP... Would i be in trouble with the dealership and did doing that void my warranty?? Really worried and stressed out.. Sorry to be a pain. |
08-29-2014, 07:44 PM | #7182 |
Rep 40,752
I answered your PM. You have no worries.
08-30-2014, 05:54 AM | #7183 |
Rep 3
Hey Guys
at first thanks for the S/W and all the explanations without it I even wouldn't know where to start! But it seems that a need a little bit of help. I intsalled e-sys (3.25.3) and applied the patch. copied the pzdata files (52.1) to e-sys/data and the folders to SWE. Attached the obd cable to my car and connected with e-sys. so far it is working (I can read out VIN, etc.), but when I try to read "CAFD_..." in HU_CIC (I wanted to start with indicator lights in HUD) I get an error message... Transaktions-Report: Aktion: Codierdaten lesen HU_CIC [63] [DV01958] readCPS o.k. CAFD_000000F9_007_003_022 Fehler: Datei für "cafd_000000f9-007_003_022" wurde nicht gefunden! [C012] Then I checked "I Stufen" and found that the version on my car (F010-14-07-504) higher is than the version I have for e-sys (F010-14-03-502). Could that be the problem or do I have made another mistake? Thanks in advance for your help... |
08-30-2014, 06:22 AM | #7184 |
Rep 40,752
08-30-2014, 10:30 AM | #7185 |
Rep 7
Hi everyone.
Took delivery of my new F30. Could someone (Shawn maybe) point me to the latest Esys Software, PSdZData Files and instructions to get a Token required for me to start coding my car (2014 build). Thanks! |
08-30-2014, 11:19 AM | #7186 |
Rep 40,752
PM sent.
08-30-2014, 12:43 PM | #7187 |
Rep 3
Help Needed. FAO Shawn Sheridan :)
Hello All
ive coded a fair bit of my F20 M135i June 2014 now with success, however there are a couple of things which aren't 'working' or failing to find the option to code. I have bus nav with HU_champ2 FIRST ISSUE Ive coded for BMW Live and although i now see the items available, and also done the required update. when i try to access e.g.: the internet i get a error message back, and when i select BMW live it states it was not purchased as part of the car order? Details Below I see under the available options status Internet and BMW Live. But yet when i select internet it is still stating a browser error. <Application error in Browser please try again or restart the application> Also when i select BMW Live it messages with <this is an optional service that has not been purchased for this vehicle> Under available services for the vehicle are Assist My Info Assist traffic information Assist Emergency Call Automatic tele service call BMW Live BMW Mobile Care Battery Guard Door Unlock Internet Teleservice Report Vehicle finder SECOND ISSUE I thought id be able to change the Idrive/connected start up image to the M logo image. (Im sure I've seen the option but i can't find it on my car. <another forum member 'wibbles' has said this is only a option on the ProNav?> can anyone confirm this? Third Issue I want the car to remember the last damn setting on the AC.. and the code line is IHKA 3002 OFF_MEMORY Air Conditioning will remember if ‘Off’ or ‘On’ from previous shutdown. yet i can't find this on my car?? last Issue I wanted to get the weather reading option on the screen, and i think its an option to do. advise would be great. Thank you all in advance Regards Iain Smith |
08-30-2014, 01:53 PM | #7188 |
Rep 149
shawn i am running esys 3.24.3. This is the second time this year I have had dealer work on my car and they update the software and now i cannot code my car to my liking. I just tried to code my car after the dealer had it last week and I get cafd_xxxxxxxxxxxxxxxx not found!
What do I need again for this? Do I need to update my esys or just the cafd files? Thanks, |
08-30-2014, 01:57 PM | #7189 |
Rep 40,752
You need to update your PSdZData.
PM sent.
08-30-2014, 03:42 PM | #7191 |
Rep 5
Hi, Shawn.
I am running esys 3.24.2. I tried to code my car and I also get: FEM_BODY [40] [ˇˇˇˇˇˇˇ] readCPS o.k. cafd_ffffffff-255_255_255 Fehler: File for "cafd_ffffffff-255_255_255" not found! [C012] So, I tried: Connect => Read FA => Activate FA => Read VCM => Left-Click on FEM_BODY => Click on "Detect CAF for SWE" => Select the CAFD matching your I-Level => Select OK => Right-Click on FEM_BODY (the ECU itself not the underlying CAFD) => Select CODE. And get a new error: [C111]. Do I need to update my PSdZData? |
08-30-2014, 03:50 PM | #7192 |
Rep 40,752
You should first try other CAFD's from Detect CAF for SWE option.
What PSdZData version you using?
08-31-2014, 07:58 AM | #7193 |
Rep 5
I'm running v52.0.4 Full PSdZData with SWFL.
This problem is happening after I took my car to review. They changed the rules on revisions of 8,000 km to 12,000km and all encodings were erased. |
08-31-2014, 10:52 AM | #7194 | |
Rep 54
E aÃ* amigo, qual a versão do I-step? Essa troca de plano de manutenção foi feita em qual kilometragem ( segunda troca? ) |
