12-04-2018, 12:52 AM | #23 |
Rep 373
i did some googling and realised it is forged due to the wide parting line and smooth edges. it also made a harmonic singing noise when i tapped it vs a thud a cast crank would make.
this then means that a pwg m135i which looks identical also has a forged crank as i have seen one as well. what i dont understand is if the crank is forged and the rods are as well what makes the n54 internals stronger?
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
12-04-2018, 02:55 AM | #24 | |
Rep 504
I'm not sure if rods are forged. In n54 technical training from bmw ag they state that they are forged. in s55 or n55 documentation I haven't found that rods are forged.
12-04-2018, 01:24 PM | #25 | |
Rep 1,348
Do you have a pic of the differences as well? Would love to see.
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 Last edited by ceedawg; 12-04-2018 at 01:30 PM.. |
12-04-2018, 07:05 PM | #26 |
Rep 1,693
12-04-2018, 09:00 PM | #27 |
Rep 2,577
Guys, I made a list for you. See the attached picture. To the best of my knowledge.
Outside of the obvious EWG big turbo, keep in mind the following two points that is critical but is not often talked about. 1) Steel forged crankshaft is the key to M135/235/M2 making noticeably more power everything else being equal. 2) M2 manifold is why it easily holds up 16+psi at 6k+ rpm, with stock turbo and pump gas.
Lemania 2320
bkdore103.00 |
12-04-2018, 09:20 PM | #28 | |
Rep 1,693
We really need to see the visual differences on the M2 manifold to understand. |
12-04-2018, 09:25 PM | #29 | |
Rep 2,577
And yes they're forged. Chart updated.
Lemania 2320
12-05-2018, 02:02 AM | #30 |
Rep 504
12-05-2018, 02:42 AM | #31 | |
Rep 2,577
Didn't care too much as stock IC is the first thing to go once you power mod.
Lemania 2320
12-05-2018, 07:08 AM | #32 | |
Rep 504
it is the same part number.
ceedawg467.50 |
12-05-2018, 10:49 AM | #33 | ||
Rep 83
12-05-2018, 01:38 PM | #35 |
Rep 373
so its basically safe to assume the n55 can handle 400-450rwhp daily comfortably.
12-05-2018, 07:07 PM | #36 |
Rep 1,693
12-06-2018, 12:57 AM | #37 |
Rep 504
strange that in B58 technical training it is mentioned that rods are drop forged, while not a word about it in n55 or s55 pdfs. But I agree, it would be nonsense to use non-forged rods in s55 and part numbers are the same with n55. Interesting thing that s55 holds higher power than n55 which tends to bend rods at lower power level than s55..
12-06-2018, 04:08 AM | #38 |
Rep 1,348
Do you have Pics /info on the difference between the two manifolds 335 vs M2 ?
12-07-2018, 12:28 AM | #40 | |
Rep 2,358
(A Dane in China) |
12-07-2018, 01:33 AM | #41 |
Rep 504
PS2 is only capable of max max ~550hp, to make 600+ on n55, PS2 is not enough for sure, need to go speedtech, but not many people went that way and almost no info about blown engines..
12-09-2018, 03:33 PM | #42 | |
Rep 1,693
harkes1078.00 |
08-13-2022, 08:05 PM | #43 |
Rep 37
not required, but recommended. the more power youre making the sooner your clutch disk will need to be swapped out, apparently the synchro’s start to get eaten alive with mods as well, the ZF 6 speed MT is a good trans but its not known to be very mod friendly
08-13-2022, 08:16 PM | #44 | |
1296
Rep 3,533
perryreid9031.50 |
