04-20-2015, 05:39 AM | #1 |
Rep 341
Help with my MINI
Hi all,
I understand this is a bit off topic however, I am not getting any luck with the MINI forum and members over here are exteremly helpful. I have an eight days old F56 (MINI COOPER), few days ago I found a bit pulsation through the steering wheel when the stop start kicked in. I hear a constant humming/pumping sound along with the pulsation/feedback through the steering wheel when the stop start system is active. If I am right in saying it sounds like your home gas radiator. I am finding it bit strange. Not sure if it is a pump, fan or some another part. Please help before I knock on the dealer's door. |
04-20-2015, 06:17 AM | #4 |
Rep 341
04-20-2015, 06:20 AM | #5 |
Rep 341
04-22-2015, 03:41 PM | #7 |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
It's not normal. Our R56 Mini just turns off then silent so I'm sure the new ones would do the same.
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
04-22-2015, 03:47 PM | #8 | |
Rep 1,437
04-22-2015, 05:40 PM | #9 | |
Rep 341
I was so loving our 9 days old MINI. |
04-23-2015, 12:42 PM | #10 | |
Rep 1,437
The pulsation thing is definitely not right - even today when the car had been heated by the sun and the a/c was trying its best to cool the car quickly, the ASS made the car fall silent except the internal fan. |
04-23-2015, 12:47 PM | #11 | |
Rep 2,727
Curent: F31 335d xDrive MSport Individual TB / OW Merino
Gone: F31 320d MSport BS /CR, E61 520d MSport Bus Ed, E53 X5 V8 Sport |
04-24-2015, 04:04 AM | #12 |
Rep 341
I have dropped my MINI at NINE ELMS this morning and the gentleman over there drove it and found it strange. He suggested that there may be something to do with the steering. The loan car feels absolutely fine.
I hope they resolve the issue. |
04-24-2015, 10:26 AM | #14 |
Rep 341
It does sound like a motor running even when the engine has come to a stop. Surprisingly, it does it randomly (probably 80%)..
05-02-2015, 01:20 AM | #15 |
Rep 341
After a week of diagnostics the dealer came back with "we have tried 3 F56s and they all do the same thing". They made me drive other cars and yes they did make some kind of noise and pulsating however it wasnt as loud as my car. I have adjusted the steering wheel and it did make some difference. Their explanation given was; when the car comes to a stop, enging cuts off to save fuel however the steering motor stays on to make it go once you move the steering or press the clutch. They said there is a quality bracket and this behaviour falls under that hence not faulty.
05-02-2015, 12:24 PM | #16 | |
Rep 1,437
Mine's silent. No pulsing/vibration (but I will check again). iirc the steering is really stiff and turning it too much causes the engine to re-start (I'll check that too!) |
05-02-2015, 03:43 PM | #17 | |
Rep 341
Once the car comes to a stop start then hold the steering wheel tightly and then you might feel some pulsation or I should say some motor running sensation through the steering wheel and then if you touch the center steering column near your knees and you might be able to feel the same sentation. Apologies if I am sounding crazy here. |
05-03-2015, 04:11 AM | #18 | |
Rep 1,437
Ok when for my Sunday morning spirited run - my god this mini is even better in the wet! Tested the Auto Stop Start. Absolutely silent. No vibrations. Even when I put my ear against the steering wheel, I couldn't hear or feel anything. Also moving the steering wheel left to right DID NOT restart the car and was not assisted. So not sure why the dealer thinks the electric motor keeps running. This must be a F30 thing that I got confused with. Mine is a Apr 2014 build, if that helps. If the other mini you drove had the same problem, maybe some models do keep the steering electric motor running |
05-03-2015, 04:56 AM | #19 | |
Rep 341
I am not going to let it keep me awake all night, I am going to enjoy my MINI and if it escalates them I shall take it to a different dealer. Does this sound like a plan? Cheers Saurabh |
05-03-2015, 08:18 AM | #20 | |
Rep 1,437
05-03-2015, 08:40 PM | #21 | |
Rep 588
Drives: F30 320d & G29 M40i First Edtn
: Best of luck |
05-04-2015, 04:15 AM | #22 | |
Rep 341
