04-29-2015, 05:05 PM | #23 | |
Rep 15,858
I despair at many tyre shops and their lack of engineering knowledge and bad practice. I watched a guy use a torque wrench, he 'clicked' the torque value correctly and then gave it a good heave. I had to say something, just a vacant look in return. HighlandPete |
04-29-2015, 05:11 PM | #24 |
Rep 554
Drives: 335D MSport 2016
Most tyre shops will use air guns for speed and on the normal bolts you are Ok. You have to take care with the locking bolt.
I would say the person responsible for this issue is the person who fitted the winter wheels, bet he used an air gun not a torque wrench!! |
04-29-2015, 06:32 PM | #25 |
Rep 7,032
Drives: 335xd Msport +
A torque wrench !!!!
My dad just used to stand on the end of the wheel wrench to make sure his nuts were tight enough |
04-30-2015, 01:29 AM | #26 | |
Rep 20,651
When refitting, finger tight, then a torqued down air gun using the correct nut sequence, finally torque them on. the number of times you see them walk up and use an air gun on max torque from the start and the socket bounces off and clashes on the vehicles wheel. The first garage I worked at HGV & Heavy Plant, I could only torque some lighter vehicles, the heavy stuff, I weighed bugger all and was like a starved Spuggy. Much to the delight of the fitters etc lol. |
04-30-2015, 02:02 PM | #27 |
Rep 1,216
My biggest issue when I was changing back to summers a month or so ago was not getting bolts out, but getting wheel off the hub.
Has to bash all 4 repeatedly with a club hammer via a block of wood. The bastards just didn't wanna go back into storage!
M3 Azurite Black now instead of the 335d. Roughly the same really.
04-30-2015, 02:49 PM | #28 |
Rep 77
I had the same - rubber mallet needed on all 4!
I quite enjoy the bi-annual change over, gives me an opportunity to clean up the calipers, hubs and wheel arches, and apply some GTechniq to the calipers. Also gives me 6 months to thoroughly clean the set of wheels that are off. My kit is: Trolley Jack Torque Wrench, simply a must and not that expensive. Rubber puck thingy for the jack points. Extendable wheel wrench, with electrical tape round the socket to prevent scratched. S |
04-30-2015, 03:58 PM | #29 |
Rep 1,089
[QUOTE=NISFAN;17825643]Used a gun to remove the locking nut? What an absolute dick.
You need a jack, trolley jack is preferable, make sure it has a low minimum height, and you need a BMW style jacking pad to fit the BMW jack block. You need a breaker bar (half inch) and a 17mm long socket, preferably the ones with a sock on them. On the breaker bar, a straight one with swivel end is the best for control, rather than the bent end extendable type. As mentioned a torque wrench is a good tool, but very expensive for the odd wheel change requirement. Most importantly......technique!!! You can shear the lock nut pattern off quite easily with the wrong technique, so make you gen up on that too, otherwise you could have spent money to be in the same position. Alternatively, just tell them to be careful with the lock nuts. Cost = zero[/QUOTEThat's what worries me, getting an outside party changing the tyres. I'm possibly thinking of changing the run flats to non flat decent rubbers. I don't have the correct equipment to change over the tyres though. I take it BMW dealers will change over non run flats with a substantial charge, more than than other tyre dealers ? |
04-30-2015, 04:29 PM | #30 |
Rep 32,881
Some copper grease on the hub where the wheel touches solves this for next time.
04-30-2015, 04:47 PM | #32 | |
Rep 196
I have Coppaslip (think that's how it's spelt), assume it's same as copper grease. Brilliant stuff anyway, good on back and metal side edges of brake pads too. For those of us who don't know (including me!), what is the torque setting on F3x wheel nuts please?
F31 330d Luxury RWD, MG, Black Leather, Vis Pack, Adv Parking, Adaptive Suspension, Sunroof, Elec sports seats, plus more...
For Weekends and sunny days: 981 Boxster GTS Last edited by Gorsh; 04-30-2015 at 04:48 PM.. Reason: spelling |
04-30-2015, 06:52 PM | #33 | |
Rep 32,881
140nm |
05-01-2015, 02:59 AM | #34 | |
Rep 476
Drives: F36 430D m sport, 340i m sport
05-02-2015, 05:43 PM | #35 |
Rep 130
I had this problem when I took the wheels off my e90 prior to part exchanging it. I had used copper slip but it didn't seem to make a difference this time as two of the wheels wouldn't budge even with a hammer. In the end I just lowered the jack very slowly until the weight of the car was on the wheel - came apart easily so did the same for the other one also.
05-03-2015, 11:58 AM | #36 |
Rep 597
Interesting thread as this locking nut is identical to mine and I had the same issue (posted another thread about it already). In my case though it was the locking key that deformed/broke.
The new locking nut key looks different in how it's been manufactured. I will see if I can get some pics to show it. |
05-03-2015, 04:36 PM | #37 | |
Rep 1,437
I was jacking up on a piece of wood but this much better! |
