12-04-2017, 03:43 PM | #1 |
Rep 96
Limits of the N20 engine? Beyond 27psi
It's been a few months now I've been running the Pure Stage 2 turbo on my 2016 428xi at 25 psi. I recently updated the JB4 firmware to "N20_OBDII_EWG_5_T2.hex" and like some others here my default boost safety changed to 36 psi and the N20 tmap sensor turned on.
I knew the car could push more and with this new range of PSI from the JB4, I did a few runs on map 6, targeting 27 psi & 30 psi and then on Map 7 (30+psi). I haven't really seen or read about other people raising the boost on the N20's, but I've posted a few logs for references and a list of my mods below. It seems like 27 psi is the limit these little engines are happy with. On the 30 psi Map 6 run and the Map 7 run, I was getting misfires around 55k RPM and 45k RPM respectively and had to let off the throttle. It wasn't any better if I tried raising Meth additive to 75. That being said, I had a few runs reach 30+ psi but it was very inconsistent, if anybody has any other input to safely increase boost, it would be appreciated. Mods: Pure Stage 2 Turbo, JB4, Eurocharged Back End Flash, Fuelit LPFP, ER turbo CP, BMS Methanol Injection kit (50:50), Injen Intake, Wagner Catless DP, AWE Quadtip Exhaust. BMS spacers, H&R springs. 94 Oct pump gas |
12-04-2017, 04:38 PM | #2 | |
Rep 2,638
You'll probably have to get your EC BEF revised for higher boost. The misfires you're getting may be coming from running too rich up top or your spark plugs aren't gapped correctly or not iridium. Try unplugging the MAF and do the run again, if it still misfires, then it's either the tune or plugs.
12-04-2017, 06:26 PM | #3 | |
Rep 96
12-04-2017, 06:45 PM | #4 |
Rep 63
More boost does not necessary mean more power if your running outside the efficiency range of the turbo. Running higher boost ranges will increase the chances of you blowing the motor. The difference here is the water injection has been tuned by someone who knows what they are doing. The advantage of water injection is its able to cool the intake temps by running the higher boost level and make up for the car running lean. The problem with these engines is they run hot and proper cooling is essential.
12-04-2017, 07:44 PM | #5 |
Rep 89
I would not run anything over 23/24 psi on an N20 without rebuilding it forged. Anytime I have heard of the N20 running higher PSI than 23/24 stock it bricks the engine.
12-04-2017, 07:48 PM | #6 | |
Rep 2,638
Just run safe and efficient boost till you get the revision |
12-04-2017, 09:20 PM | #7 |
Rep 96
Will do, I’ll be keeping boost around 24/25 psi until I could put it on a Dyno again and tune it safely. Some cooling mods might be necessary eventually. Thanks for the support
12-05-2017, 10:37 PM | #8 | |
Rep 577
Did you also replace your FMIC? Or is that stock? I guess the meth keeps your charge cool. You should get Bootmod3, then you can adjust the tune in the fly with a tuner over OBD, and won't have to keep removing the DME each time you want to revise. |
12-06-2017, 07:30 PM | #9 |
Rep 96
The FMIC is stock for now. But I’ll most likely upgrade next year depending on how temps get in summer weather.
I was looking into Bootmod3, but I don’t think Protuning Freaks does custom Dyno tuning. So I drove to Toronto (from Montreal) to put my car on Eurocharged Dyno for a custom tune. You’re right that the tune you have will make or break the engine, so I really wanted to get a custom dyno tune and make sure everything was running optimally. |
Stubok471.50 |
12-06-2017, 09:02 PM | #10 | |
Rep 2,638
12-06-2017, 10:24 PM | #11 |
Rep 96
I’ll have to see if they could build on my current tune if I make the switch.
Once you get near the power threshold of the engine, the power differences won’t be that significant. More boost and timing won’t necessarily result in more power so the dyno is important, but anyways what do I know lol, that’s why I’d rather let the experts handle it. But they both offer similar services. |
02-13-2019, 08:16 PM | #12 |
"Punished"
Rep 4
02-14-2019, 01:55 PM | #13 |
Big Turbo Boys N Girls
327
Rep 579
Entire block. Pistons+ rings, Rods +Bolts, wrist pins etc. Basically entire bottom end.
2012 F30: G25-660 Bottom Mount Mani+ DP+ Intake, CSF FMIC, VRSF CP, Walbro 450 LPFP, PR Injection with AIC 4, S63TU Injectors, Tuned with BM3, ZF Race 4 Puck and Non SSA Pressure plate, Catless, 3.5" Quad Muffler, Custom Valved Bilstein B8 + H&R SS. Max 456 WHP - 452 WTRQ. Currently tuned down to 434 WHP and 362 WTRQ to save the rods.
02-14-2019, 02:01 PM | #14 | |
327
Rep 579
To make this motor last, you want to get a big turbo and tune it like a traditional map. Starting low and building up gradually as you go through the RPM rang and peaking up near the top end. These cars from factory were designed to have peak power on low RPM to feel fast during daily stop and go but run out of steam real quick. My advise is to get a big turbo and tune it to gradually increase boost and power much like a N/A tune and your motor will last. Also since OP has METH an IC is not that big of a concern, as Meth helps far more efficiently to cool the air than any IC will.
02-14-2019, 03:38 PM | #15 | |
Rep 3,674
Anyway, what would you consider a "big" turbo? There's a lot of options out there. MHI, Pure, Mamba etc...
MacklinUSOB518.00 |
02-14-2019, 03:48 PM | #16 | |
Rep 891
Is Pure Stage 2 the only option for us or is there a larger turbo that is more budget friendly? Edit: just say rjd's post, I'm gonna check those out. Cheers.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i Last edited by MacklinUSOB; 02-14-2019 at 03:58 PM.. |
02-14-2019, 06:44 PM | #17 | |
Rep 3,674
MacklinUSOB518.00 |
Tags |
boost, jb4, ps2, psi, turbo |
