09-04-2018, 11:52 PM | #1 |
Rep 11
Will Apex EC-7 18x9 et31 fit on a 340??
I have a set of Apex EC-7 18x9 et31 left over from my M3. Currently, I have a 340xi. Would these wheels fit with a 235/45/18 tire?
Thank you! |
09-06-2018, 02:45 PM | #4 |
Cheapskate
4451
Rep 4,995
255 is proper tire fitment for a 9" wheel. But it would be pretty aggressive for our cars. The tire will most likely poke in the front and the back.
What is your suspension setup? |
09-06-2018, 02:52 PM | #5 |
Rep 11
Stock suspension...sticks out a little with the 245 set up I have from the M3 (245/45) which rubs in the front with turning. From what I researched, 235 is the minimum for a 9" wheel (225 will have a little stretch).
09-06-2018, 07:03 PM | #6 |
Rep 4,361
i meant 255. as kern417 said it is aggressive and will poke. 255/40 is lower diameter than 245/45 and it should not rub while turning. i am basing this on someone running 9.5" +35 with 255/35/19 saying he's not rubbing and peeps running M3/4 513M with 18x9 +29 on 255/40/18 up front, on F3x platforms
you can stretch 235/45/18 on the 9" if you'd rather, though Last edited by alohasurftoad; 09-06-2018 at 07:08 PM.. |
kern4174451.00 |
