BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > Professional Motorsport Racing Discussion (IMSA, DTM, Formula 1, Grand-AM, Le Mans, IRL, WRC, etc..) > FIA taking action on Red Bulls flexible rear wing
Studio RSR
      05-14-2021, 09:07 AM   #45
Killed by Death
Killed by Death's Avatar
12464
Drives: '23 X3 M40i
Originally Posted by GuidoK View Post
In that verstappen/bottas video you can also see that the mercedes rear vertical finn is flexing in the corners and under turbulance and the RB's rear finn doesn't.
I bet that on that little thing also a minute advantage is gained (I can't imagine MERC not being able to stiffen that finn up where other brands can).
I think it's strange that people do see a wing flexing on the RB car but don't see a finn flexing on the MERC car. How can I be the only person who does see that?
I bet that's equally 'non rigid'.
It's all the same same. All teams try to stretch the rules to find the tiniest possible advantage.
Good catch, didn't notice the vertical fin flexing because I was concentrating on the the wing.
M5Rick60060.50
      05-14-2021, 09:13 AM   #46
M5Rick
M5Rick's Avatar
60061
Drives: M5 F10 DCT Gunmetal
Originally Posted by ///M Power-Belgium View Post
Yeah , probably the W12 warp-speed isn't enough for HAM...
Otherwise ?
That's for sure with all the luck on his side !
Remember HAM at Imola in the gravel trap in reverse during the damn Red-Flag !
Mate , give me a f@cking break !
Theres a song called ''Some guys have all the luck'' (with the helpful hand of others who are in cahoots) I'm thinking of putting it on..
      05-14-2021, 09:22 AM   #47
David70
Drives: 06 Z4M Coupe - 13 Cadillac ATS
Originally Posted by Killed by Death View Post
Man, we agree on nothing
Lance Armstrong cheated and used "a range of techniques to avoid detection" with intent and covered it up for years.
RB passed all tests with no cover-up or intent to deceive because the wing was in plain view.
However, after watching the new video I think the FIA will change the test and RB won't be able to use it. The key part being marking wings and video observation not just load tests. IMHO
X2, Lance used a drug that was specifically banned, there was no grey area, then was successful getting by/or avoiding the tests.
RB has a spoiler that passed all tests and "rigid" isn't a binary, yes/no function. Take any of these cars over a curb, have gauges to measure deflection and you will find that virtually nothing is rigid. You want something that doesn't bend under a certain amount of load you need to put the numbers in the regulation and test for these numbers. Only thing I can see from the video is the RB wing is more flexible than the MB and the MB fin seams to be more flexible than the RB. I don't for a second think MB has this flexible fin because they don't realize it or can't fix it. Too simple to make it less flexible if it would help them.
2006 Z4M Coupe - Stromung exhaust, ZHP knob, stubby antenna, clutch delay delete
MKSixer34184.50
      05-14-2021, 10:15 AM   #48
///M Power-Belgium
///M Power-Belgium's Avatar
Belgium
63360
Drives: ///M3-E92-DCT Silverstone II
Originally Posted by M5Rick View Post
+1
Regarding the 16-B flexible rear wing :
It Isn't flexible , because the "whole rear wing" is moving downwards .
"IF" the rear wing was flexible , only the middle section of the wing would be curved downwards !
The reason why the Red Bull wing is moving downwards is because the 16-B is running with the well known "higher rake"
In other words : By the Red Bull's higher rake , the rear wing is catching more wind .
That's why we can see that the whole wing is moving downwards by the higher downforce on the rear wing .
HAM and Toto are talking BS as usual...
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod.
M5Rick60060.50
      05-14-2021, 10:24 AM   #49
M5Rick
M5Rick's Avatar
60061
The reason why the Red Bull wing is moving downwards is because the 16-B is running with the well know "higher rake"
The higher rake combined with more at an angle r/wing makes sense in it catching more wind.
It's why the W12 has been tail happy at first with their longer wheel base and higher rake thus using the McLaren diffuser to even it out and taking longer to warm their tyres whereas RB tyres up quicker.
      05-14-2021, 11:03 AM   #50
SenorFunkyPants
SenorFunkyPants's Avatar
Drives: 2019 M5
Watch how much the Red Bull wing appears to rise at the end of the straight...RB are leaning back their whole wing assembly to cheat the static load tests.
yco5737.50
      05-14-2021, 11:29 AM   #51
M5Rick
M5Rick's Avatar
60061
Newey knowhow
      05-14-2021, 12:00 PM   #52
///M Power-Belgium
Belgium
63360
Newey knowhow
The Mercedes "Warp-Speed Knowhow" isn't visible , because It's hidden under the W12 PU cover ...
That's what we are talking about , and that's why HAM is leading in the drivers rankings with a lot of luck on his side !
It's there where the FIA should look at ....
M5Rick60060.50
      05-14-2021, 12:15 PM   #53
M5Rick
M5Rick's Avatar
60061
Exactly my friend, it's what you ''can't'' see and only a fool thinks 44 car is all kosher with that (nasa) speed.
      05-14-2021, 12:27 PM   #54
David70
I'm assuming the static load test is done by pushing on an area of the wing and measuring deflection (correct me if I am wrong). You say RB are cheating the test, can you explain how? Only way I can see that you can say they are cheating the test is to understand how they did it or have some additional information besides just watching a wing go down more than another wing.
      05-14-2021, 02:17 PM   #55
Ngilbe36
Ngilbe36's Avatar
Drives: 2011 E90 M3, 2019 F150
2011 BMW E90 M3  [0.00]
Neat! It looks like they(RBR) knew how the FIA tested this and figured out a way to pass the test and still gain an advantage. This is engineering. As a result the FIA will tighten the testing up to eliminate this grey area/loophole. I'm not mad about it. Nice work RBR
      05-14-2021, 02:45 PM   #56
Killed by Death
12464
Drives: '23 X3 M40i
M5Rick60060.50
      05-15-2021, 04:56 AM   #57
SenorFunkyPants
Drives: 2019 M5
Wow.
So other teams who might have scored more constructors points (along with the $millions that brings) if Red Bull hadn't been cheating...you thing they are equally impressed by Red Bulls "engineering"?
And if Red Bull have the moral duplicity to cheat at one aspect of their cars design then why wouldn't they cheat at others?
      05-15-2021, 05:31 AM   #58
M5Rick
M5Rick's Avatar
60061
^ You could say that about the Merc hidden warp speed to which other teams are losing out on points, well hidden under those engine covers if Merc are cheating at that hiding it well and being passed as 'legal' like the Das scam.
      05-15-2021, 07:19 AM   #59
///M Power-Belgium
Belgium
63360
Great news about Grosjean . The Phoenix of the fire is back !
Most of his crashes were caused by his crappy HAAS car !
M5Rick60060.50
EdM54066.00
      05-15-2021, 08:37 AM   #60
M5Rick
M5Rick's Avatar
60061
Like his mauve car he he
      05-15-2021, 08:53 AM   #61
Chihuahua
Chihuahua's Avatar
4076
Drives: E30 329iS, E65 Alpina B7
Wow.
If their wing passed the FIA static load tests how is it cheating? This isn't Renault's mass damper, this is a rear wing that's in plain view. Kudos to RB for staying within the rules and finding an advantange. F1 101.
      05-15-2021, 08:58 AM   #62
///M Power-Belgium
Belgium
63360
Spot on mate !
M5Rick60060.50
      05-15-2021, 09:06 AM   #63
M5Rick
M5Rick's Avatar
60061
Spot on mate !
Having chicken shish kebab today my friend with mayo on the f/fries
      05-15-2021, 09:16 AM   #64
///M Power-Belgium
Belgium
63360
Rainbow trout here...
M5Rick60060.50
      05-15-2021, 09:46 AM   #65
Killed by Death
12464
Drives: '23 X3 M40i
Love it, good for him!!!!!!!
Still hoping HAAS can pull off a miracle in 2022. My second favorite team since I live about 20 minutes from their US factory. MAYBE Ferrari can produce a great engine without cheating next year. But I doubt it
M5Rick60060.50
      05-15-2021, 10:12 AM   #66
///M Power-Belgium
Belgium
63360
Same here . It's really nice for Grosjean to see him get the pole !
Also for his wife and kids , after such a hard time..
No wonder he crashed so much in the Haas car . The Haas car is very unpredictable !
On the other hand : I've watched the 30 episodes (3 seasons) of Drive To Survive ..
I mean the driver Kevin Magnussen did an oustanding job at Haas in that crappy car !
If Checo fails at Red Bull , Horner should make that call for Kevin Magnussen ASAP !
Kevin is such a nice guy and his driver performance is really underestimated ...
Hopefully we can see Kevin back in F1 ASAP !
EDIT : Ferrari ?
Well , Ferrari did a big step forwards !
Look where they came from...And look where they run today !
M5Rick60060.50
