BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 2012 BMW 335i F30: Still the Benchmark @ 0-60mph - 4.7 sec (Motor Trend Video)
      02-28-2012, 11:41 AM   #111
justinnum1
Drives: 2018 330i Msport 6mt
Originally Posted by Q4P View Post
Are you really comparing a car that weighs 500 lbs less in terms of performance? LOL The knowledge on this forum amazes me at times.
As far as 0-60 times are concerned, different situations will get different results which is why 0-60 times are not a good way to judge performance. Any sort of incline change, tire change, traction issue, style of launching and temperature will all have to do with 0-60 times. Trap speeds at the end of the 1/4 mile are the only relevant ways in comparing 2 vehicles performance in that regard, the 335i is 5-6 MPH faster than a 328i (which is a huge difference).
lol
      02-28-2012, 12:50 PM   #112
Robin_NL
S0THPAW
Robin_NL's Avatar
8717
Drives: HS M2 Competition
Sorry for being ignorant , sir. I won't do that again, I promise you.
F30 335iAT 0-200kmh :20.4s
F10 535iAT 0-200kmh: 21,8s
That's less difference than the 328i vs 335i.
Think about it!
      02-28-2012, 01:17 PM   #113
saamfou
Drives: 2011 E93 M3
Originally Posted by Weaselboy View Post
Exact same thing happened with the E90. Car mags got about 1/2 second less than the BMW published number.
I noticed in the video he is torque braking the auto trans to about 2k RPM at launch. I wonder if BMW is testing without doing that?
What is torque braking?
      02-28-2012, 01:22 PM   #114
Weaselboy
Weaselboy's Avatar
76
Drives: 2024 M340i
Holding your left foot on the brake to keep the car stopped while pressing the accelerator with the right foot to increase RPM, then releasing the brake. In this case they revved to 2,000 RPM to get up in the torque band at launch, then released the brakes.
      02-28-2012, 01:34 PM   #115
saamfou
Drives: 2011 E93 M3
Got it, so in effect when you release the car the engine is spinning at higher RPMs and thus great torque to the wheels at start?
      02-28-2012, 01:38 PM   #116
Red Bread
Drives: Smog machines
Precisely. Many modern automatic and DSG cars don't allow this though, so comparing like for like isn't always possible.
      02-28-2012, 01:38 PM   #117
pcbrew
pcbrew's Avatar
29
Drives: 2012 335i 6MT
Yes, need too have the turbo spooled up to be in the sweet spot for torque.
      02-28-2012, 01:44 PM   #118
Q4P
Q4P's Avatar
Drives: Too Much
Think about it!
Right but there is still a 500 LB weight difference between a 335i and a 535i which is massive. The cars have identical engines so the weight differential is made up more so than when comparing a 335i to a 328i which is down on 40 HP. Anyway you look at it, with that much of a weight difference between a 3 and a 5, the responsiveness / acceleration of the vehicles will not be even close nor could it be. Try that again by doing 100-200 KM (where launching is not a concern) and I promise the results will be even further apart.
2jZ + RB26 + 4G63 + LS9 + N54 =
      02-28-2012, 02:43 PM   #119
KR335
Drives: 2020 M340iX
Originally Posted by Sumithb13 View Post
Did you not watch the video? He launched it from a dead stop.
They always lauch from a dead stop. The question is when does the clock start? If they measure with rollout, it doesn't start until the car has moved one foot, which seems to generally subtract 0.2-0.4sec from the 0-60 compared to staring it from when the car first moves.
      02-28-2012, 02:50 PM   #120
KR335
Drives: 2020 M340iX
Originally Posted by Michael Schott View Post
Can't speak for all car magazines but here are Car and Driver's test procedures:
http://www.caranddriver.com/features...-c-d-test-cars
They do not roll the car. 0-60 is from a dead stop. Same with Inside Line for 0-60 times:
http://www.insideline.com/features/h...nd-trucks.html
Road & Track does a 1 foot roll but they subtract the time for that 1'. Not sure about Motor Trend.
Here's the response (from Michael Austin - C&D staff) to a post on the C&D forum when I asked the editors whether or not they measure acceleration times with rollout.
"Hi! We haven't changed our methodology, and we still use rollout. Currently (and going a long way back) we use 0.3 miles per hour to approximate the 1-foot rollout. The rollout time is typically around 0.2 to 0.3 second.
We've always had a lively discussion here in the office about publishing rollout times in the performance results. Do you think that would be a good idea, or just extra information that might confuse too many readers?"
I'm pretty sure MT does the same, but can't currently find a document that confirms that.
      02-28-2012, 03:35 PM   #121
clarence
Drives: F30 328i M-Sport
Actually wht sort of timing equipment do they use?
      02-28-2012, 07:45 PM   #122
Danforz
BMW Enthusiast
Drives: 328i '07
0-60 tests are designed to get the best results not the most repeatable results or the results you and I would get. They find the optimal revs that won't spin the tires and with an AT brake torque to that point and dump the brake and mash the throttle at the same time. With a MT they find the right revs, dump the clutch and mash the throttle. They also often correct for humidity and elevation.
We spend a lot of time here gnashing our teeth over 0-60 times but what's relevant for most of us in the real world is the feel we get in the seat of our pants. Nothing more.
I agree, there's more to a car than 0-60. That said, I'm a consumer who likes to be informed accurately and I think we can all agree with that can't we? Look, to me, and if you take a moment to think about it, to most people, 0-60 means you take your foot off the brakes and press the gas.
All this stuff with roll out, or torque breaking is great, I suppose, but they should also just include a normal 0-60. Its really not asking for much.
      02-28-2012, 09:17 PM   #123
KR335
Drives: 2020 M340iX
I believe most use VBOX equipment. At least C&D does according to the link posted in one of the earlier posts.
      02-29-2012, 12:57 AM   #124
KevinJ
Drives: 2k11 335is
The 2012 335i does not do 0-60 4.7s
First the reviewer did torque braking so he's kinda cheating the 0-60 and creating some hooplah and reality is slower as recorded by C/D. A 335is can consistently do 0-60 in 4.5-4.7 (Road and Track 4.5). According to C&D (4.6 seconds).
Comparing real C/D results between the 335is coupe and 2012 335i sedan reveals the real story. Look at each track time below:
335is Coupe
Power (SAE net): 320 bhp @ 5900 rpm
Torque (SAE net): 370 lb-ft @ 1500 rpm
C/D TEST RESULTS:
Zero to 60 mph: 4.6 sec
Zero to 100 mph: 11.4 sec
Street start, 5–60 mph: 5.0 sec
Standing ¼-mile: 13.3 sec @ 108 mph
Source: http://www.caranddriver.com/reviews/...take-road-test
2012 335i
Power: 300 hp @ 5800 rpm
Torque: 300 lb-ft @ 1200 rpm
C/D TEST RESULTS:
Zero to 60 mph: 5.3 sec
Zero to 100 mph: 13.0 sec
Street Start, 5–60 mph: 5.9 sec
Standing ¼-mile: 13.8 sec @ 103 mph
Source: http://www.caranddriver.com/reviews/...an-test-review
Also just review the C/D test notes: 2012 335i 0-60 5.3 and look at the outside cold temp which would helps the 0-60 time. The 335is for example was done at near 70-80 degree temps.
http://media.caranddriver.com/files/...april-2012.pdf
http://media.caranddriver.com/files/2011-bmw-335is.pdf
Originally Posted by gatoman39 View Post
2012 BMW 335i: Still the Benchmark?
0-60mph - 4.7 sec
1/4 mile - 13.3 sec @ 103.9 mph
60-0 - 109 ft
Lateral accel: .90g
This new one actually accelerates at the same pace as the 320-horse, 332 lb-ft 335is -- the one with two turbos and a fast-shifting twin-clutch transmission. Our mere automatic 2012 335i, down a turbo and supposedly 20 horsepower and 32 lb-ft, reached 60 mph in 4.7 seconds and the quarter mile in 13.3 sec at 103.9 mph. That's right on pace with a Camaro SS, assuming it's driven well.
      02-29-2012, 01:21 AM   #125
Robin_NL
S0THPAW
Robin_NL's Avatar
8717
@KevinJ. Thanx for the info, and whatever the outside temperature and other conditions:
German carmag AMS tested an F30 335i sportline 0-62 in 5.1 seconds.
My F30 335i is just as fast as my ex my 2007 N54 335i but even has a better sound/brakes and chassis to it.
Whatever the outcome and until the M3 arrives, or if there's an upgrade of the N55 etc., in this segment the F30 335i sportline is the real sports sedan as BMW advertised.
      02-29-2012, 01:42 AM   #126
DrivenByE30
DrivenByE30's Avatar
France
592
Drives: '12 F30 Lux 335i 6MT
Curious to know...
from your point of view: who would be the closest competitor to the F30 335i ?
Now that you are one happy owner of one,
which car do you consider to be most likely to tail the F30, and for which you should keep an eye in the mirror?
      02-29-2012, 02:45 AM   #127
Robin_NL
S0THPAW
Robin_NL's Avatar
8717
Originally Posted by DrivenByE30 View Post
Curious to know...
      02-29-2012, 02:58 AM   #128
svache
svache's Avatar
Drives: 2012 F30 328i
http://2.bp.blogspot.com/_JxGRBQDzsic/S_yLHceCbxI/AAAAAAAABFI/oGJle1k7mnQ/s1600/Police+Cars+BMW.jpg
Seeing you live so close to the border, I think in your case it will be more likely these guys:
Btw, I love this one here:
      02-29-2012, 06:45 AM   #129
Falafel Combo
Drives: X5 xDrive50i
lol @ fake exhaust voice-over @ 1:12.
So just to re-cap, what the f30 328i claims to do well, when pushed to the limit and red-lined in sport mode, busting some veins, the f30 335i does better in it's bath robe without breaking a sweat. Not bad.
The f30 335i has some great potential.
      02-29-2012, 07:47 AM   #130
Michael Schott
Drives: 2017 VW GTI Sport
Interesting. The link I posted did not say they use roll out. And it would be good to know if this is for 0-60 times of 1/4 mile or both. It seems some magazines use rollout for 1/4 mile and not 0-60.
Can you please link to the forum discussion? It sounds like a good read.
      02-29-2012, 10:21 AM   #131
DrivenByE30
France
592
Thumbs up
Good one! and realistically too!
In typical Top Gear expression
      02-29-2012, 10:58 AM   #132
Fugly M3
Fugly M3's Avatar
5071
Drives: 2023 M3CX
Originally Posted by Calmwinds View Post
wait, so the 5.4s published by bmw is inaccurate?
I really thought it didn't make sense that a car 80 lbs lighter with the same engine would be slower than previous gen.
please don't take this personally- perhaps you're new to BMW and don't know but for everyone else who's been posting the same question over and over on numerous threads- BMW's numbers are typically .4-.8 seconds pessimistic in the 0-60 time category.
on another note- love the upholder test- if he did that in an e9x he'd be covered in water
2012 3 series review, 2012 3 series reviews, 2012 335i review, 2012 335i reviews, 2012 335i track video, 2012 f30 review, 2012 f30 reviews, 3 series f30, 3 series f30 forum, 3 series f30 review, 3 series f30 reviews, 3 series forum, 3 series reviews, 3-series review, 335i 0-60, 335i 0-60mph, 335i f30, 335i f30 review, 335i f30 video, 335i quarter mile, 335i review, 335i reviews, bmw 3 series first drive, bmw 3 series forum, bmw 3-series f30, bmw 335i review, bmw 335i reviews, bmw f30, bmw f30 3 series forum, bmw f30 3 series review, bmw f30 3-series, bmw f30 forum, bmw f30 review, f30 0-60, f30 0-60mph, f30 3 series review, f30 3 series reviews, f30 3 series track video, f30 3-series, f30 3-series forum, f30 328i, f30 328i quarter mile, f30 335i 0-60, f30 335i 0-60mph, f30 335i review, f30 335i track video, f30 335i video, f30 forum, f30 forums, f30 review
