07-03-2017, 12:31 PM | #1 |
Rep 5,997
Coasting vs. Turning off Injectors
So when running in Eco-Pro mode on the highway, the car will enter a coast mode where it goes into Neutral when you're not pressing the gas. I read somewhere that all modern cars turn off the fuel injectors when in gear and you're not pressing the gas and the engine is above say 2000 rpm. If the engine drops below maybe 1500 the fuel injectors come back online. So in this condition you're not using any fuel, vs. in coast mode the transmission is in Neutral and the engine is idling, so it's using fuel otherwise it would stall. Wouln't it make more sense to leave it in a higher gear to prevent engine braking while coasting and turn off the fuel injectors? Or maybe turn off some of the fuel injectors like cylinder deactivation on some cars.
07-03-2017, 01:20 PM | #3 |
Rep 5,997
07-03-2017, 03:26 PM | #4 |
Rep 16,082
There's a lot of engine braking. If you had a car with a standard and no power anything, especially steering, you could test it by turning the ignition off, though I wouldn't recommend it. Wherever you saw the idea that injectors are turned off when coasting is wrong. The injectors on unused cylinders are turned off with a variable cylinder engine, but only on the unused cylinders, and in order to work the valves on those cylinders are also kept closed.
07-03-2017, 04:08 PM | #5 | |
Rep 5,997
07-03-2017, 04:17 PM | #6 | |
Rep 15,858
I also question how coasting saves more fuel, only possible if drive train losses exceed the fuel used to idle the engine. |
bimmer4562960.50 David Kunitz658.00 |
07-03-2017, 04:33 PM | #7 |
Rep 42
I would say coasting does save fuel on my 435. Especially on a long downhill stretch. Without it the engine slow the car so much that you need to depress the accelerator repeatedly to maintain speed. I've noticed mine doesn't always coast though, it seems to be linked to the satnav. When the reduce speed image is present on dash it automatically engaged gear, wish I could change that.
07-03-2017, 04:53 PM | #8 | |
Rep 16,082
07-03-2017, 04:55 PM | #9 |
Rep 5,997
That's different from the fuel cut off. That's only on some sixes vs all cars have the fuel cut off. I think the manual sixes don't have VCM as this impacts responsiveness when you get on the throttle.
07-03-2017, 05:06 PM | #10 | |
Rep 5,997
07-03-2017, 07:25 PM | #11 |
Rep 1,342
Related story...
We have a 2011 Honda Odyssey with ~80k miles that had an issue last year. Engine light turned on; I thought it was just a misfire or something else minor. But it turned out that there was a TSB on VCM. Apparently the original VCM programming wasn't quite right, and excess fuel was left in the 3 cylinders that get shut off (when coasting and/or other conditions make it OK). The fix was to replace the piston rings in the 3 cylinders (!) and reprogram the ECU. Funny that the 3 cyls were at the back of the engine and they some how did this repair with the engine still in the car. Even though we were way beyond warranty, the work was done at no cost, plus had a loaner for the 3 days it was in the shop. About 12k miles later, it hasn't blown up yet. Modern cars are incredibly complex. |
07-03-2017, 07:32 PM | #12 | |
Rep 5,997
07-03-2017, 08:09 PM | #13 |
Rep 1,502
I knew I'd heard somewhere that while coasting (foot off the gas while car is still moving in Drive, not the BMW eco-pro definition of coasting whatever that is) fuel is shut off.
I had to google and voila, Car and Driver confirms it: "We went in search of an expert opinion on this one. According to Paul Williamsen, the product education manager at Toyota, “All contemporary Toyota and Lexus vehicles (and every other car built since the 1990s that I’ve looked at) can detect the condition when engine revs are higher than idle with a fully closed throttle: Under these conditions, all current to the fuel injectors is stopped, and no fuel is injected.” That means if your foot is off the gas while the car’s in gear, you’re not using any fuel. Tom Read, GM’s powertrain spokesman, agrees: “Shifting into neutral in an automatic will cancel fuel cutoff. Thus, it is better to remain in gear and let the drive wheels pull the engine airflow down to where fuel cutoff can be enabled or where fuel flow is minimized.”" http://www.caranddriver.com/features...neutral-page-3 |
07-03-2017, 08:14 PM | #14 |
Rep 3,256
I've wondered the same. My guess is that in coast mode it uses so little fuel that it outweighs the engine breaking effect with the injectors off in regards to distance.
07-03-2017, 09:37 PM | #15 | |
Rep 16,082
This makes the Eco-pro system counter-intuitive, since in theory complete fuel shut off with the transmission active would use less fuel than with the car in freewheeling mode. A BMW engineer would have to explain why that's not the case. |
bimmer4562960.50 |
07-04-2017, 06:04 AM | #16 | |
Rep 15,858
As I see it, if you are driving at a steady speed and lift off the gas, will the conditions cause the car to slow down too quickly, or will the speed hold quite steady, like down a slight hill? There are conditions where you don't need to add more gas, to keep up the pace, like the steady downhill scenario. You don't want or require engine braking, (not steep enough), so coasting must be more efficient in that condition. If you are driving in gear, (adding more engine losses) you will need to add (use) more gas to keep the speed, compared to the idle consumption. I note this in a VW the family own, with the coasting function. Surprising how often coasting cuts in even on country roads, in what appears to be steady state driving. |
07-04-2017, 10:20 AM | #17 |
Rep 5,997
So driving in eco pro just now I noticed it does kick in back in gear when slowing down to a slower speed to allow engine braking but when coasting at a cruising speed it idled. Presumably during this slowing down portion at lower speed the injectors are off. The parasitic losses and engine braking would require presses of the gas to maintain speed which uses more gas while coasting maintains more momentum if that's what you want using only idling gas. Overall it may save more fuel using that momentum. It doesn't appear to use that idle time to charge the battery however which maybe uses more idle gas unless you let it idle slower than normal. The battery charging only happens when applying the brake, maybe using resistance from the alternator to help slow the car while charging the battery
07-04-2017, 05:48 PM | #18 |
Cheapskate
4447
Rep 4,993
just remember it's not a linear relationship between rpm/throttle and fuel consumption. That's why 6th gear at 60mph uses less gas than 5th gear at 60mph. yes you may have to input less throttle to maintain speed since more torque is going to the wheels in 5th gear, but the higher rpm negates the benefit of less throttle.
cruise control at say 3000rpm may be low fuel consumption by just compensating for drivetrain friction, but it'll be more than the consumption at 800rpm no matter what. the only time i've heard it's bad to go into neutral is when you're going downhill and the momentum/weight of the car is enough to overcome the drivetrain losses in itself. in that case, it makes sense to stay in gear. but on flat ground that's almost never the case. |
07-05-2017, 05:42 AM | #19 |
Rep 1,329
I love this feature. I will take the minimal fuel it takes to idle the engine without any load over the losses to have the car drivetrain breaking when off the throttle during my usual hwy driving any day of the week. This is the only reason I use the eco pro mode during mundane hwy trips.
I would imagine the calculation of fuel savings would be pretty well evaluated before BMW would implement such a feature. Fuel savings is such an area of focus nowadays.
2002 325i sport - sold 2009 135i M sport - sold
2009 550i M sport - sold 2005 M3 6MT Jet Black w/Cinnamon 2016 F30 320i ZSP 2003 E46 325it ZSP 5MT |
07-05-2017, 09:13 AM | #20 | |
Rep 5,997
07-07-2017, 07:00 AM | #21 |
Rep 11
If the instantaneous fuel consumption display is accurate, Eco mode uses 1.2-1.5 l/100km of fuel while coasting on a flat surface. When coasting in gear, the same display will show 0.00 l/100km.
07-07-2017, 07:16 AM | #22 |
Cheapskate
4447
Rep 4,993
coasting in gear is like dragging the brakes. you can't use the instantaneous consumption display for cruising speeds because it will go up and down as the throttle tries to maintain speed. one second it will be 0, the next it'll be 2+.
There is only rolling resistance when coasting in neutral, so the 1.2-1.5 is constant.
BAA435I9.00 |
