01-05-2012, 01:49 AM | #133 | |
Rep 10,185
But should be around 1) 2643 RPM 2) 2101 RPM
BMW if you are reading, I need a job, Please. |
01-05-2012, 01:55 AM | #134 | |
Rep 10,185
Like the X5 Style 375 wheel
01-05-2012, 01:59 AM | #135 | |
Rep 3,566
My 325i (17" tyres) does a tad over 2000 in 6th. I would have thought somewhat less that the above as 7 & 8 are less than 1:1, which I understand 6th will be on the 8 speed sports tranny. Please correct me if i'm wrong. Nice to read your posts again. It's been a while since I was active here. Thanks E90Fleet. Cheers
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
01-05-2012, 07:49 AM | #136 | |
Rep 10,185
The E90 325i Auto is listed as 6th 1:0.69 with a Final gear of 1:3,73 The F30 328i Auto is listed as 8th 1:0,667 with a Final gear of 1:3,154
01-05-2012, 08:28 PM | #137 |
Rep 1,044
I'm hoping someone (E90Fleet?) has some info he or she can share about some of the more obscure options available on US F30s.
For example, what the heck is 5AP, which is listed on my build as "Decoding for no-dazzle high-beam assistance"? Or 6WA, "Instrument cluster with extended contents?" Love this one: 8S4, "Variable light decoding." That takes me back to disco-era nightclub light shows. And, since it only costs US$90, I threw 8TH, Speed limit info" into the order, though I have no earthly idea what it is or does. Another thing, does "smartphone" mean iPhone only? What about Android phones? I ordered 6NL and 6NR (enhanced Bluetooth and BMW Apps) which includes 6NF - Smartphone integration, but can't find anything that describes what phones are supported. Would love to know more about these infotainment/integration options if anyone can enlighten me. |
01-05-2012, 09:43 PM | #138 | |
Rep 784
http://www.bmw.de/de/de/newvehicles/..._pricelist.pdf
Most smartphones should support the Bluetooth connectivity but specific features are dependent on the BT profiles they support. Android phones support the A2DP profile for streaming music files and I think iPhone does as well. With 8TH, the current speed limit will be displayed on the HUD panel I do not know everything you get with 6WA, but the brochures seem to show this panel exclusively. Attached pic shows example. Without 6WA, I believe the EfficientDynamics is a physical pointer indicator. Last edited by pcbrew; 01-05-2012 at 10:34 PM.. Reason: added comment on 8TH |
01-05-2012, 10:18 PM | #139 |
Rep 784
OK, I found some more pictures from the gallery post that shows better what 6WA - Instrument cluster with extended coverage is.
Last edited by pcbrew; 01-09-2012 at 08:05 PM.. Reason: added picture of base panel (no Nav) |
01-05-2012, 10:28 PM | #140 |
Rep 784
FYI, the initial F10 had a similar small LCD panel standard.
From ~March 2011 onward, if you order the HUD ($1300 standalone option), you also get a full black panel, as shown here. Compare these 2 pictures with the first 2 pics in my previous post. |
01-06-2012, 08:35 AM | #141 | |
Rep 1,044
5AP isn't a typo. It's listed as "decoding for no-dazzle high-beam assistance". I guess I'll figure out what that is when I get the car. |
01-08-2012, 10:15 AM | #143 |
Rep 1,181
Drives: G29 Z4 M40i Roadster
In addition to the question above:
I see in the ETK that the wheel bolts are bigger than on an E90 (M14x1,25 in stead of M12x1,50). Does this automatically mean that rims from an E90 won't fit? Unless the thicker bolts, the PCD, Centre Bore and Offset are the same as far I can see in the ETK. Last edited by Joop!; 01-08-2012 at 10:21 AM.. |
01-09-2012, 02:08 PM | #145 | |
Rep 10,185
8J ET:36 8.5J ET:47
01-13-2012, 04:01 PM | #147 |
Rep 4,163
When is m-sport x-drive available? same time as regular m-sport? (july 2012 production?)
'06 bsm e90 330xi : 18" VMR CSL : KW V3 : GruppeM Rep Intake : UUC/Corsa Catback : Hartge Lip : ACS Roof Spoiler
OEM CF Trunk Spoiler : CF Emblems. Pillars. Mirror. Grille : LUXER12 led plate : V1 Hardwired : OG.longtran e90post sticker! circa 2005 |
01-16-2012, 01:33 PM | #148 |
Rep 151
N55 Performance Edition Retrofit Kit
Why has there been no discussion about using the existing N55 Performance Edition Retrofit Kit recently introduced for the E90 335i (increases horsepower from 300 to 320hp and torque from 300 to 332 ft-lbs) for the F30 335i? Isn't this upgrade easily adaptable to the F30 as well? Even with BMW not including it for free, shouldn't the upgrade be immediately usable for the F30? What am I missing here?
Original post for upgrade: http://www.e90post.com/forums/showthread.php?t=553916 |
01-16-2012, 02:01 PM | #149 |
Rep 1,346
Drives: 2011 E92 335 M-Sport
You are trying to assign logic to the equation, and that's not how they operate. Perhaps they are saving it for the MSport version, maybe there's a 335is in the works. Maybe they just keep it in their pocket until the midcycle refresh then try to sell it to the 3-4 year old models as a retrofit. who knows.
01-16-2012, 05:19 PM | #150 |
Rep 103
01-17-2012, 09:27 AM | #151 | |
Rep 151
This $550 BMW upgrade is publicized for the N55 engine in either the E90 335i or the 135i, and obviously will work equally well for the N55 engine in the new F30. BMW has already put this product out there for us. Why aren't people talking about this obvious upgrade in the forums? |
01-20-2012, 03:39 PM | #152 |
Administrator
40828
Rep 21,240
FAQ has been updated with info from our interview with the BMWNA 3 series product manager.
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
01-24-2012, 06:14 AM | #153 |
Rep 150
I am about to order an F30. Which option shall I get in order to have ECO Pro/ECO/Comfort/Sport/Sport Plus modes ? Can someone please clarify which of these modes comes as standard ? I am confused with all these modes and which options they belong to. Thanks a lot.
01-24-2012, 06:34 AM | #154 | |
Moderator / European Editor
1512
Rep 6,754
Best regards, south
