03-18-2018, 12:12 PM | #1 |
¯\_(ツ)_/¯
537
Rep 1,000
How old is your battery?
Was just doing a few things on the car and i noticed that my battery's build date is 30/13 so the 30th week of 2013. I threw a trickle charger on it on the jack points under the hood after noticing the date.
Just wondering since my battery is 5 years old... that's about how long normal car batteries last (~4-6 years). I haven't had any issues. Just wondering how long your guy's batteries have lasted? |
03-18-2018, 12:58 PM | #3 |
Rep 1,503
Here in Phoenix car batteries typically last around 3-4 years. With the 3 other bimmers we bought since moving to AZ we always had one battery replacement under warranty, so within 4 years. My F30 335i is about 5 months out of warranty and still on the original battery, so it’s a bit of an anomaly but also the first that’s only driven a few times a week vs the others that were daily drivers. I’ll probably do a preventative replacement in a couple months before summer hits.
Anyway, that’s my long-winded way of saying that weather (heat in particular) and usage do factor in to the life of a battery but 3-6 years in general sounds about right. |
eluded3005.00 |
03-18-2018, 03:49 PM | #5 | |
Rep 4,439
Drives: '23 X1 28i xDrive
Next time you have your car serviced, I'd have them run a battery test. Getting stuck with a dead battery is rarely fun. |
03-18-2018, 04:06 PM | #6 |
Rep 5,984
I would think AGM batteries and the fact that these are higher output than what you might see in a Ford or Honda and the fact they are trunk mounted should allow them to last longer, so not surprised by the longer life of 8+ years, though there seems to be some variation from people on here. Mine is still strong after 2 years while the flooded cell batteries in my other car often only last 2 years so I get them replaced under warranty. The latest flooded cell battery I've been using the BMW battery tender every couple of weeks and it has made it past the 2 year mark, about 2 years and 4 months still going strong.
03-18-2018, 04:18 PM | #7 |
Rep 2,387
Check the battery with a volt meter in the morning after it's had a chance to discharge over night. Don't start the engine. You should read 12V or over. Anything less, get a new battery. Weird electrical things happen when the battery is weak.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
03-18-2018, 04:20 PM | #8 |
Rep 1,582
Car manufactured in Dec 2011, so 6 yrs and 3 months old and going strong.
Edit: corrected a basic arithmetic error.
2020 M550i (G30) | Carbon Black/Black Nappa | DHP | DAP | Executive | Luxury Seating | Park Asst | Ceramic Controls | Front/Rear Heated Seats | 20" 668M wheels
2021 X3 (G02) | Dark Graphite Metallic/Cognac | Premium | DAP | Front/Rear Heated Seats Sold/Retired: 2012 328i (F30) Last edited by adhrp; 03-19-2018 at 10:59 AM.. |
03-19-2018, 06:43 AM | #10 |
Rep 6,984
5 years as of this past January...zero problems.
03-19-2018, 08:45 AM | #12 |
Rep 1,907
mines 4.5 years old and currently on 78%, only do 5k a year so not bad considering.
Happy Motoring
Evdok |
03-19-2018, 10:28 AM | #13 |
Rep 10,247
03-19-2018, 10:58 AM | #14 |
Rep 1,582
Oh haha, yes! Thanks for catching that. Time for me to go back to grade school
2021 X3 (G02) | Dark Graphite Metallic/Cognac | Premium | DAP | Front/Rear Heated Seats Sold/Retired: 2012 328i (F30) |
03-19-2018, 02:29 PM | #15 |
Rep 77
03-19-2018, 05:42 PM | #16 |
Rep 15,858
03-20-2018, 03:26 AM | #18 |
Rep 441
My original battery is 4 months shy of its 5th birthday. My experience with ordinary lead-acid batteries is that they die suddenly; but I can't be sure about AGM types. But I've now noticed that when I (rarely) have ASS in action, the engine restarts much more quickly than it used to. I suspect my battery may be on its way out. The longest I've ever had a lead-acid battery last was 7 years, but most have been between 3-4 years.
I'll hook my battery up to a diagnostic charger and see if I should get it replaced at its next service due in about 2,500km.
EBII 335i Touring M-Sport (Munich built July 2013)
| 6 Speed Manual | 2VF Adaptive M Suspension | 2VL Variable Sports Steering | 403M wheels | M-Sport brakes | 688 Harman Kardon | 494 Heated Seats | 610 HUD | 322 Comfort Access | 5AC High-Beam Assist | 609 Navigation Professional | |
03-22-2018, 08:17 PM | #20 |
Rep 11
Mine is 05/13 production date but I'm the second owner. I bought it CPO. I'd be happy to get another year out of the battery. That voltage drop to 12.35V when it sits overnight.
I live in Nevada and lead acid battery usually last 2-3 years because of the heat and the battery mounted inside the hood isn't helping. |
03-23-2018, 03:10 AM | #21 |
Rep 441
Overnight, my battery measures just on 12.5V. Hooked up to my AGM diagnostic charger, it seemed to indicate 75% charge. It should be closer to 12.8V on a full charge. Anyhow, I let it charge overnight and I will measure it again after a few days of normal use.
03-23-2018, 06:22 AM | #22 | |
Rep 15,858
If we charge to 100% SOC, after a few days use it will drop back, as the energy management doesn't charge the battery. Leaves capacity for the over-run regeneration. If we don't drive a profile that gets much 'regeneration/harvesting' it is likely it will settle around 80% in normal use. 75 - 80% SOC is not necessarily a sign the battery is on the way out. |
JJS122.50 |
