06-17-2016, 11:58 AM | #1 |
Rep 2,418
Help please! Wheel and Tire size to fit 2015 F30/F32/F36 xdrive
Hi,
Looking to purchase new set of tires. Will these fit x-drive. Unfortunately, I don't know how to use the calculator Can someone let em know the rolling diameter? OPTION 1: 235/40/19 & 265/35/19 (I thought 235/35/19 in the front and 265/30/19 in the rear is more common. Which one is correct)? OPTION 2: 255/35/19 & 285/30/19 OPTION 3: 225/40/19 & 255/35/19 Wheels are FRONT 19X8.5 +30 and REAR 19X10 +45 so I'm hoping to go with a wider tire. Car is lowered on ACS Springs. Lastly, car itself is 2015 BMW 435i xdrive gran coupe |
06-17-2016, 12:32 PM | #2 | |
Rep 617
TIRE COMBO = OVERALL DIAMETER 235/40/19 & 265/35/19 = 671 mm & 668 mm (-0.4%) 235/35/19 & 265/30/19 = 647 mm & 642 mm (-0.8%) 255/35/19 & 285/30/19 = 661 mm & 654 mm (-1.1%) 225/40/19 & 255/35/19 = 663 mm & 661 mm (-0.2%) 235/35/19 & 275/30/19 = 647 mm & 648 mm (+0.1%) ***Summer Clearance Sale*** Sales @ UPWheels.com * Ph. 657.888.4UPW * FacebookDOTcom/UPWheels |
06-17-2016, 12:50 PM | #3 |
Rep 39
I'm about to place an order for wheels to the 440. It should arrive here in Sweden around first week of August so I want to make sure wheels are around when it comes.
First, what's your thoughts on BBS CH-R vs CI-R. Going for black with either of them. 20's. Dealer recommendation based on discussion with BBS is 8,5/20 front with 225/35-20 and 9,5/20 rear with 245/30-20. My initial thinking is that 9,5 with 255 sounds a bit to wide for that tire...? Edit: oops, posted in wrong thread. Sorry. Last edited by Daggen; 06-17-2016 at 12:57 PM.. |
06-20-2016, 02:43 PM | #4 |
Rep 25,989
235/275 is going to be the closest to 0% difference, so it will be the best option, in terms of minimizing stress on your xDrive system. Just make sure that the 275 will fit comfortably on the 10" wheel without causing any rubbing issues. It should be fine since xDrive cars usually sit higher from the factory. Not sure how much of a drop the ACS springs provide, though.
06-22-2016, 09:58 AM | #5 | |
Rep 2,418
06-22-2016, 11:14 AM | #6 | |
Rep 5,140
06-24-2016, 12:33 AM | #7 |
Rep 2,418
06-24-2016, 12:34 AM | #8 | |
Rep 2,418
What would the front need to be if I want to run 285/30/19 in the rear on 10" wide wheel (instead of 9.5)? |
06-24-2016, 01:36 AM | #9 | |
Rep 5,140
With your wheel spec I recommend a 235/275 setup. F: 8.5x19" ET30, 235/35-19 R: 10x19" ET45, 275/30-19 Almost identical diameters which is crucial with xDrive. |
06-24-2016, 11:30 AM | #10 |
Rep 617
