11-25-2020, 04:17 PM | #23 | |
Rep 230
Using Bimmercode. ICM > 3000 daten, F8 > C_SLD_Funktion > aktiv ICM > 3000 daten, F8 > C_Umschaltung_ACC_DCC > zugelassen KOMBI->3003 FZG_Ausstattung, 10->SLD_ENABLE->aktiv. Done. I think this is what you are looking / asking for.
F30 335d xDrive M Sport + 2014 |Birds B3 Dynamic Suspension Kit Springs and Dampers |Pro Media Pack | Visibilty Pack | Interior Comfort Pack | Electric Adjustable Heated Front Seats + Driver Memory
Watsey6430.50 |
11-26-2020, 12:12 PM | #24 | |
Rep 8,502
I have BimmerCode so will try your suggestion. Thanks for posting
11-28-2020, 03:08 PM | #25 | |
Rep 8,502
Changing "ICM > 3000 daten, F8 > C_SLD_Funktion" to "aktiv" changes the functionality of the SET button to operate as LIM on/off. The LIM function works "ICM > 3000 daten, F8 > C_Umschaltung_ACC_DCC > zugelassen" was already in this configuration. No need to change anything on my car. I'm sure that the KOMBI module use to be listed in Bimmercode (or was it in Carly ? Can't remember, but will check) but it's not listed. I'm not currently able to code "KOMBI->3003 FZG_Ausstattung, 10->SLD_ENABLE" to "aktiv". At this point the steering wheel controls operate as : SET button is now the LIM function. One press for On, one press for Off. The Cruise control button (icon of speedo with arrow) is still for On/Off. The "Res" button is now cruise control speed Set and Resume. If cruise is active and I want to pause it (cruise is still available, but is not managing the speed of the car) then it just needs one press of the Cruise button. A second press turns cruise off completely. That's workable, but I don't know whether I can access the KOMBI module whether FZG_Ausstattung, 10->SLD_ENABLE > aktiv is required and what it does. Can you clarify ?
11-28-2020, 03:15 PM | #26 | |
Rep 230
I`m only passing on the coding that Stephan from Bimmercode emailed me to enable the Limit function. Sorry.
11-28-2020, 03:21 PM | #27 | |
Rep 8,502
I've already emailed him about not seeing the KOMBI module - hopefully he will be able to clarify.
11-28-2020, 03:24 PM | #28 |
Rep 230
He is usually quite prompt with a reply in my experience. Cheers
04-03-2023, 11:06 PM | #29 |
Rep 322
I have the newer G series steering wheel with -/+ volume at the top, the < > back/forward in the middle and the scroller wheel in between. Is there any way to program any of these buttons to control the iDrive screen? When I want to input an address, search query or text message while driving, I have to use my voice or the iDrive knob. Voice is highly inaccurate, and the iDrive knob is a pain to rotate the exact number of clicks to get from A to V to E etc, meaning I have to keep my right hand off the steering wheel for a longer period. I'm also not an avid smart phone user, so I can't input this info from my phone using Android Auto/Carplay, so I rely pretty heavily on BMW maps, and being able to control iDrive from steering wheel while driving will probably make using iDrive much simpler.
07-09-2023, 02:52 AM | #31 |
Rep 2
hello everyone. The LIM button is nice but I personally don't use it at all. I just don't like limitations . I thought it would be a great option to program it to run sport or sport + or something like that. how to do it and is it even possible
01-21-2024, 03:56 PM | #32 | |
Rep 12
How do I code the dial to change songs with bluetooth? (I have coded in bluetooth but dial only shows the song playing) |
