04-20-2022, 07:59 PM | #1 |
Rep 1,372
Do wheels need to be the same width to be considered square?
Question: If I mounted a pair of 245/40R18 tires on a 18x8.5 on the front axle and a pair of 245/40R18 tires on a 18x9 on the rear axle, would this be considered a square setup or staggered because the wheel size is different?
If wondering why, just curious to know if there are those who wanted the flexibility to go between a staggered and square setup but not change wheels. Thanks
04-21-2022, 12:35 AM | #2 |
Rep 4,356
your described setup is square, tires... however since your rims are different widths and (speculating) offset, you cannot rotate front to rear, only across the axle.
a true square setup would be four of the same rims(diameter, width, offset) at each corner with the same size tires. fully rotatable if wrapped with non-directional tires |
04-23-2022, 10:30 PM | #4 |
Rep 1,372
It's a typo. Tire width is to be 245mm. The idea would be if I decided to switch from staggered to square would I have to switch wheels or just swap tires.
