07-03-2021, 07:53 AM | #155 |
Rep 2
Hello, i just enabled this and works perfectly…thanks! Does anyone know how to decouple rear fog light from turning on front headlamps? When you activate the rear fog lights it also turns on the headlights. I would love to just have this on with angel eyes drl. Ive also coded rear lci to always on with DRL. Any help greatly appreciated!
07-16-2021, 10:44 PM | #156 |
Rep 246
I've performed this DIY to several F30's, both pre-LCI and LCI, and never ran into any issues. Now I tried it on our F36 LCI and couldn't get it to work. After digging through the forums, I've discovered that LCI tail lights on USA F32, F36, and F82 do not have the actual lights for the rear fog light. In this case, other parts of the tail lights can be used as the fog light. To do this, a different value can be used for Mapping_Nebelschlussl_L_output and Mapping_Nebelschlussl_R_output.
LEFT and Right Values: 0x1A and 0x1B - Inner turn signal 0x1C and 0x1D - rear fog lights that are absent 0x1E and 0x1F - Reverse lights 0x20 and 0x21 - Outer turn signal 0x20 and 0x21 - Third brake light on the rear window After playing with these values, I found that the inner turn signal mimics the fogs the best as they are Bright and light beam is focused rearwards. Also, when the rear fog light is activated and turn signal is on, the inner signal will blink with the outer signal as well. Last edited by DLag30; 07-17-2021 at 02:18 AM.. |
08-05-2021, 01:38 AM | #157 | |
Great Teacher
1102
Rep 1,308
Drives: 06 e91 325ix
I have a modified stock switch but wanted the illuminated button that the EU have. My EU switch also has the unused dial for headlight leveling but it doesn’t matter.
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
09-06-2021, 12:57 PM | #158 |
Rep 174
Drives: BMW 330i Sport Wagon
Rear Fogs
Installed the Euro Switch and coded rear fogs today - that's a welcome symbol in the instrument cluster. I found the switch online for ~$50. I was going to mod the switch myself, but in the end, I think it was worth the wait for the lighted button.
Great guide below. Thanks.
W///AgonHo FB - @WagonHo | IG - @wagon_ho
2019 F31 330i SportWagon | M-Sport | Black Sapphire Metallic over Black Dakota 2016 F31 328i SportWagon | Sport Line | Alpine White over Beige Sensatec (sold - 2019) 2004 B5.5 Volkswagen Passat GLS Wagon | Northern Green | 5-Speed Manual (sold - 2016) BMW CCA | National Capital Chapter since 2019 - SCCA | Washington DC Region since 2021 |
Onizukachan1101.50 |
09-06-2021, 03:03 PM | #159 |
Rep 174
found this one on eBay shipped from the EU. ECS Tuning sells them, too.
09-06-2021, 04:58 PM | #160 |
Great Teacher
1102
Rep 1,308
For anyone looking for one. Much cheaper to look on eBay uk than us eBay or buying new.
04-27-2022, 05:56 AM | #161 |
AH3 Owner
206
Rep 311
Drives: BMW 335i ActiveHybrid 3
Can confirm, this also works with VLAND taillights. Finland doesn't require the left fog light to work for USA imports, but nice to have anyway.
05-23-2022, 10:43 PM | #162 |
Rep 4,551
Drives: 2015 328d xDrive
Typo?
NYC Bimmer259.50 |
05-31-2022, 10:28 AM | #164 |
AH3 Owner
206
Rep 311
02-15-2023, 03:08 PM | #166 | |
Rep 474
USA and Canada clusters have both, front and rear LEDs preinstalled. What the cars don't have - the rear fog light button in the headlight switch assembly to the left of the steering wheel. The green square shows what is not present on the USA/Canada spec F series.
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
Greek F320.00 |
02-15-2023, 03:13 PM | #167 | |
Rep 3
02-15-2023, 03:21 PM | #168 | |
Rep 474
Well, you have to do your own research (size, voltage when powered, required resistors, etc). I've done similar thing by researching the smd LEDs that are installed on the pcb board of the switch. The switch in North America does not have the led for the rear fog light button:
Greek F320.00 |
02-15-2023, 03:33 PM | #169 | |
Rep 3
