BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Touch buttons deteriorating
      12-28-2012, 02:14 AM   #1
Bmwphile
Bmwphile's Avatar
149
Drives: 2020 G20 330i
I'm probably being anal Like my thread on the drooping interior vision mirror
http://www.f30post.com/forums/showthread.php?t=780869
BUT has anyone noticed whether their programmable dash buttons are deteriorating like mine.
I have noticed that the more highly used ones are losing their painted finish. The numeral in the middle is transparent so they can be backlighted, but the surrounding grey/black finish is starting to display a fine crack which is allowing more of the backlighting to show through. I must it admit its only just noticable but it is there. It will probably get worse through further use.
BMWphile
2020 G20 330iM Sport (Tanzanite Blue), Visibility, Comfort, HK
2012 F30 328i Sportline (Mineral Grey)
      12-28-2012, 02:30 AM   #2
zeezz
Drives: F30 328i Sport Line
photo? seems hard to believe this would start happening within the first year.
      12-28-2012, 03:35 AM   #3
Bmwphile
Bmwphile's Avatar
149
As requested
BMWphile
      12-28-2012, 04:47 AM   #4
NYmsportF30
Drives: 335i m sport estroil blue
Oh wow I see what you mean, I'm surprised that would happen so soon or at all for that matter. Everyone's hands and natural oils are different and cause different wearing. I'm pretty sure you can get the pieces replaced, I know back on my family's 2000 5er the center console buttons would pop off or break rather easy and we were able to get replacements.
2013 335i ///M-Sport, Estoril Blue II, Alum Hex trim with Estoril accent, Black leatherette, Navigation system, Sport automatic with shift paddles, Heated front seats, Bluetooth, rearview camera with park distance control.
      12-28-2012, 04:48 AM   #5
RWFG
Drives: 328i M Sport Auto
I have that too, on num key "7", and thought that I am the only one.
Seems to be a guarantee issue then.
You can never go plenty fast enough!
      12-28-2012, 05:35 AM   #6
Bmwphile
Bmwphile's Avatar
149
It's good to hear the buttons can be replaced. I'll wait to my first service to have the problem rectified. The buttons function perfectly well.
I think my skin oils are quite normal and I don't use any cosmetic hand creams or moisturisers. Nothing else I touch has undergone the same changes
BMWphile
      12-28-2012, 08:23 AM   #7
ES_TRADER
Drives: 328i, 335i, M3, 535i, X5, 36M
2014 Ford Raptor  [0.00]
2012 328i E92  [10.00]
2013 X5  [0.00]
2013 335i F30  [8.00]
1990 Toyota Previa  [0.00]
1997 E36 M3  [10.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
Do you wear hand lotion? Some have reported this happening on e9xs as well when wearing lotion.
      12-28-2012, 08:26 AM   #8
Elk
Drives: 2012 335i
The buttons appear cracked. This is very odd as a wear pattern.
I hope getting new buttons is a trivial process for you.
      12-28-2012, 08:55 AM   #9
wdlv
wdlv's Avatar
Drives: 2019 X5 40i M Sport
Strange, doesn't look cracked, just as though the paint is wearing thin with oil or petroleum. Also, perhaps oil got behind the buttons?
Try a little degreaser in a small section and see what happens.
      12-28-2012, 09:16 AM   #10
howiegu
Member
howiegu's Avatar
Drives: 22%E2%80%99 M440
That's odd...clip your nails often?-
      12-28-2012, 09:20 AM   #11
BavarianFanatic
Too much is never enough
Drives: Too Many
Do you use your fingertips or nails when you depress the buttons?
I've seen this before in a few other cars. The early Cadillac CTS was notorious for this. They always replaced them under warranty. I imagine you'll get BMW to do the same.
DON'T try to use a degreaser or anything else on them. You'll just wipe out the rest of the paint and for sure be denied any sort of warranty coverage.
What's your build date?
      12-28-2012, 09:40 AM   #12
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
I hardly use mine, but that's disconcerting for sure...
SOLD: 2012 335i Mineral Gray
      12-28-2012, 09:45 AM   #13
JoeyO
Drives: silver car
That looks like something went wrong with the injection mold process. Not necessarily a wear problem. Maybe some usage is bringing the problem to light but those parts were never made right from the start. Maybe it was a bad batch?
      12-28-2012, 10:00 AM   #14
The X Men
Drives: 2013 X3 35i
Sure looks like they use the wrong type of paint for that application or BMW didnt use enough coats. I hope they can replace just the buttons and not the whole unit.
      12-28-2012, 10:29 AM   #15
jzcrna
Drives: 2019 M2 Competition
That's terrible!! I miss the rubberish material of the E90s. It seemed much more durable. IMHO
      12-28-2012, 10:45 AM   #16
tdizzle
Drives: 2017 F80 ZCP
I had that happen on my truck, but it was after about 4 years. Most definitely it was from wear. The paint they used was quite thin, I guess they wanted the numbers to illuminate but after awhile the most often touched areas wore down and the light would show through.
Yours is a bit different than my truck though. It's hard to tell if the paint is wearing off or not in the picture. In any case, in my truck, they just replaced the whole unit (6 disk in dash cd changer/mp3) and didnt bother with the buttons. I was surprised, but I guess under warranty, that's how they do things at Ford. It was a 30min process, so I can't complain. Although, it did start to happen again right before I traded it in earlier this year for my car.
      12-28-2012, 03:20 PM   #17
Bmwphile
Bmwphile's Avatar
149
Don't think this will work as the actual paint is missing
BMWphile
      12-28-2012, 03:26 PM   #18
Bmwphile
Bmwphile's Avatar
149
Do YOU think my nails are too long??
BMWphile
      12-28-2012, 03:27 PM   #19
Bmwphile
Bmwphile's Avatar
149
Fingertips. March 2012
BMWphile
      12-28-2012, 03:33 PM   #20
Cyberdemon
Cyberdemon's Avatar
1538
Drives: 2020 X5 40i, 2018 M3 Comp
When you wash the car, do you ever use any kind of chemical or solvent while wiping down the dashboard? (Or if you have someone else wash the car, do you know what they use to spray their rags?)
That's not wearing thin from abrasion/normal rubbing (to witness that, look at a soft touch painted mouse or cell phone after a few years) it appears that some type of oil or residue has gotten under those keys via the open area (number) and started to seep behind which is causing the paint to shrink back.
Do you have a significant other, child, guest who ever wears any hand lotions?
Otherwise do you wipe the buttons down with any type of off the shelf cleaner when detailing the car?
Either of those would be my guest - I design products with soft touch paint and this is exactly the type of failure you see after exposure to any type of oleic acid or alcohol. I see you're in Australia too so the extreme heat the car may see may also be part of the issue.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette
      12-28-2012, 03:59 PM   #21
Bmwphile
Bmwphile's Avatar
149
Thanks for your comments, Cyberdemon.
No, I am the only one who touches the keys. I rarely wipe the keys. The only gentle wiping would be done with a soft (dry) microfibre cloth.
No alcohol used on my hands.
Could be related to the heat, but I don't think our climate would be any worse than in say southern California
BMWphile
      12-28-2012, 04:11 PM   #22
Cyberdemon
Cyberdemon's Avatar
1538
It's possible it was a crap formulation of the paint then...if it is then a lot of owners will have this issue then (or it could be due to a specific vendor/batch of parts)
Will have to wait and see, not sure if the dealer will be willing to do much since it's technically just cosmetic and that most likely requires replacing the entire unit.
