06-22-2015, 11:52 AM | #8801 |
Rep 213
Drives: 2019 X3 m40i
Shawn - I successfully coded my 2013 F30 in Dec 2014. I just had a bluetooth issue/update at the dealer that wiped some of the coding. Can I run with the previous version of software to re-code or do I need an updated version/database? If so, can you please send that to me?
Thanks in advance. |
06-22-2015, 06:58 PM | #8802 | |
Rep 213
06-22-2015, 07:42 PM | #8803 | ||
Rep 40,774
PM sent.
06-23-2015, 05:42 AM | #8804 |
Rep 22
Hi Shawn,
It seems I can't change the car series despite changing the PC date ahead 4 days. It still shows 2 days remaining and there are no other selection in the drop down menu asides from F999. I've even tried putting the date forward even more but still no change. Any ideas? Thx! |
06-23-2015, 11:31 AM | #8805 |
Rep 6
Hello everyone, recently I got a BMW M135i f20 2013 with fem module defective, I got another used module, but nobody knows encode these modules, e-sys can encode this used module? Any tutorial or someone could give me an aid, and if someone could send me the software link, token and what is needed to accomplish this task, i will be very grateful, thanks in advance.
06-23-2015, 11:53 AM | #8806 | |
Rep 40,774
06-23-2015, 12:12 PM | #8807 | |
Rep 40,774
PM sent.
06-23-2015, 12:12 PM | #8808 |
Rep 3,659
Drives: 981 Cayman GTS
Hi Shawn,
I have been following this forum for a long time but this my first time posting. I want to code 2TB for my F30 328i but I'm a little confused in fact. In some tutorials, only 205 is replaced by 2TB in an xml file via E-Sys. However, I also seen in another thread people mentioning doing this: EGS/3000 Applikation -> Sportschalter_alt -> aktiv EGS/3000 Applikation -> Sportschalter -> aktiv EGS/3000 Applikation -> LC -> aktiv I know the last one is for launch control but which procedure should I follow? Or should I do the both? Can you also please PM me if you have PSdZDATA 55.4 full? |
06-23-2015, 12:19 PM | #8809 | |
Rep 40,774
Why do you need Full version? Are you going to flash new firmware on ECU's?
06-23-2015, 12:34 PM | #8810 | |
Rep 3,659
Thanks a lot for the help! |
06-23-2015, 12:40 PM | #8811 | |
Rep 40,774
Anyway, toss out everything you have and think you know, and start over. PM sent.
06-23-2015, 02:53 PM | #8812 |
Rep 6
06-23-2015, 02:55 PM | #8813 |
Rep 40,774
PM sent.
06-23-2015, 04:26 PM | #8814 | |
Rep 1,858
however...., I got a token error when i tried to read the FDL .... when I reset the date back to the correct day. I needed to leave the system date on the laptop ahead in order to read FDL Data and code. this avoided the token error |
06-23-2015, 04:30 PM | #8815 |
Rep 53
Hi All.
I have an f30 European car that came with navi professional but with crappy basic sound meaning no tweeters in the doors... I purchased the BMW Alpine HIFI upgrade kit with 2 tweeters 2 midrange speakers and an amp plus ordered the 2 door trims that allow mounting the tweeters that cam with the set. I had the set installed by a local car audio shop they did a very good job. Immediately i have noticed a huge improvement in the sound but had to turn down the bass and treble way low in order not to distort the sound... This is as I read due to the fact that the head unit is set a way to preamp the sound in a way to compensate the lack of tweeters on the standard setup but now when there is an amp connected this would be needed to be recoded. The manual talks about taking it to Bmw and let them recode it through the ISTA service system but this takes time and I wanted a faster way around this so I presumed it could be done via eSYS. So I went today to a garage near by where I know they do the coding and the guy asks me so what SA is this system as he told me he can't find it in the menu. The only thing he could select was the HI FI 676 or the HK 688 and something called m performance sound but no Alpine HIFI... I settled for the HI FI 676 as the HK is surround sound and probably not the right choice... Result is the distorted pre amped head unit setting is now gone and I can put the treble and bass to the mid setting and play the music on a decent volume without the sound being distorted as was the case before but is this it? Should I code this different and if so what how via eSYS? Also after the coding will there be more settings etc? Or is this ok and should I leave it as is? Thx Sash |
06-23-2015, 07:04 PM | #8816 | ||
Rep 22
I've tried rebooting etc and still the same. BTW I'm using Windows 8.1, so not sure if the OS is creating the problem. However, I've read that it works fine for others on Windows 8.1. Anyway, I'm going to try it on a Windows 7 laptop later tonight and see if I can get it to work. Any further ideas on correcting this issue is appreciated. Thx! Quote:
06-23-2015, 08:35 PM | #8817 | |
Rep 40,774
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 06-23-2015 at 08:44 PM.. |
06-23-2015, 08:43 PM | #8818 | |
Rep 40,774
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 06-23-2015 at 08:49 PM.. |
06-23-2015, 08:47 PM | #8819 | |
Rep 40,774
06-23-2015, 11:31 PM | #8820 |
Rep 22
Alright, got it working on Windows 7, so I assume it was the Windows 8 problem. One quick question, please excuse my ignorance, as I have a F36, I assume then that I should choose F036 in the Car Series selection, right? Thx
06-24-2015, 01:07 AM | #8821 | ||
Rep 53
1. Delete the SA 676 2. Recode back Standard / Basic sound as it was before 3. Add to FA HO-Word = HIFI, which is the Alpine Retrofit, then VO Code Head Unit and Amp When u say then code HU and Amp u mean when adding the wording on stage 3 above just hit code in eSYS? Kind regards S. Last edited by Lazarini; 06-24-2015 at 03:23 AM.. |
06-24-2015, 06:18 AM | #8822 | |
Rep 40,774
Yes, you select F36 Car Series.
