BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > GraceNote Database
      04-02-2015, 07:51 AM   #67
Rick4345
Rick4345's Avatar
Drives: 2012 328i Mineral Gray
I'm having trouble too. This is what I downloaded from the alternate source Where am I goofing up.
      04-09-2015, 06:33 PM   #68
Rick4345
Rick4345's Avatar
Lightbulb Duh
First thing. I'm not the most computer savvy person going. I've been trying to figure out why I couldn't get the download from the DVD to the car.
This is what I found out by pure dumb luck:
When you format the DVD, you can choose a setting similar to "USE LIKE A USB FLASH DRIVE" by right clicking on your DVD Drive. Mine was "F".
That way it doesn't finalize the DVD and it is just like using a USB Flash Drive.
It was to the point, I even asked Shawnsheridan for help and he was stumped. Silly me.
I din't know if this made a huge difference or not, but I did download the file by renaming it a torrent file and using BIT TORRENT to accomplish that.
      04-09-2015, 06:45 PM   #69
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
Correct. Session must be Finalized in order to be read by Head Unit. I was not aware you did not do so.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
      05-18-2015, 01:03 PM   #70
Fronzdan
Drives: 335i xDrive MSport 6MT
Just a tip for anyone doing the Gracenote update...
It probably takes a good 40 min to load onto the HDD. Also, DON'T exit the screen where the percentage done starts counting up. I'm not sure if this halts the process or not, but when you go back in you won't see the percentage, you won't be able to restart the installation and all your Connections will be gone. I wasn't sure if it was still going or not and had no feedback, so I had to reset iDrive and start it all over again.
Edited to add...
Blah, it didn't work. It finally got to 100% and then just went back to where it allows you to start the installation. The version number on the HDD vs the DVD is still different. Help!
...Just burned it again DAO method and made sure the session was closed. Will see what happens.
....Success! That version of the dvd did the trick.
      06-20-2015, 03:00 AM   #71
lepniak
Drives: E87 118d 2008r.
shawnsheridan can you send me gracenote DB?
I have CIC navigation with version ECE Road Map Europe Premium and GraceNote DB version 1-01/08
Thank you for PM
      06-20-2015, 08:51 AM   #72
shawnsheridan
Thank you for PM
PM sent.
      06-20-2015, 01:14 PM   #73
nyranger74
Drives: 2013 M5 Alpine White
Hey, can you PM me update for NBT for US. Also, will this allow for Sirius Channel logos? Thanks!
      06-20-2015, 01:26 PM   #74
shawnsheridan
Gracenote has nothing to do with SDARS. It is for DVD's only.
Try FDL coding HU_NBT => SDARS_ALBUM_ART = aktiv.
PM sent.
Forum Jump
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
