BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Bootmod3 HP GAIN??
      12-17-2019, 06:05 PM   #1
silentF30
silentF30's Avatar
Drives: 2015 F30 Msport
Lightbulb Bootmod3 HP GAIN??
      12-17-2019, 06:14 PM   #2
chowser51
chowser51's Avatar
Drives: F33 430 and F39 M35i
which engine?
I've got an appointment Thursday for my B46 running stage 1 - 93 octane.
Going to do the first run stock, then flash back for the last two runs.
Hoping my snow tires don't mess anything up.
      12-17-2019, 06:16 PM   #3
upsidedownfunnel
Drives: 2014 335i
2014 BMW 335i  [0.00]
Which engine?
Few people would waste time/money dynoing a stage 1 tune. You'd have to run the car with a stock tune, flash the DME, then run again on the same day on the same dyno in the same conditions to get a real comparison.
There is a very noticeable bump in power especially in the mid-range where you spend most of your time. It's incredibly easy getting a lot of power from a modern turbocharged car. You could spend thousands in mods on a naturally aspirated engine and not get as much power as a stage 1 BM3 on N55.
Most people seem to mostly concentrate on peak HP numbers when it's really the area under the curve that matters most. Peak figures may not be that much higher, but you are gaining a lot of real power in the lower engine speeds.
      12-17-2019, 06:47 PM   #4
silentF30
silentF30's Avatar
Would the tune give more/less hp depending on the engine? I have a n26
      12-17-2019, 07:18 PM   #5
IK6SPEED
Drives: BMW M3 / AH3
So you think that a tune in a 4 cylinder engine would give you the same HP increase as a tune on a 6 cylinder engine?
Or even a tune on a 6 cylinder engine running Premium 91 octane in Denver is going to give you the same increase as Premium in Los Angeles? Or even Premium 93 in Texas?
Seems you need to understand the basics before asking the questions you pose.
      12-17-2019, 11:05 PM   #6
Mkswoosh
Mkswoosh's Avatar
93
Drives: 2018 340xi tanzanite blue
Everyone is throwing different numbers for different reasons. Motor, fuel type, dyno conditions, the car itself won’t be the same whether it be b58 vs b58. That’s why bm3 gives you a percentage increase range on their webpage.
      12-18-2019, 12:39 AM   #7
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
Here we go again...people post haven't done dyno either.
eluded3043.00
      12-18-2019, 02:44 AM   #8
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
3043
Drives: 340 6MT, 50e, others
+42.6 hp at the wheel
      12-18-2019, 01:19 PM   #9
silentF30
silentF30's Avatar
Makes sense. Thank you for the knowledge.
bmw (3)series, bootmod3, dyno, f30 3 series, tune
