BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Winter Wheel ?
Vorsteiner
      05-28-2013, 02:20 PM   #1
PSUBALL10
PSUBALL10's Avatar
Drives: 2018 X5
Winter Wheel ?
Will the type 158s from the e90 fit on my 335xi sport line? Here are the specs on the 158s:
Type 158 (17x8 ET34 225/45 R17)
These were my winter wheels for my e90, and I was hoping to use them as winter wheels for my f30.
      05-28-2013, 04:28 PM   #2
Buzzman
Drives: 2016 F26 M40i
Yes they will and here is the proof. I have the same wheels for winter. The only thing is that your speedo will be slightly "slower"
2016 F26 Alpine White M40i
2014 F25 Alpine White 35i Sport - Retired
2012 F30 Melbourne Red 335i Sport Line - Retired
2007 E92 Space Grey - Retired
      05-28-2013, 10:25 PM   #3
PSUBALL10
PSUBALL10's Avatar
Drives: 2018 X5
Awesome! Thank you very much
      05-29-2013, 01:09 AM   #4
free2d
Drives: F30 335
The front brake will not rub? Calipers and rotors?
      05-29-2013, 09:16 AM   #5
R12ax7
R12ax7's Avatar
63
Drives: 2011 328i M-sport 6MT
2011 328i  [0.00]
+1...I was under the impression you would need at least a spacer in the front to prevent break rubbing. I am looking to use some style 193s for my winters. I would think the 193s should have a little more clearance due to the extra inch in diameter but I am not sue if they have the same offset as the 158s
340i | BSM/Black | Msport | Track | 6MT (MPerf) | 442s
      05-29-2013, 01:45 PM   #6
Buzzman
Nope, they work just great, no rubbing either externally (tire on body) or internally (brake and such). The 158s have the same offset and width as F30 (non-staggered) wheels, minus the diameter 17 vs 18.
My wheels were transferred from my E92 to the F30 by my dealer when I took delivery and the master tech knew they would fit. Which pissed off the parts guy who was more than ready to sell me a BMW OEM winter package for a few Ks.
      05-29-2013, 01:54 PM   #7
Buzzman
193s are 8x18 Front, ET 34 and 8,5x18 Rear, ET 37.
Here is a good place to check specs for BMW OEM Wheels.
http://www.bmwstylewheels.com/3
      05-29-2013, 03:27 PM   #8
R12ax7
R12ax7's Avatar
63
2011 328i  [0.00]
Great, thanks. So the fronts are the same width and offset as the 158s so I should be good to go.
      05-29-2013, 04:08 PM   #9
Orient330iNYC
Drives: 2013 335i M Sport
the opposite actually,the speedometer and odometer will read higher than actual with E90 sized tires.
Past: 2004 S60R 6MT
Past: 2007 E90 335i 6MT
Past: 2010 335xi ZMP, MPPK, MPE
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
      05-29-2013, 08:25 PM   #10
Buzzman
A typo, I meant speed will be slower (then the speedometer reading) but you are correct.
      05-29-2013, 10:32 PM   #11
free2d
Drives: F30 335
Cool. May try when got spare time. Reason is that my E90 325 have AD08 on it. Wana change the F30 335 RFT out.
      06-24-2013, 01:06 AM   #12
nogren
Drives: F31 330d xDrive
Guys, I thought the bolt dimension was different, i.e. M12 in E9x and M14 on F3x?
But perhaps the new wheel nuts will work well through the old rim, if the holes are wide enough ...
/n
      06-24-2013, 03:03 PM   #13
remmib
remmib's Avatar
Norway
1154
Drives: 2013 F10 520d M-Sport
/n
Yes, correct on the bolt size, but the hole is large enough to fit M14 bolts.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      06-24-2013, 04:09 PM   #14
nogren
Thanks, to bad I already bought a 2nd set of 413 rims to put studded tires on then. :-(
Niklas
