BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Alpina Replicas & wheel offset
VIBE Motorsports
      06-21-2013, 06:24 PM   #1
MVDsF30
MVDsF30's Avatar
Drives: 2013 335i
So here's my question. I am thinking about getting Alpina B7 style wheels. I found a set which are 19x8.5 with a 35 offset. There is also a staggered set available with I believe with a 19x9 or 19x9.5 rear but has a 20 offset.
I am not to familiar about the offset on which will fit and what looks good. What are your opinions?
      06-21-2013, 07:11 PM   #2
MVDsF30
MVDsF30's Avatar
Drives: 2013 335i
Thanks for the info. Do you think I should run a squared set-up or go with a slightly staggered with a 255/35/19 on the rear and keep the 225/40/19 up front.
      06-21-2013, 07:56 PM   #3
momo3605
Drives: 2016 M4
This is a great idea! Alpina wheels would look awesome on the F30. Also, if you do 8.5 all around, then do a 245 square or 245/255. I have 245/255 on a 8.5 inch square setup, only because I didn't want to have less grip in the back than stock. I already get wheel spin with 255 in the back when flooring it. But if you prefer to be able to rotate, then 245 will be your best choice.
      06-28-2013, 07:11 PM   #4
pkancel
pkancel's Avatar
Drives: G30-Msport,435iGC, Audi A3
Momo, 255-35-19 should be good all around too on 19x8.5 yes, with a et33?
      06-29-2013, 01:51 PM   #5
richb811
richb811's Avatar
312
Drives: 2011 E92 JZB M3, 2000 750iL
Unless you are making custom fender flares, the 20" offset won't work
40-45 is a good fitment for the rear. You can use a spacer on the 19x8.5 ET35 to push it out a little and keep the setup squared too.
      06-30-2013, 03:49 PM   #6
MVDsF30
MVDsF30's Avatar
Drives: 2013 335i
Has anyone seen the M5 wheel on an F30 yet model 166 I think?
      07-06-2013, 08:43 PM   #7
pkancel
pkancel's Avatar
yes, look at the gallery or wheels and tires section, one guy has them and they look great. The Former M5 yes?
