BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > VOSSEN CV1
      07-11-2013, 04:26 AM   #1
mill328
Drives: BLACK F30
VOSSEN CV1
Hi everyone I'm new here.Considering putting on VOSSEN CV1 matte silver f.20"x9" r.20"x10.5".I know that the front offset should be et35 but I'm hesitate wether putting on et42 or et45 for the rear wheels.By the way im gonna lower my car so I'm afraid its gonna rub the fender if the wheel came out of the fender too much.And what tire profile will perfectly fit my new rims?Anybody helppp
      07-11-2013, 10:40 AM   #2
pkancel
pkancel's Avatar
Drives: G30-Msport,435iGC, Audi A3
Search forum, there are two conversations discussing 20s recently on this same size set up started by a member from Italy.
      07-11-2013, 11:23 AM   #3
mill328
Drives: BLACK F30
Thank you very much!already got the tires size but still confuse wether go on et42 or et45 for the rear wheels.Another question is "Is the offset will effect the concavity of the rims??
      07-11-2013, 04:24 PM   #4
pkancel
pkancel's Avatar
The offset can have an effect on the concavity but its typically that combined with the wheel size. In other words, a 20inch of the same wheel can have more concavity than a 19 but its not always the case. When you locate a wheel, like the Vossen, ask them if there is any difference in concavity between offsets. I am guessing not so much unless the offset difference is signficant, like between a rear wheel drive car and a car like ours with a more positive offset.
      07-12-2013, 09:24 AM   #5
mill328
Drives: BLACK F30
Thanks very much for your advice
