BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding for paddle shift retrofit
      03-20-2015, 08:37 PM   #1
Coolala
Japan
38
Drives: 2013 F30
Hi,
I would like to know the exact way (just enough way) to code for paddle shift retrofit.
1. Remove 205 and add 2TB
2. VO code FEM_BODY
3. FDL code FEM_BODY => PADDLES_VERBAUT = aktiv.
Is it correct and enough?
Just curious I found most ppl mentioned VO code ALL modules, but I think it is not necessary right?
Someone said VO code FEM_BODY, EGS, ICM , KOMBI
Some other said VO code FEM_BODY, EGS, ICM, GWS
What is the correct way then?
Any help gratefully appreciated.
      03-21-2015, 02:03 AM   #2
Chris@codemybimmer
Chris@codemybimmer's Avatar
Drives: AW F30 328i Xdrive
You only need to VO code FEM Body if all you want is the functionality.
VO coding ICM and KOMBI will give you sport transmission (faster gear shifts) and Sport+ functionality from ICM + Sport+ icon in the KOMBI
not sure if VO coding EGS does anything
      03-21-2015, 09:55 PM   #3
Coolala
Japan
38
Drives: 2013 F30
Very detail explanation. Thanks a lot!
      03-22-2015, 08:28 AM   #4
JP-76
Drives: 335i
So are you saying that you don't need to flash EGS to get true sport program?
I was in that consumption that automatic- and sport-automatic-transmissions have different software?
Present: F30 335XiA M-Sport Individual
Ex: 335dA Individual MY2007 "LCI"
      03-22-2015, 11:50 PM   #5
Halsifer
Halsifer's Avatar
Drives: 2018 Audi RS7
Yes, the transmission supposedly has different software. I would code FEM_BODY, EGS, ICM, and KOMBI, just to be safe. It's not like it's gonna hurt anything.
2018 Audi RS7 4.0T
2006 BMW e46 330Ci Convertible ZHP
2010 Audi S5 4.2L [Sold]
2014 BMW 335i xDrive M-Sport [Sold]
2010 Audi A6 3.0T [Sold]
      03-23-2015, 12:11 AM   #6
JP-76
Drives: 335i
Okay, but it is still going to need to flash a "sport"-SW in the EGS ecu (not just changing parametres aka coding) to get the "factory"-sport-transmission?
I'm asking because I'm trying to do a OEM sport-transmission retrofit 2TB to my 335i F30 and I want everything to work like it was from factory
So far I know I need sport-steeringwheel with paddles, sport-gearlever, some wiring from steeringwheel and the codings mentioned above, but do I/ can I / is it even nesessary to flash the EGS as it was in the E60 2TB retrofit
      03-23-2015, 04:21 AM   #7
Halsifer
Halsifer's Avatar
No, you should not need to flash, just VO code. It's not using any different software. All the firmware on a base 335i and a fully equipped 335i should be identical. The only difference would be the parameters set and features enabled based on what modules/equipment you have. (Hence the reason for FDL and VO coding).
I believe it is unnecessary to flash. If you want to be thorough, I would modify the FA by adding 2TB, write the FA back to the car, and VO code every ECU.
2018 Audi RS7 4.0T
      03-23-2015, 05:49 AM   #8
JP-76
Drives: 335i
I'm going to update the I-step first to 54.1 and after that add 2TB to FA and code the whole vehicle anyway so this no need to flash with different SW is very good information.
Thanks!
      03-23-2015, 11:30 AM   #9
Halsifer
Halsifer's Avatar
Thanks!
Yep! Also, if you are updating your vehicle to 54.1 yourself, just change your vehicle's FA first and then update all modules. You won't need to code it in later then.
2018 Audi RS7 4.0T
      03-23-2015, 02:57 PM   #10
JP-76
Drives: 335i
Good point, thanks.
Only have to install sport gearlever before upgrading I-step, otherwise it's going to stuck on the gearlever version mismatch
      03-31-2015, 09:25 PM   #11
JP-76
Drives: 335i
Ok, I-step is upgrated to 54.3 and coded for 2TB. Everything works fine without sport-gearlever so it's only coding as said earlier
Next question: I have sport-steering wheel with lane departure warning without paddles at the moment. Can I just buy normal sport-steering wheel with paddles and transfer the LDW-motor from the old wheel or do I need to buy steering wheel with LDW?
      04-04-2015, 12:33 AM   #12
JP-76
Drives: 335i
Well, thanks for your help guys
Figured this out by myself....
      09-12-2016, 10:11 AM   #13
thatg20guy
thatg20guy's Avatar
Drives: 2021 M340i
So I replaced my sportline wheel (no paddles) with an M-sport wheel that had paddles. I had previously added 2TB to my car and VO coded FEM, EGS, ICM and KOMBI so I've had those functionalities for a while. I read on other posts that if I had FEM BODY 3190 PADDLES_VERBAUT then that means my car was pre-wired for shift paddles.
However, after starting the car, the paddles did not work - I coded the PADDLES_VERBAUT back to nichtaktiv, restarted the car, and re-coded it to aktiv and it still didn't work. Does that mean my car isn't pre-wired and the only reason that folder in FEM BODY exists is because I VO coded 2TB?
      09-12-2016, 10:35 AM   #14
atzebmw
Drives: Tesla Model 3
I think the folder FEM BODY 3190 PADDLES_VERBAUT can be found at all cars, also with manual gearshift.
The existing coding values in all ecus of all cars are the same.
But some codings are not activated.
      02-04-2018, 05:17 AM   #15
Goggy_66
Drives: F30 330e
Hello!
I have installed paddles on my 330th. Activation with Esys should be done. The guy who will perform the activation discovered that my car does not have the same (sports) gearbox as the usual F30.
So my question is which parameters would change in my car for it to work?
Thanks!
      02-04-2018, 05:20 AM   #16
Goggy_66
Drives: F30 330e
That's how it looks!
      09-05-2020, 08:53 AM   #17
RudolfMeister
Drives: F30 335d 2016
F30 2016 retrofit f1
Hi guys,
I have seen kies motorsports tutorial on how to retrofit paddle shifters. I have done everithing right, coded the car via bimercode, but it is not working. I am 100% positive my car is previred, because i have just duble check it now. Does anyine know what the issue might be? Does it need some extended coding? Thank
code, paddle, shift
