03-08-2014, 06:01 PM | #23 |
Rep 1,130
Drives: '16 340i AW MSport
Yup thats where mine is located, completely in the center console. 1 Aux Cable for audio 1 USB cable for power. No visible cables.
03-08-2014, 09:21 PM | #24 |
6579
Rep 5,304
So I've been using this for the past couple of days. It works like it should but there is a few seconds of delay for any touch commands. For example... if you touch the "Next Track" icon, it doesn't execute the command until 3-4 seconds later. Minor inconvenience, but still kind of annoying.
03-10-2014, 03:15 AM | #25 |
6579
Rep 5,304
So after one more day of using this, I'm a little fed up with it. I am going to return it. Every time a playlist comes to an end, I have to reconnect the Airplay. The problem is that the Airplay option just disappears.
03-10-2014, 07:48 AM | #26 |
Rep 1,130
ex o,
What device? That's wierd I've never had a drop out at all of AirPlay connectivity ;\ |
03-10-2014, 05:19 PM | #27 |
6579
Rep 5,304
03-12-2014, 08:00 AM | #29 |
Rep 1,130
03-12-2014, 10:11 PM | #30 | |
6579
Rep 5,304
Does it take a few seconds to respond to touch commands? For me it would take about 2-3 seconds for every command to execute. I'm back to just plugging in a 1/8" cable and the touch commands are executed immediately. |
03-18-2014, 12:50 PM | #31 | |
Two turbos are better than one!
119
Rep 404
So, is anyone using the Auris Skye and what are your impressions?
Thanks Quote:
03-18-2014, 01:25 PM | #32 |
Rep 6,248
04-23-2014, 03:38 PM | #36 |
Rep 386
Received it last night. Works like a charm.
Question for those who use this or any device plugged into the AUX port...is there any way to skip tracks or control the music (besides volume) directly from the car, or is that a limitation of running it through auxiliary? With Bluetooth audio, you are able to control anything without even touching the phone. Just wondering if it's an aux thing or if I'm missing out on something... |
05-21-2014, 08:57 PM | #37 | |
Rep 1,130
10-21-2014, 11:10 PM | #38 |
267
Rep 2,741
i have it setup in an e92 with an upgraded DAC...sounds way better with logic 7 off if anyone is curious with right EQ settings its nice and clean
used airport express not the air enabler but mostly same thing upgrade the DAC if people don't like the quality output |
12-05-2014, 12:15 AM | #40 |
267
Rep 2,741
you open it and take out the power supply, you place a small device that takes input and out put soldered with a USB cable to power it directly and thats it
google airplay car there should be a tutorial explaining everything..check my thread in the audio section as well i posted up a pic |
