BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Questions for wheels gurus here: Square set up
proTUNING Freaks
      02-21-2013, 02:08 AM   #1
lmaleke
Hong Kong
Drives: shifting priorities for now...
Talking Questions for wheels gurus here: Square set up
Quick questions for all wheels/suspension gurus here:
  1. Any effect on how the car will handle if one were to have a square set up on a non x-drive?
  2. Will a square set up trigger error codes such as, blinking ESP, etc?
  3. For 20x8.5 with either et36 or et34 all around, which ET will fit nicely for both front and rear? I mean clear the brakes etc?
  4. As far as tires, perhaps would go with either: 235/35ZR20 or 245/35ZR20 all around. Which size would you recommend me getting?
  5. Last but not least, has anyone have any personal experience on running a square set up on a non x-drive?
Thanks!
      02-21-2013, 08:48 AM   #2
diesel86
Drives: 2012 BMW 328i Sportline
Unless you opted for the summer option w/ and M-Sport, all F30's come from the factory with a square setup; so codes should not be an issue. My F30 Sportline has 225/45-18's on all four corners.
2012 328i Sportline - Black Sapphire Metallic - 8AT Sport
I pronounce it "Beemer" and turn my fog lights on even when it's not foggy.
      02-21-2013, 09:08 AM   #3
lmaleke
Hong Kong
Talking
Thanks diesel!
Now, for 20x8.5 all around, which et should I be choosing to clear the Msport brakes? et36 or et34?
      02-21-2013, 10:40 AM   #4
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
I would go with 34, but that is still not aggressive enough for the rear if you ask me.
8.5 with an ET around 25-30 would look good both from and rear. But no matter what you choose with a square setup on the F30 the front wil be more aggressive.
8.5 ET25 is about the same up front as 1013mm has on his HRE's. So quite aggressive...
8.5 ET25 equals a 9.5 ET38 in the back which all the M5 reps are running.
      02-22-2013, 12:31 AM   #5
lmaleke
Hong Kong
Talking
Got it. Thanks Gracie Rossi!
I'm getting that, for the rear, a set of 5mm or 10mm for the rear is needed to achieve a more aggressive look... Am I correct so far?
      02-23-2013, 01:38 AM   #6
lmaleke
Hong Kong
hmmm 179 views and a couple of responses. That equates to: 2/179 = 1.12%
lol
      02-23-2013, 01:56 AM   #7
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
Yes, an 8.5" ET35-ish would be great up front and perfect with a 5-10mm spacer in the back.
If you want the front to be more aggressive just add a 5mm spacer.
I'm running 9" ET30 up front but that is too aggressive if you don't lower the car (in my opinion, but perfect with a low drop).
      02-24-2013, 01:38 PM   #8
lmaleke
Hong Kong
Thanks Rossi!
      02-24-2013, 08:34 PM   #9
ks200906
Drives: F30 328i MSport
I think 20x8.5 et35 all around would be nice. Slightly more aggressive than stock and should clear brakes and structs. Also suitable for lowering to any extent without rubbing if using BMW recommended tire sizes.
      02-25-2013, 05:04 AM   #10
lmaleke
Hong Kong
Talking
doujeh ks200906I was thinking a square set up either with 235/35-20 or 245/35-20. Either would be ok I assume? Interestingly the latter size has more brand to choose from than the former, I don't understand on why...
      02-26-2013, 12:27 AM   #11
pkimM3r
pkimM3r's Avatar
205
Cant yiu get the same width but different offsets instead of using a spacer??
      02-26-2013, 01:14 AM   #12
lmaleke
Hong Kong
Talking
Unfortunately that's not an option, the brand does not offer other width (at least for the time being) - only 8.5 available
      02-26-2013, 01:39 AM   #13
ks200906
If going for a square setup, a lot of brand only offer 8.5 et35 that would fit all 4 corners on F30.
If going staggered, you can go wider at rear with different offset.
