03-08-2013, 10:55 AM | #1 |
Rep 245
Tires Question -- How much vertical height
How much vertical height (profile) would I gain by putting a 265 tire on a 9.5" wheel from a 255 tire on a 9.5" wheel. Is it enough to matter?
Why you ask? Well I do not plan to lower my 335 m-sport and want to fill up the wheel gap as much as I can. |
03-08-2013, 11:56 AM | #2 |
Rep 398
I can't answer you're tire question but just wanted to throw out the m performance suspension will only drop the car 10mm more than your m sport or 3/4" over standard. I have it installed and absolutely love it. Might help you get the look you're after
03-08-2013, 12:12 PM | #3 |
Rep 245
Does it just come with Springs or Shocks and Struts? If the latter it's probably out of my budget.
03-08-2013, 01:53 PM | #4 |
Rep 3,553
almost nothing.
assuming you are running 19s with an aspect ratio of 35, 10mm wider will give you 3.5mm of more height. if you really want to fill out the wheel well, go for a higher aspect ratio tire. 255/40/19 will give you another half inch of sidewall.
Present: 2023 G07 40i ZDH/ZDU/ZMP/ZMQ/2NH/ZPK/ZPP/ZRC/300/3AC
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC |
03-08-2013, 02:24 PM | #5 |
Rep 398
M perf suspension link
http://www.getbmwparts.com/partlocat...catalogid=4462 Just a random site. No affiliation |
03-08-2013, 02:32 PM | #6 | |
Rep 245
Ordered factory spec'd tires and going to mount them on: 19X8.5 et32 Fronts - 225/40/19 19X9.5 et35 Rears - 255/35/19 @james: totally out of my budget. M-Sport package should have included those parts imo. |
03-08-2013, 02:35 PM | #7 |
Rep 280
Keep in mind going with a taller tire will change the speedo accuracy not a lot from the size you plan to go with but it will alter it and mainly at higher speeds.
03-08-2013, 02:56 PM | #8 |
Rep 245
Since 255 is now going on a 9.5" wheel, the profile should probably go a tad lower than factory. Perhaps 265 on 9.5" would have kept me more near factory profile but almost splitting hairs at this point.
03-08-2013, 03:39 PM | #9 |
Rep 398
03-09-2013, 02:05 AM | #10 | |
Rep 3,553
your overall diameter will be the same regardless of the rim width assuming the width and aspect ratio of the tire stays the same.
