12-10-2021, 10:45 AM | #1 |
Rep 11
Battery Will not hold a charge, Insight greatly appreciated!
Hello everyone I have a 2014 BMW 335XI (F30 , N55 ) For the past month if my car is off for over an hour it is bone dead, no lights, can't unlock etc. I've had the car on a charger overnight multiple times and it will start up in the morning, but once again if it sits at all, its bone dead once again. I've had my battery and alternator both checked and both of them check out to be in good condition, My negative and positive terminals are both secured on their posts and I make sure I leave nothing on that could be draining any power. Any ideas for what the issue could be would be greatly appreciated!
JacksonDesmarais
12-10-2021, 10:56 AM | #2 |
Rep 10,256
Something is clearly draining the battery if the battery passed the tests.
Were you able to retrieve any stored codes? |
12-10-2021, 01:36 PM | #4 |
Rep 4,877
Either a drain or the battery is bad. Its possible to have a loose plate that shorts it out under vibration.
If the battery is original from 2014, it's most likely the culprit. |
12-10-2021, 02:40 PM | #5 | |
Rep 102
The normal battery life is usually about 4 years. OEM BMW may be longer. I have a friend whose battery from 2013 hardly used car just changed this year.
F30 335i xdrive
12-10-2021, 03:16 PM | #6 |
Rep 16,089
I'd be very wary of replacing the battery. That's probably the single most often misdiagnosis here, leading to spending major coin that doesn't fix the problem. A simple test is to fully charge the battery, then remove the negative terminal overnight. If it's dead the next morning the battery is toast. If it holds the charge overnight the problem is parasitic power drain. Obviously you want to do this when you've got time the next day to give the battery one last charge to start the car before you drive to Autozone or the like for a new one.
Polo088161610.00 |
12-10-2021, 08:09 PM | #8 | |
Rep 706
12-10-2021, 11:04 PM | #9 |
Rep 125
If your battery drains in an hour, you have A MAJOR FIRE HAZARD SOMEWHERE! The battery in the car has a capacity of 90 Ah (or 95?), which means if it drains in an hour, your battery is running 90 amps of current through SOMETHING for an hour. At 12 volts, that means around 1000 Watts being spent somewhere. Something must be getting heated up pretty hot with that power.
Disconnect everything, don't drive the car, get it inspected. |
12-11-2021, 10:13 AM | #11 |
Rep 625
I’m going to assume when they did the battery test they tested voltage and CCA. The tester prints out the status and available CCA and the mechanic will give you the printout.
Assuming that checks out, looking for a parasitic drain is a as simple as connecting a multimeter in series, in ammeter mode after the car has had a chance to fully turn off. Then start pulling fuses. Not going to explain the technique here as if it’s done wrong you can mess up the car, the multimeter or personal injury. Look it up or get it to a mechanic to hunt down the parasitic drain. You can also use a FLIR to look for hot fuses but most people don’t have thermal cameras |
ChuckP4936.50 JackDesmarais3.00 |
08-14-2023, 12:33 PM | #12 | |
Rep 5
08-15-2023, 01:43 PM | #14 | |
Rep 184
OEM battery is not made by BMW so is any battery that they were buying at the time. My 18 month old BMW R1250RS had a battery failure as they were using cheap Brazilian batteries at the time (but OEM). The replacement aftermarket is going strong. |
08-17-2023, 09:37 PM | #15 |
Rep 339
Question, what is the approximate mileage on your car? Quite possibly it could be the water pump. It is an electric one and could be on its way out, as in constantly running, aka draining the battery. It happened to me, so you might want to check it out.
Billfitz8244.50 |
battery charging, bmw f30 3 series, f30, help a noob |
