08-19-2018, 05:20 AM | #13685 |
Rep 4
ISTA Error
Hi, I'm having a problem running ISTA.
I follow the steps in the manual and always get the error: Failed to start ISTA Please make sure ISTA configuration is valid. In doubt reset any non standard ISTA configuration and reinstall ISTA. I have put a fresh install of windows 7 on my Laptop, downloaded the link Shawn sent me again, but no luck. Would really appreciate any help |
08-19-2018, 11:07 AM | #13686 | |
Rep 8,364
08-19-2018, 02:08 PM | #13687 |
Rep 4
08-19-2018, 03:36 PM | #13688 |
Rep 8,364
08-19-2018, 07:41 PM | #13689 |
Rep 60
Shawn, would you be able to send the latest E-Sys and PsdZData please?
This is probably the third time I've reached out. It's been a few months since I last worked on coding my car and I decided to make some adjustments tonight but I'm stuck in the token loop again. I had it working perfectly a few months ago! Any idea how I got stuck in the loop? |
08-19-2018, 07:46 PM | #13690 | |
Rep 40,786
08-20-2018, 09:58 AM | #13691 |
Rep 1,241
Drives: 2016 BMW 340i
Shawn, can you please send me the latest E-Sys and PsdZData files? Thanks in advance!
2016 BMW 340i 688 | LCL5 | 4FT | ZMT | ZTP | ZDA | ZLP | 494 Formula One Pinnacle 30 Tint | Brushed Aluminum Pedals |
08-20-2018, 10:37 AM | #13692 |
Rep 40,786
PM sent.
08-22-2018, 07:13 AM | #13693 | |
Rep 3
Hi everyone,
I recently buy F31 320d and noticed that rain sensor was missing. I did some research and found out that my car has all the sensors, wires and buttons existing but only coding is needed. I already know from other thread what values i need to change but as a newbie i dont have any experince about coding. Ibought coding cable from ebay and next step is to get all the software and basic knowledge. Could someone give me link to working software and guidance how to set it up? Thank you. Quote:
08-22-2018, 08:17 AM | #13694 | |
Rep 40,786
08-23-2018, 03:33 PM | #13697 |
Rep 6
Enhanced Bluetooth Troubles
I recently took my car to the dealer to get them to update the istep version. However after this upgrade I can no longer get the enhanced bluetooth to work in the car the option is listed in the car however when I pair my phone it will no longer ask to stream audio as well as telephone. Any help would be appreciated as I had originally coded this feature in before the update. I'm using Psdzdata 4.12.35 along with launcher 2.8.2. When I went into the VCM to write the new values after hitting read it was listed as 10(Unknown).
Sorry if I should've included something is this I haven't as I don't have an in-depth knowledge if the coding. |
08-23-2018, 06:10 PM | #13698 | |
Rep 40,786
You should not be in VCM at all. Where exactly do you see "Unknown"?
08-23-2018, 06:39 PM | #13699 |
Rep 6
Hey Shawn thanks for replying.
I following the instructions listed here https://www.bimmerfest.com/forums/sh...96&postcount=7 On step 10 10. Click “read FA FP VIN” button and check FA to make sure changes are saved to the car. I believe it is under vehicle profile that shows unknown after I write the modified FA to the car. |
08-23-2018, 06:48 PM | #13700 | |
Rep 40,786
08-23-2018, 07:00 PM | #13702 |
Rep 40,786
If it is coded, it should work. You need to unpair phone, pair it again, and make sure Music is enabled under both Phone and Bluetooth Options.
08-23-2018, 08:41 PM | #13704 |
Rep 40,786
08-24-2018, 11:55 AM | #13705 |
Rep 6
Hey Shawn the only thing I can't seem to code through FDL coding on my F30 is the Easy Entry I do not have a module called SM2 only SM however I found EINAUSSTIEGSHILFE and set it but it still will not work. Is there anything I can do to make this feature work or am I out of luck?
08-24-2018, 12:00 PM | #13706 | |
Rep 40,786
