09-07-2015, 06:49 PM | #1 |
Rep 112
Night time visibility is terrible
Hello all,
Was wondering if any of you fine folks could provide me with some suggestions. I have a 2013 BMW 335i F30 M-sport in Estoril Blue II. I absolutely LOVE this car but there is one major problem that I have with it. The night time visibility with the adaptive HID headlights absolutely sucks. I mean it is just terrible. I have had multiple people comment on how bad it is. The high beams work great but the low beam lights just suck. Are they designed from the factory to be this bad and offer terrible visibility? Is there just something wrong with them? I feel like they are not pointing up high enough. I have tried moving the adjusters, and they offer so little adjustment that it didn't really make much of an appreciable difference. Is this something I should let BMW take a look at? Secondly, I have searched long and far for some sort of aftermarket solution to allow us to install auxiliary driving lights on these cars. There doesn't seem to be much on the internet about this. Is this even possible? Has anyone successfully done this? Can one of you smart, intelligent, clever people PLEASE figure out a way to make auxiliary/fog lights work on F30 M-sports? Thank you in advance. |
09-08-2015, 06:31 AM | #3 |
Rep 700
Start with changing out to brighter bulbs, I think the most common swap is up to 5000 or 5500k, after that, see about turning each of the lights up half a turn on each side, I belive it's the adjuster in the middle, not the ones on the outside. If thay doesn't work, bring it back to the dealer and let them get after it.
09-08-2015, 10:15 AM | #4 |
Rep 25
Take it to the dealer, it might be that they aren't adjusted high enough.
I don't think swapping bulbs to 5k would be a good idea. You would be getting a whiter light, but with less lumens output with 5k. |
09-08-2015, 10:52 AM | #6 |
Rep 2,754
Drives: 2020 M4 ZCP / 2023 X3 M40i
I adjusted my headlight aim slightly higher than factory spec and it's pretty good now. Either your aim is too low or something is wrong with your headlights. I would get a dealer to check it out.
09-08-2015, 06:58 PM | #9 | |
Rep 112
Wicked, will you get a code if you put different bulbs in? Mind telling me what type of bulb to buy? Do you need to replace the high beam bulbs as well? thanks. |
09-08-2015, 07:06 PM | #11 |
Rep 112
They are plenty bright enough, it's just they are pointed to low to be of any use. The light doesn't scatter enough in front of me and have gotten in the habit of relying on lights of other cars on the road, as well as street lamps to see further out in front. It's downright dangerous if you ask me. Need to get this dealt with ASAP.
09-08-2015, 07:15 PM | #12 |
Rep 821
Are they adaptive? If so I would think there may be more adjustability? Go to he dealer. One feature I have is auto high beams, amazing. It's faster then I could ever possibly be switching Hi to low beams. I have a 340 on order I would have purchased a GC but to get auto hi beams you need to spend an extra $1900 for LED. Good luck.
09-08-2015, 11:55 PM | #13 | |
part-time optimist
Rep 72
Drives: '12 Alpine White F30 335i
Here's a good set for much cheaper than the CBI's I got: http://www.highperformancebulbs.com/hipexed1shid.html Pick 4300K or 6000K |
09-09-2015, 12:01 AM | #14 |
part-time optimist
Rep 72
Here are the OSRAM CBI's I purchased for my car:
http://smile.amazon.com/dp/B00C7DAUF...ords=D1s+osram Best bulbs imo. Instructions on how to replace them are on page 197 on the manual I believe. |
09-09-2015, 03:46 PM | #15 |
Rep 814
turn CCW to raise them, right?
14 435i M Sport 6 speed, MG/Coral, MusicarNW Stage 3+ Upgrade for HK, M Brakes, MPPK, MPE, M Rear Spoiler, M Side Molding, full Expel wrap
09-09-2015, 03:59 PM | #16 |
BMW Fanatic
331
Rep 1,076
Go with the Osram Xenarc Nightbreaker Unlimited bulbs, they transformed my car's nighttime visibility.
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
09-09-2015, 06:13 PM | #17 | |
Rep 112
Just to clarify the car uses four bulbs correct? Two for high beam, and two for low beam? Last edited by pisgahlvr; 09-09-2015 at 06:30 PM.. |
09-09-2015, 10:17 PM | #18 |
part-time optimist
Rep 72
Yes CCW to raise them and CW to lower. Make sure you adjust the correct knob. There's a tutorial on this site with pics but it shows the horizontal knob instead of vertical so unless you want to adjust it side to side then adjust the one I've pointed out in the pic I just took below. Use a 6mm hex key to adjust. If you point a flash light in that hole, you'll see a little knob where the allen wrench goes.
09-09-2015, 10:21 PM | #19 | |
part-time optimist
Rep 72
Here's a video that shows how bi-xenon headlights work: |
09-09-2015, 10:21 PM | #20 |
Rep 1,604
Why wouldn't you take it to the dealer if you felt it was that much of a safety concern?
2014 Alpine White 328i M Sport | M Performance Exhaust | M Performance Front Splitter | M Performance Carbon Fiber Spoiler | M Performance Grills | M Performance Pedals[/SIZE]
______________________ |
09-10-2015, 01:53 AM | #21 |
BMW Fanatic
331
Rep 1,076
2 bulbs. They are BiXenon, so the bulb works as High + Low beam. 4350k.
09-10-2015, 08:12 AM | #22 |
Rep 814
Thanks Wicked.
