05-28-2023, 12:21 PM | #1 |
Rep 81
new bosch injectors Teflon seal not compressed?
Shouldn’t these have a metal piece on here that keeps them compressed?
Do I need to compress them or just apply some assembly oil and install? Was told I did not need the tool kit for brand new injectors |
05-28-2023, 12:37 PM | #3 | |
Rep 81
Just trying to figure out if I can install them |
05-28-2023, 07:41 PM | #4 |
Rep 383
05-28-2023, 07:50 PM | #5 |
Rep 81
03-25-2024, 08:26 AM | #6 |
Rep 8
Hi, did you compressed seal somehow before install? My Bosch injector just arrived and it looks exactly the same as yours. Not sure what to do next. Zip ties method seems doable as describe here: https://www.thedrive.com/guides-and-...r-seal-service but is it necessary?
03-26-2024, 12:18 PM | #7 |
Rep 77
With new injectors you don’t need to resize the Teflon seal. That is for reusing existing injectors and the Teflon seal is a mandatory replacement item every time you reuse an injector and must be resized once it is installed. I’ve done both. As has been pointed out you must install the decoupling element on the new injector. Your original injector you removed had it.
03-27-2024, 07:56 AM | #8 | |
Rep 1,687
Drives: 2014 428i and 2018 X5
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport |
