BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > I'm an idiot. Help.
proTUNING Freaks
      07-23-2015, 10:32 PM   #1
ahero4eternity
Drives: bmw
I'm an idiot. Help.
Used the wrong size socket to remove the negative battery terminal and now the socket is stuck. Any tips?
      07-23-2015, 10:37 PM   #2
Labeef
Labeef's Avatar
265
Drives: 320I Sport/Xenon
Grab some vice grips and lock onto the socket. Then with the other hand, gently tap on the terminal with handle of a screwdriver.
      07-23-2015, 10:48 PM   #3
ahero4eternity
Drives: bmw
Haha, did that. Even used a hammer on the other screwdriver's handle.
      07-24-2015, 01:13 AM   #4
layer_4
Drives: 2015 335xi
did you try heating the bit? it might expand and get larger.... doesn't hurt to try i guess
      07-24-2015, 02:18 AM   #5
obriennathaniel
@obriennathaniel_f30 on Instagram
obriennathaniel's Avatar
Drives: 582whp/596wtq '13 335i
hit it with an impact in reverse. If that doesnt work, tighten it down fairly good, then reverse it with a hit or two and itll break loose.
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge|
      07-24-2015, 08:42 AM   #6
rking117
Drives: Z4 3.0i & 320i
hahaha yep done that one too. I would try tapping it while turning it in the opposite direction that you did to get here. If that doesn't work then I would definitely try the impact wrench thing someone else mentioned. It will come off just be persistent.
hope that help,
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold)
      07-24-2015, 09:17 AM   #7
Thumper333
Thumper333's Avatar
Drives: 2018 M240i X-Drive
Sockets are cheap.
Get a saws-all.
2018 M240i X-Drive | Sunset Orange Met
2015 328d X-Drive Touring M-Sport (Traded)
2015 Audi S4 Sepang Blue P+ | DSG | Tech Package | Adaptive Suspension | B&O
2015 Audi S3 Misano Red | 19" Sport pack w/Mag Ride | B&O
1983 Porsche 944 All stock
      07-24-2015, 09:21 AM   #8
G30 B58
Pace Car Driver
1553
Drives: '22 AW G30 B58 M-Sport
Back it out and get a new bolt.
      07-24-2015, 09:43 AM   #9
Hernandiaz11
Drives: 2014 435i M-Sport 6-Speed
That obviously happened while you were loosening the bolt. Try putting the connector/clamp back onto the battery terminal and tighten the bolt and it should snap back out since you're applying torque in the opposite direction of when it got stuck.
      07-24-2015, 10:00 AM   #10
DrifterX
DrifterX's Avatar
Drives: 2016 340i M Sport 6MT+RWD
This is very simple...
1. Remove the bolt with the socket in tact
2. Hold the socket around it's circumference with a vice grip or pliers if you don't have a good grip, a bench vice would be best
3. Use a screwdriver to push down or hammer on the bolt through the socket attachment opening as indicated by the arrow below. It usually goes through the entire socket.
4. Profit???
      07-24-2015, 10:02 AM   #11
ahero4eternity
Drives: bmw
3. Use a screwdriver to push down or hammer on the bolt through the socket attachment opening as indicated by the arrow below. There's usually a hole that goes through the entire socket.
4. Profit???
Attachment 1249935
Thanks for the tip, but read post #3. Been there, done that. Used a vice grip (roommate held that) while I hammed away. SOB is stuck on there good!
      07-24-2015, 10:11 AM   #12
DrifterX
DrifterX's Avatar
Oh my bad How much did you torque this damn thing... LOL
Did you try applying any penetrating oil? May give it some lubrication. Only other option is heating like someone else mentioned, maybe even with just a heat gun if you have one lying around.
If heating it doesn't help, I think you're better off just leaving the socket on there. You'll never have to use another socket to remove your battery terminal again
      07-24-2015, 11:04 AM   #13
rking117
if you have taken it completely off the screw then using a larger diameter socket ( one that the current socket will not fit into but the nut will place them one on top of the other and using a screw driver or similar smack that thing good it will come out.
      07-24-2015, 01:45 PM   #14
CalCarNut
CalCarNut's Avatar
Drives: 2015 F36 Jet Black Sport Line
WD-40 shot from the top and visegrips around the socket with maybe latex glove between metal and visegrips for maximum grip.
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint|
      07-24-2015, 03:37 PM   #15
435MSport6Speed
435MSport6Speed's Avatar
432
Drives: 435i M Sport 6 Speed
sell the car immediately.
14 435i M Sport 6 speed, MG/Coral, MusicarNW Stage 3+ Upgrade for HK, M Brakes, MPPK, MPE, M Rear Spoiler, M Side Molding, full Expel wrap
