03-26-2018, 07:47 PM | #23 | |
Rep 891
View post on imgur.com I am running the Apex SM-10's 8.5 et35. They are concave, but there are also larger versions with more concavity. I could run 255's but when I bought these (June '17) the only 18 inch size available for PS4S was 245, and I still was rolling on the stock 8 inch 397s. Spring is in the air! Best time for mods, haha.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i Last edited by MacklinUSOB; 03-26-2018 at 07:49 PM.. Reason: fix photos |
DaFish155.50 |
03-27-2018, 05:32 PM | #24 |
Rep 463
I have been wanting to go lower as well. I have a 435IX and lowered it on HR Sport Springs. The drop makes it look closer to stock for a regular 435i.
03-27-2018, 05:33 PM | #25 |
Rep 1,288
Drives: 2014 435iX, FBO
I had some questions for KW on the Street Comfort/V1 and V2
1) As RIDE quality goes please compare KW Street Comfort - assuming the best - how does this vary from 1 click to 16 clicks of rebound - does it get as hard as the V1 or V2? KW V1 - at what setting compared to the Street Comfort (in clicks) would the V1 be? KW V2 - Where is this firmness/comfort compared to Street Comfort in clicks, and would the V1 be in the middle of the settings for the V2? For example: the V1 would have the same ride comfort with the Street Comforts in 10 clicks, and the V2 in 4 clicks... this would give me some idea of how stiff. 2) Ride height. Street Comfort - if this only goes down 1.58", I think this maybe not enough. is the 1.58 measurement from where the stock suspension is now? (IE: 3" higher?) KW V1 - I read a lot about these being too low... again this would be from the stock height? KW V2 - is this the same spring as the V1 except adjustable? 3) Is there a “recommended” height, or can I set the height to the absolute min or max of Front Lowering is 0.8" to 2.0" and Rear Lowering 1.0" to 2.0" ? Here is KW's excellent response - and they responded in a day too ! Great service. Thank you for contacting KW. For kit number 1802000U on the 4 series models the Front Lowering is 0.8" to 2.0" and Rear Lowering 1.0" to 2.0". The SC kit can adjusted to feel very much like the V1/V2 by closing the valve and getting closer to the 16th click. It is not predefined as to what click on the SC kit would match the V1/V2 however you will find it within the closed range of between 8th-16th click. The V1 is present in the middle range and the V2 will feel more firm by comparison to the SC system primarily due to the springs and valve rate. The V1/V2 systems ride height range is F 1.2-2.4” and R 1.4-2.4”, a little lower than SC. The V1/V2 are the same set up with the exception of rebound adjustment. Based off you suspension requirements our best suggestion is the Street Comfort system. These suspension systems are built in Germany upon placing your order and the estimated delivery time is around 3 weeks. Let me know if you need more information or need assistance placing an order direct from the manufacturer. Yes you have the freedom to set it at min or max or anywhere in between 0.8" to 2.0" Respectfully, Sales and Technical Support Manager KW automotive North America, Inc.
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S |
03-27-2018, 05:39 PM | #26 | |
Rep 1,288
The XDrive is ridiculously high. BMW should at least offer a "sport suspension" that would make the XDrive at the same height as the non XDrive suspension. I almost didn't buy the car because it looked like sh_t. I almost sold it because I can't stand the look of the height. These C/O will fix it and with the mods I am hoping I will love this car again and keep it for another 2 years - It only has 73,000KMS (less than 50k miles) on it, so lots of life in it.
04-11-2018, 09:58 PM | #27 |
Rep 2,556
You sure you want to drop your car that much? Wondering how that'll affect suspension geometry and subsequently handling? My vote is Street Comforts (which I liked on my car) and a one inch drop, fwiw.
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
04-11-2018, 10:21 PM | #28 | |
Rep 808
It's interesting how they compare the V2/V1 to the dampening adjustment of the SC, I ran my SCs at 9/16 and found that too stiff for me and the roads here so I'm glad I had the option to soften them out a bit |
04-25-2018, 08:55 PM | #29 |
Rep 1,934
Wow nice read. So street comforts can go to v1 stiffness and just fall short of the softest setting on v2. The height adjustment is on the lower end from stock ( is this xdrive stock or rwd stock?) compared to v1/2.
04-27-2018, 09:55 AM | #30 | |
Rep 1,288
This looks fantastic, but I think it maybe too aggressively low. Frig does it look sharp though. Incidentally this is the absolute bottom of the rear adjuster- it won't go lower, but I would never go lower than that anyway. The front can go much higher or lower. I'll need to set this higher for the winter. I set the rear settings to 6 clicks, I wanted soft. WARNING: you need to remove the rear shock to adjust the softness- this is about an hour of labour. You need to sure what firmness you want in the car ON INSTALL! I wanted a bit firmer than stock, and I got that. The front you can pop the hood and adjust I just bumped it to 7 clicks and I'll report back. All in all, I'm pretty happy. Just sitting waiting for my alignment and then I'll report on the handling. All my engine mods are in now, and I'm really starting to love this car now. Never imagined that an xdrive car could be this good! Special thanks to the dope steez and everyone helping me to figure all this out! Great to have this community!
MacklinUSOB518.00 |
04-27-2018, 10:31 AM | #31 | |
Rep 808
Hopefully you like the setup! Yes the rear rebound settings are a PITA to redo, you'll want to set that up right the first time. |
04-27-2018, 05:02 PM | #32 |
Rep 1,288
Ok here is a pic. Remember, I had a 3" gap between the wheel and the fender...
The fitment and offsets of the rims and PSS 4S tires are perfect. I'll get more as I get the car cleaned up this weekend. I think it needs to come UP 1/4" to 1/2", but it looks friggin GREAT this way.
04-27-2018, 06:12 PM | #33 | |
Rep 808
04-29-2018, 01:34 PM | #34 | |
Rep 1,288
04-29-2018, 02:45 PM | #35 | ||
Rep 808
What is your rear wheel offset out of curiosity? EDIT I read your earlier post - ET40. Wish I had ET40s |
