03-22-2013, 04:01 PM | #23 |
Rep 604
I rip Lossless WMA from Cd's with Zune software, put it in a 32gb usb, and it plays. 2013 model f30
07 E83 X3 BSM Sport-->10 E90 335i xDrive BSM M-Sport-->13 F30 335i xDrive EB M-Sport-->16 MKVII LB Golf R --> 19 F22 M240i xDrive MG
03-22-2013, 06:06 PM | #24 | |
Rep 148
BUT... ...to my disappointment, when I played the tracks via my Scandisk 32GB Cruzer Fit USB drive in my F30, the tracks played with gaps. I assume it has to do with the way the BMW stereo processes/plays the files. Totally discouraging. So I guess gapless playback in a digital format is unattainable. I think since I can't attain seemless/gapless playback even with a lossless format, I am just going to rip my CD's to high quality mp3's using VBR -V0 using the LAME encoder. I think the quality will be good enough for me and I will be able to fit about 300 albums on my drive as opposed to only 60 or so if they were WMA lossless. When I want to listen to a CD that has tracks that run together, I will either just have to live with the gaps, or pop in the CD. I did notice that when you go into External Devices->USB, it starts playing whatever you last had playing. Is there a way to STOP playing, or is your only option to you use the mute/volume button? What if I would like to be able to search for an album/music to silence instead of listening to something that I no longer want to listen to? |
03-28-2013, 11:15 PM | #25 |
Rep 366
Some of my lossless WMA tracks are listed, but immediately skipped when played. Seems to happens with entire albums. Some do play, though. Annoying.
F34 (2019 330xi): Luxury, ZCV, Nav, ABSD, Alp White
F34 (2016 328xi): Nav, ZDA, Alp White F30 (2013 328xi): ZCP, Nav, PDC, Alarm, Shades, GS Metal [Ret] E90 (2009 328xi): ZCP, iDrive, BMW Assist, PDC, Alarm, Shades, SG Metal [Ret] E90 (2006 325xi): ZSP, ZCP, iDrive, BMW Assist, PDC, CA, Xenons, Shades, CrO3 Exhaust, TiAg Metal [Ret] |
05-12-2013, 10:15 PM | #26 |
Rep 27
I have the same issue with my 2013 F30. The car stereo will play my WAV files from my 64GB USB flash drive and it recognizes all of the songs contained within separate folders, however it does not play the tracks without momentary pauses between each. This is VERY annoying when listening to live recordings!
05-14-2013, 10:00 AM | #27 |
Rep 10
Suggest using iTunes Playlists. Strikes me as much easier and has more functionality with BMW. Format in FAT32, copy musc files from iTunes Playlist to folder on card (drag and drop the Playlist), use VLC to build playlist mpu file.
