04-16-2017, 12:51 PM | #1 |
Rep 320
++F36 sub enclosure and amp rack++
I haven't posted much on the forums; life and work have been crazy! That said, I wanted to share some updates to the hatch area of the GC. I've made a few variants of these now, but this latest enclosure is 8mm thick (slight overkill) with a beauty ring to hide the mounting hardware on the subwoofer. The sub is an Oz Audio OzV10.25 10". I was a huge fan of the old school Oz stuff from the 90's, so I was really curious to see how the new stuff performed.
The amp rack is under the floor, housing a Zapco ST-X compact chassis amp, and Kicker's summing loc. The summing wasn't necessary, but this piece can handle up to 40v input, so it does the trick well for the HK system. Anyways... here's a few pics of the finished product. Hope ya dig! 🎶 Last edited by Titan 3; 04-16-2017 at 01:01 PM.. |
04-19-2017, 01:45 PM | #4 |
Rep 320
Thanks! It's really done surprisingly well. I've used a couple of Alpine PDX micro chassis, and got a good amount of heat of them as well. This thing is running at 2 ohm, and has yet to be something too hot to lay my hand on.
04-24-2017, 02:33 PM | #8 |
2006 TIME Person Of The Year
9720
Rep 6,445
Looks great. Questions and comments:
Fuel filler and battery is on that side... Probably more room on the driver's side. How did you mount the enclosure to the body of the car? Is it able to be removed without tools? Did you modify the inner trunk panel? How much interior air volume were you able to retain in the enclosure?
04-26-2017, 12:35 PM | #9 |
Rep 906
wow that looks real clean. good job. wish i didn't have less than a year left on my lease i'd totally do that!
2016 X3 35i M-Sport
2019 440i Coupe M-Sport - Retired 2018 330i Sedan M-Sport - Retired 2015 428i Gran Coupe M-Sport - Retired |
04-29-2017, 01:01 PM | #10 | ||
Rep 320
Thanks for the questions! The F36 is actually ideal on the passenger side only. The battery is actually sunken into the floor, so the space at floor height and above is a vacant cavity. The driver side has your tool kit, stock amplifier and the motor to your hatch. There's actually very little room there. I remove the battery try and the enclosure replaces it. So the panel is unharmed and can be replaced if you decide to return to stock. The enclosure sits in a floor groove and pressure fits into the wall. My current one has roughly .7 cu ft, but most of the ones I make are closer to .5-.6 to run 10w6v3's in. They like .55 cu ft, which works out well. Hope I answered everything! Here's a few additional pic of different variations of them. [IMG] View post on imgur.com [/IMG][IMG] View post on imgur.com [/IMG][IMG] View post on imgur.com [/IMG][IMG] View post on imgur.com [/IMG]I can appreciate that. Mine is done in a year and a half or so. It's had me struggling w how much throw at her. |
