BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Sport+ Coding
proTUNING Freaks
      11-10-2014, 09:44 PM   #155
TractionControl=OFF
Drives: XP-38 (F30) Landspeeder
Originally Posted by kapkanimd View Post
Same thing happened on mine after dealer reprogrammed the car.. sold the car before I even tried to find a fix.
did u sell it privately or trade it in, or sell it back to dealership? did u not like the car anymore?
      11-10-2014, 09:50 PM   #156
kapkanimd
Drives: 2020 M8 Competition Gran Coupe
Loved the car, just time for a change. Sold the lease privately.
      11-15-2014, 11:55 AM   #157
kevbo
Drives: 320D GT
Originally Posted by shawnsheridan View Post
In SAT mode, you get S1-S7. When you are in SAT, and then manually up/downshift with the Gear Shift or Paddles, it switches to Manual Mode and you get non-SAT M1-M8. And yes, non-SAT Sport Mode shows just DS.
Hi all. When I started reading this thread I was really pumped that I could activate SAT but this seems to suggest I already have it. I'm driving a 320D GT Sport Line. I don't have paddles or the sports gear stick however when I press the gear stick over it shows S1-S7 on the dash. The gear changes don't feel any different if I'm in Comfort, Sports or Sports+ . I always just assumed using the gear stick was a short cut to putting the car in Sports Mode. Is there a sure fire way of knowing if I have it or not?
      11-17-2014, 12:58 PM   #158
TractionControl=OFF
You can ask your dealer, or you can feel how aggressive the car shifts, like its jolting really hard.
      11-17-2014, 01:12 PM   #159
kevbo
Drives: 320D GT
I reckon its off. I read somewhere on this forum that the S1-S7 can be activated independently of SAT.
      11-17-2014, 02:46 PM   #160
carzaddict
Drives: 2015 Cadillac Escalade ESV
activiating s1-s7 can be done via coding
2015i Cadillac Escalade ESV
      11-18-2014, 03:08 PM   #161
fea30boy
fea30boy's Avatar
Drives: F30 320i
Just use any VINdecoder and see if your car has the 2TB option. If so it has SAT, if you found 205 your car has the normal autotransmission
      01-08-2016, 09:33 PM   #162
CntryClub007
CntryClub007's Avatar
490
Drives: 2016 340i | 2015 X5-50i
Originally Posted by Timur View Post
It is possible . I have done on on my 320i.
Do the following:
Kombi => 300C ECO_FDS =>Function
FDS_MENUE_TEXT_1=> menue_3
FDS_MENUE_SIGNAL_1=> menue_3
FDS_MENUE_TEXT_2=> menue_3
FDS_MENUE_SIGNAL_2=> menue_3
FDS_MENUE_TEXT_3=> menue_3
FDS_MENUE_SIGNAL_3=> menue_3
FDS_MENUE_TEXT_4=> menue_3
FDS_MENUE_SIGNAL_4=> menue_3
ICM Module/ 3000 Daten/ IcmKod_B_Sportlenkung/ verbaut
EGS/3000 Applikation -> Sportschalter_alt -> aktiv
EGS/3000 Applikation -> Sportschalter -> aktiv
ICM/IcmKod_B_S2TBA -> verbaut
It will activate sport+ and sport transmission )))
Or you also could add 2TB option and delete 205 in salapa element
Apologies for the stupid question here...
On the SAT and Sport+, do I need to change the FA from 205 to 2TB, as well as do the Kombi, EGS, ICM etc...or can I just do the Kombi, EGS etc...or just the 2TB?
From my understanding, I need to do FA change first and then progress with the others like traditional CAFD file coding under the SVT section?
Edit: All I had to do was change the FA to 2TB, and then VO code the 3. I went in via FDL (through CAFD) and verified everything was there and it was. My launch control was actually on by default too.
      02-06-2016, 07:33 AM   #163
Raygbmw1
Australia
Drives: Bmw116 F20
I successfully VO coded the 2TH replacing 205 in my F20 116i and removed error due to paddle shifter not installed.
What I did was as follows:
1. Remove 205 and add 2TH in my FA and write the modified FA to the car.
2. I coded the EGS, ICM, Kombi and FEM body.
3. I FDL code Paddle to nichtactive in FEMbody.
4. Checked the car with Rheingold and it reported that EGS is not receiving information from the paddle - duh ... paddle is not installed just yet.
5. Followed the test procedure to make the gearbox to re-learn signals form the car. When this finished, error is then cleared.
2TH does not need paddle shifter but the paddle needs to be set to nichtactive in FEMbody, otherwise an error in EGS is recorded.
Paddle will be installed in the near future when I get my christmas bonus..
      02-28-2016, 10:31 PM   #164
pentagon
pentagon's Avatar
23
Drives: 2015 F30 328xi
I just coded SAT and i have a stupid question ...
Is it passive, or do i have to activate it manually by moving the lever to the left(S1). If i leave the lever at default position, will the car shift any differently vs regular auto?
      03-01-2016, 04:35 PM   #165
CntryClub007
490
Did you do 2TB or just Sport+ coding? It should just work, I noticed it most when moving the lever over and in manual mode. Also when in sport or sport+, not comfort or Eco pro.
Sport Trans Shifter and Coding Tutorial 205 -> 2TB http://f30.bimmerpost.com/forums/sho....php?t=1219013
      03-16-2016, 05:35 AM   #166
REd116
Drives: F20 116i
hello i ve got a f20 116i year 2014/10 sportline with sport+. i can see s1 s2 ..in the manual mode but i dont have sat...do we know the code just for the sharper gear changes?i dont want the activation for the padddles..
      03-18-2016, 09:10 PM   #167
Sniper101
Sniper101's Avatar
Drives: 2013 328i F30
Successively and sport plus bit i do not have S selector it still shows DS
      05-24-2016, 02:40 PM   #168
Alan_Tan
Malaysia
18
Drives: BMW F30 330E
SOLVED
      06-14-2016, 06:26 PM   #169
matteis
Drives: bmw 118i f20 sport gp
I tried to code a F30 2014 320i GP to enable Sport+.
I fdl coded:
KOMBI:
FDS_MENUE_TEXT 1,2,3 and 4 = menue 3
FDS_MENUE_SIGNAL 1,2,3 and 4 = menue 3
ICM:
ICMKOD_B_SPORTLENKUNG = Verbaut
It did enable Sport+ mode, but I can't see "Sport+ Image" in dash (just on iDrive Screen).
Am I missing something?
I didn't change FA. The car has 205 auto transmission.
      08-27-2016, 12:13 PM   #170
aenima4six2
aenima4six2's Avatar
Drives: 2022 M5C + 2019 Ford Raptor
Update.
If you are running the latest BMW software you will also want to code the following, or you will be missing the "SPORT+ DCT OFF" menu in the dash.
KOMBI [60] [NS64828] > CAFD_000009C8_006_003_023 > 300C ECO_FDS, 3C > Funktionen > FDS_MENUE > Ausgelesen > menue_3 (Werte=03)
      10-20-2016, 07:20 PM   #171
nemobanks
Nemo banks
nemobanks's Avatar
Drives: 2014 BMW F30 328i
Originally Posted by ardyer View Post
As someone new to all this, would the presence of xdrive matter for this? I wouldn't think so, but I would like know sure.
Same happen to me any luck?
      10-21-2016, 12:15 AM   #172
nemobanks
Nemo banks
nemobanks's Avatar
Do the following:
Help me please i have an CEl after i coded. What to do?
      02-11-2017, 10:21 AM   #173
RideInBimmer
Drives: F30
Hi, i took apart everything to see how the gear selector switch is plugged into the interior. I am planning on purchasing a new gear selector switch because my current one is scratched. If i am using a Used gear selector switch, are there going to be errors? The company that sold it to me said that it is a "plug and play", that means no error codes right? Thanks
      03-08-2017, 08:06 AM   #174
skanderbeg
Drives: F30 328i
Do the following:
Just to clarify, because I am a little confused with what FA (VO) coding does versus just changing the variables in CAFD (FDL coding).
If I change just the CAFD variables listed above and don't mess with changing 205 to 2TB under the FA, I can have sport automatic transmission (SAT) and sport+ option in my car? If this is the case, what is the purpose of the 2TB option, besides for paddle shifters?
      03-10-2017, 01:31 AM   #175
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
VO coding takes the guesswork out and tedious changing of 1+ FDL's by coding 100% of an ECU to factory values.
If your vehicle does not have paddle shifters, you follow-up with FDL coding to set parameter to nicht_aktiv to avoid errors.
      09-14-2017, 03:49 PM   #176
Dzhedaj
Drives: F30 328i
A question on coding SAT (I know this one's an old topic, but it has loads of useful info):
The instructions here say to code ICM Module/ 3000 Daten/ IcmKod_B_Sportlenkung/ verbaut
If I do 2TB VO coding, this one is not enabled, it seems to be steering wheel, not gearbox related if we translate it from German...(I do have the M sport steering wheel and paddles). So is this one really necessary to enable and what does it actually do?
