10-04-2023, 07:41 AM | #1 |
Rep 290
Engine map - Gearbox map...
Hi Guys,
I'm just wondering if you can just map the engine is there a point having the gearbox map??? or do both need to happen? I'm very new to the f30 platform mapping situation.. I have a 330d 2015 Many Thanks |
10-04-2023, 08:17 AM | #4 |
1933
Rep 2,109
I'll be getting both engine & box mapped come the New Year (when my F31 is out of extended warranty)
I'll be getting the box serviced first though so it's in full health and would highly recommend doing the same
Bachu172.00 |
10-04-2023, 08:50 AM | #6 |
Rep 1,027
From what I've gleaned online doing similar research, so long as the remapped engine's torque curve matches the stock map's curve, then the stock gearbox map will work fine.
But if the engine map changes drastically, then a lot of people try the Alpina TCU map, or flash it with XHP, otherwise the stock BMW TCU map can do some funky things. How and why I don't know as most torque converter autos only care about input shaft speed vs output shaft speed to measure the shifts, but who knows how torque curves come into it. Another theme I've picked up on is a lot of people end up going back to the BMW TCU map after living with the Alpina one for a while. Take from that what you will! |
Bachu172.00 |
10-04-2023, 08:51 AM | #7 |
1933
Rep 2,109
I'll be going XHP I think; that's the one that's thought of highly the most...
The lads 330D I was out in yesterday to see how the Bilstein B16s are has the XHP map on his box along with a Stage 1 remap and it was very different to how my box behaves; so much smoother and reactive
Bachu172.00 |
10-04-2023, 09:00 AM | #8 | |
Rep 290
This is good know.. Ideally i would like both but will see closer to the time |
danb19791932.50 |
10-04-2023, 09:08 AM | #9 |
Rep 1,993
Drives: F30 335d
I have the Alpina map on my remapped 335d, it's a good match for it since the remapped 335d and Alpina D3 both have 360bhp.
Gear indicator is a bonus, but the best thing is it's free if you're happy to use Esys. If not it's not much to get someone to flash it, I've done a few members cars from here. I think some people who weren't happy with the Alpina map had 330ds where IMO XHP would be better.
if I've helped - an Appreciate would be, er, very appreciated!
Bachu172.00 |
10-04-2023, 09:16 AM | #10 |
Rep 8,501
IMO it's worth 'mapping the transmission if you are having the engine remapped.
I've been running XHP for a few years and the differences are noticeable, especially with the more recent versions of XHP. Compared to a 'fixed' transmission map such as Alpine XHP offers a lot more user functionality, i.e. the ability to change a wide range of parameters and functionality settings and re-flash the transmission, typically in less than a minute, and without any additional charges.
10-04-2023, 10:03 AM | #12 |
Rep 1,993
Drives: F30 335d
Yes.
10-04-2023, 10:17 AM | #13 |
Rep 1,027
The TurboLamik controller is another option if you want full control as it completely removes the BMW TCU. I've seen some great things done with it, but it's more for geek level 10 stuff.
Yeah it's annoying only Sport and Manual modes show the gear as standard. I wouldn't mind knowing what D is up to when it starts gear hunting at 20mph. |
10-05-2023, 02:29 AM | #14 |
Rep 175
I had my 330d remapped after getting it, approx 310 bhp. Made it so much more fun to drive. After a month or 2 I got the xhp gearbox map and went straight with the off the shelf stage 3, it really brought the car to life. Would highly recommend it.
10-05-2023, 03:18 AM | #15 |
1933
Rep 2,109
Did you install it yourself or get someone to do it for you?
10-05-2023, 03:58 AM | #17 |
Rep 8,636
10-05-2023, 04:04 AM | #18 |
Rep 33
I had my 430d remapped to 315hp and 700nm of torque and ran without a gearbox remap for a couple of thousand miles. However, I could feel the car hit the torque limiters in 3rd and 6th when accelerating in those gears. It was really noticable in 3rd as it almost felt standard in that gear.
I then went to XHP which i admit is a costly mod, but I've not had any issues since and the gearbox can use the full power of the engine all the time. Plus the shift maps are a lot better for cruising, economy & sports driving when needed! |
10-05-2023, 04:45 AM | #19 | |
1933
Rep 2,109
Just I see them crop up for sale every so often and have wondered whether to buy one etc
10-05-2023, 04:59 AM | #20 |
Rep 175
10-05-2023, 05:09 AM | #21 | |
Rep 1,027
If XHP removes 2nd to 3rd hunting between 14-19mph in traffic, I would buy it for that alone. |
10-05-2023, 05:21 AM | #22 | |
Rep 175
If I had to choose between the engine or gearbox Remap I would pick the gearbox. As for removing gear hunting, I can't comment. |
