09-11-2013, 08:18 PM | #23 | |
Rep 349
That said, OZ's make a good track wheel due to price. I'm personally not a fan of their look on a bmw, but who cares. Cheap to replace annually.
2013 EBII 328i M-Sport 6MT, M-Performance Brakes, M-Performance Suspension, APEX Arc-8 18 x 8.5 square, Pilot SS
1999 EB1 M3 - Bilstein PSS9, Vorshlag Camber Plates, Kosei K1, ZII Star Spec, PFC, gallon of distilled water. |
09-11-2013, 11:24 PM | #24 | |
Rep 267
Low pressure cast, light weight. Nice looking wheels! |
09-12-2013, 08:27 AM | #25 |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
Low pressure cast (e.g. OEM BMW, non-forged OZ/Avant Garde/BBS, etc.) can be pretty good. But flow formed are typically lighter and stronger. Kinda the middle ground between cast and forged.
09-12-2013, 12:38 PM | #26 | |
Rep 586
The High Light Technology (HLT) process used in the manufacturing of select O.Z. Racing wheels uses rollers to compress and elongate the material along the barrel of a low-pressure cast aluminum wheel to obtain the desired profile. This process, which is directly derived from O.Z.'s experience in F1, produces wheels that are extremely light and strong. The flow forming process and the HLT technologies combine to create mechanical characteristics similar to those of a forged wheel. This permits a dramatic reduction in wheel weight while enhancing structural rigidity vs. a standard cast wheel. |
09-12-2013, 05:03 PM | #28 |
558
Rep 1,477
Drives: 335i
Yes, to be clear, OZ actually makes wheels by all 3 processes... forged, flow formed & cast (both gravity and low pressure)
09-13-2013, 01:34 AM | #30 |
Rep 586
Yea
G05 - M Performance roof spoiler
05-26-2016, 12:17 AM | #32 |
Rep 101
has anyone succesfully find proper 18inch light weight wheels for F30 328i with M performance brake kit? i also want to change to 18 inch light wheel (prefer forged) to replace 400M but not sure what will fit.
05-26-2016, 01:48 AM | #33 | |
Rep 4,311
the most reasonably priced fully (mold/form) forged are from BC Forged, Advan Racing's RS-DF, RZ-DF, GT and a several styles from Rays/Volk Racing. these offerings start at $750 per wheel, though. http://www.rayswheels.co.jp/products/choose.php?lang=en i have Volk Racing G25 on Bridgestone Potenza S-04, 18x8 +45(w/5mm spacer) 245/40 front and 18x9 +50 255/40 rear. i suggest Michelin Pilot Super Sport tires instead since they are better and much lighter than the S-04's. not sure how much larger m-performance brakes are but there is ample room around my M-Sport Brakes Last edited by alohasurftoad; 04-27-2017 at 02:21 AM.. |
05-26-2016, 02:05 AM | #34 | |
Rep 953
2014 328i - FBO/KW v2/VMR v710's IG@F30_Joe
05-26-2016, 03:08 AM | #35 |
Rep 3,940
05-26-2016, 08:24 AM | #36 | |
Rep 101
05-26-2016, 09:42 AM | #37 |
Rep 4,311
370mm? i don't think it will fit. that's 15mm more radius. you may have to increase to 19" wheels
05-26-2016, 12:58 PM | #39 |
251
Rep 1,636
Our newest release is the RW.Split. Flow form wheel available in a 18x8 ET38. Flow Formed construction with a Satin Black Machined lip. They come with BMW caps. PM me with inquiries!
They weigh only 18lbs each!! |
05-26-2016, 01:36 PM | #40 |
Rep 4,311
that's hot! looks similar to my volk g25. wish these were out when before i got mine, could've saved some $$$$.
actually it looks like a clone of the volks, lol Last edited by alohasurftoad; 05-26-2016 at 02:11 PM.. |
05-26-2016, 02:05 PM | #41 | |
Rep 4,311
i tried to get a tape ruler back there but it was too difficult. there is a lot of room with m-sport calipers however if you increased the rotor radius 15mm it (assuming m-perf and m-sport calipers are the same size) would be real close. |
05-26-2016, 02:26 PM | #42 | |
Rep 3,940
05-26-2016, 02:38 PM | #43 |
251
Rep 1,636
05-26-2016, 09:55 PM | #44 |
Rep 4,311
if it fits under these 18" bmw wheels, i suspect it would fit under the volks or most any other 18" aftermarket wheel. (except some 18" enkei i've read about that rubbed the m-sport caliper)
