10-21-2014, 09:37 PM | #1 |
Rep 284
Drives: 2023 X5 X45e
CEL post-coding & KOMBI CAFD read error
I went to code my 2014 F30 yesterday evening, and in reading the CAFD files, I got the following error for KOMBI:
Code:
Transaktions-Report: Aktion: Codierdaten lesen KOMBI [60] [F720116] readCPS o.k. cafd_000009c8-006_000_030 Fehler: NCD read from ECU "ECUId:KOMBI_0x60" for CAF "cafd_000009c8-006_000_030" failed! [C069] Error processing XML data [1660] Thanks in advance! |
10-22-2014, 11:54 AM | #2 |
Rep 1,892
It's a know bad CAFD file (it's all NUL bytes).
You can either try injecting a newer CAFD file into the ECU (Shawns method), or send me a PM with your e-mail address and I can help you out. You can clear the CEL in E-Sys : Click "External Applications" in the left menu. Click "External Application" Double-click "Transmitter" Scroll to the bottom and double-click "... Clear all DTCs ..." |
10-22-2014, 12:28 PM | #3 |
Rep 284
Awesome - I'll shoot you a PM here in a minute. I'll have to venture down to the garage at work and clear that CEL though. I'd like it gone so if it reappears then I know there's a legit problem or not.
10-24-2014, 09:45 AM | #4 |
Rep 1,976
Drives: 2020 G20 320i M Sport
I noticed that you have a 328d. I've coded the KOMBI on two of these and the CEL would always come up whenever you make any coding changes to KOMBI.
I think there's some sort of sensor on the cluster that needs a specific reading otherwise it will come up with that CEL. I've only seen this happen on the F30 328d. The first car I coded took about a week for it to go away and the other one I coded took about half a day. I wasn't able to clear these with Tool32 but they will clear on their own after a while guaranteed.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
10-24-2014, 09:24 PM | #5 |
Rep 284
Yeah I noticed that it was right after that. Just wonder if things are not in sync when that particular system restarts. I was able to clear it following the instructions here. Was odd that I couldn't find it anywhere!
